Lenovo s145-14api dump bios
  • madjid911
    • Dec 2016
    • 410
    • France
    HI, my laptop, starts without display, the power button light blinking, i think the bios is corrupted, can you fix my dump? THANKS
    lenovo S145-14API
    motherboard GS440 GS540 NMC511 REV:1.0
    S/N : PF13258A
    MTM : 81UV0031FR
  • madjid911
    • Dec 2016
    • 410
    • France
    Re: Lenovo s145-14api dump bios
    I tried several bios here in the searches but none worked, I did not find the exact model
    • hardware1
      • Sep 2021
      • 2948
      • N/A
      lenovo S145-14API
      S/N : PF13258A
      MTM : 81UV0031FR
      Here's your New BIOS, it's a Virgin BIOS from Lenovo with your DMI.
      all donations are welcome,
        • 21914
        DMI 1000 - 2FFF (0x01000 - 0x02FFF)
        S145-14API Type 81UV .Bios Version: BUCN33WW
        Anyone can add their own DMI easily using the bios from post #3 and your own backup with the attached CopyDMI script.
        Easy Guide: Copy DMI info easily with Hex editing software and Macro script -> https://www.badcaps.net/forum/showthread.php?p=1214739
        • madjid911
          • Dec 2016
          • 410
          • France
          it didn't work, i think the processor is dead
          THANKS
          • madjid911
            • Dec 2016
            • 410
            • France
            Thanks for the link, I can try to do it myself now.
            • Azrael29
              • Mar 2023
              • 3
              • France
              Hello, I have exactly the same problem as madjid911, I tested several bios on the forum, without success.
              Is that someone could check my backup? I am not sure what is correct.
              I tested this solution with my backup, but it doesn't work.
              Lenovo S145-14API
              S/N : PF1DBX16
              MTM : 81UV0031FR
              Thanking you in advance.
              • peste
                • Dec 2016
                • 13600
                • ROMANIA
                Lenovo S145-14API
                S/N : PF1DBX16
                MTM : 81UV0031FR
                you have everything you need at post #62, if it doesn't work you have another problem, or you don't write the bios correctly..
                https://www.badcaps.net/forum/showth...5-14api&page=4
                • Azrael29
                  • Mar 2023
                  • 3
                  • France
                  Yes, the problem is apparently elsewhere, I got the boot page once flashed with the bios you gave me.
                  Really amazing to have the same failure, the same month and the same year.
                  I would have a doubt about the welded ram? To see, I will continue my investigation.
                  Thanks for your answer.
                  • agusguffa
                    • Oct 2024
                    • 1
                    • argentina
                    Good evening, I have a Lenovo IdeaPad S145-14API and my PC has completely crashed (the Lenovo app downloaded and installed a BIOS) to the point where the screen went black. I tried to download the BIOS .exe from the official website and extract the .cap, put it on a formatted USB, then press fn + r and the disk light flashes without reading the USB. I don't have the old BIOS or anything or I don't know how to access it. Thanks.
                    PS: I'm using a translator, sorry if there are errors.
                    • hoaca388
                      Badcaps
                      • Jan 2022
                      • 12330
                      You have to buy an SPI programmer, there are many types, many prices.
                      For example: CH341A, this is the cheapest type.
                      https://www.youtube.com/results?sear...mer+how+to+use
                      Once you have the dump, post it here with the serial number.
                      • Ahmad Mukhtiar
                        • Feb 2025
                        • 3
                        • Pakistan
                        Hi there. Got this issue in 2025. how did you fix it? You have the same model as me? S145 14 API. I updated my bios from Lenovo site and after update it restarted and it's black screen now. No power led blinking, just a black screen and fans spin after some time. I tried doing hard reset and CMOS and everything but nothing worked. Can you tell me what you did to fix it?
                        • Ahmad Mukhtiar
                          • Feb 2025
                          • 3
                          • Pakistan
                          Also I don't know how to use this site. I thing I'm messing up the comments
                          • Ahmad Mukhtiar
                            • Feb 2025
                            • 3
                            • Pakistan
                            Hey did you fix it 😭? I did the same things you did and having this issue. Also I have done all the fixes you mentioned it didn't fix it.
