WANTED: Teboview / TVW file format specification to write OpenBoardview decoder
  • inflex
    • Aug 2012
    • 545
    There's file format called "Teboview" with an extension .tvw, and I've noticed some Lenovo laptop boards are using it.
    I would like to write a decoder for the format for OpenBoardview but thus far, naturally, I've not found any useful specification on the internet. I've downloaded TeboView-ICT but unfortunately it also doesn't provide a lot of information about the technical information for each part/net/etc.
    I've decoded a moderate amount of the file format but I would *really* appreciate it if anyone could drop a file format spec accidentally
    