                            Did you fix it?
                            • Pedro Ramírez
                              • Jul 2024
                              • 21
                              • Chile
                              Lenovo GS440 & GS540
                              Hello, could you help me with the BIOS update for my Lenovo Ideapad S145-14API?
                              Model Name: 81UV
                              S/N: PF3R8NS7
                              MTM: 81UV00ATCL
                              It turns on without video and the LED is blinking.
                              I've attached a BIOS backup.
                                • 21914
                                Model Name: 81UV
                                S/N: PF3R8NS7
                                MTM: 81UV00ATCL
                                Your backup isn`t good, make another one
                                • Pedro Ramírez
                                  • Jul 2024
                                  • 21
                                  • Chile
                                  Dear friend, I'm sorry. I may have attached the wrong backup or misread it. Here's the BIOS again. I'd be very grateful if you could help me recover it. 🙏
                                  • peste
                                    • Dec 2016
                                    • 13600
                                    • ROMANIA
                                    you have everything you need at post #62..
                                    https://www.badcaps.net/forum/troubl...5-14api&page=4
                                    • AHmad_Salal
                                      Need BIOS Dump/ROM for Lenovo Thinkstation p500
                                      by AHmad_Salal
                                      Hello all,
                                      I have a Lenovo Thinkstation P500 that is stuck at post with no display, it happened after I changed the memory timings in bios. I can not clear CMOS using the jumper on the motherboard, also tried re-flashing bios suing a USB stick but it also doesn't work. The only solution that I can think of right now is re-flashing the bios chip using an external programmer but the problem is that I don't have the bios dump of p500 for flashing externally and I don't know the location of bios chip. If someone can provide the bios dump and bios chip location it would be really helpful....
                                      11-28-2023, 05:28 AM
                                    • Ahari
                                      by Ahari
                                      I...
                                      08-13-2025, 06:12 AM
                                    • hyperwood
                                      [REQUEST] 2MB BIOS Dump for Lenovo NM-E471 Rev 2.0 (Winbond 25Q16JWSIQ Chip)
                                      by hyperwood
                                      Hi everyone,
                                      I’m looking for a 2 MB BIOS dump for a Lenovo IdeaPad 5 16ARH7H / Legion 5 with mainboard NM-E471 Rev. 2.0.
                                      The BIOS chip is a Winbond W25Q16FW (1.8V, 2MB) and it's completely unresponsive / bricked. I tried recovery via USB but no success. Now I want to reflash it externally using a CH341A programmer.
                                      I already found 32MB dumps (e.g. from Vinafix and Badcaps), but they are too large for the chip – and the last 2MB in those files are just FF FF FF....
                                      ✅ What I need:
                                      • A working 2MB BIOS dump
                                      • Matching NM-E471 Rev. 2.0, e.g. JY575
                                      06-25-2025, 02:28 PM
                                    • mkdj
                                      ASUS ZenBook UX480F : need help with cleaning the ME region of my BIOS dump
                                      by mkdj
                                      Dear all,
                                      I have a ASUS ZenBook UX480F with the following symptoms:
                                      I suspect it is a BIOS issue. So I decided to try to clean the ME region. I followed the guide on win-raid, and I believe I have done everything correctly. My problem is: when I open the outimage.bin in ME Analyzer, it says that it is Extracted, and not Region, Extracted as it should be. Is it normal, or did I do something not correctly? This is my first experience editing BIOS files.
                                      I would appreciate if someone could take time to explain the issue, so that I can learn. But I would...
                                      10-19-2025, 04:41 AM
                                    • Habble7
                                      I need a BIOS dump for the Samsung S49CG934SU monitor
                                      by Habble7
                                      The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
                                      Suspected Cause:
                                      I suspect the BIOS may have been corrupted during a power interruption while updating the firmware. The official website provides firmware updates, but they can only be installed via USB flash drive.
                                      Troubleshooting Attempts:
                                      05-22-2025, 07:28 AM
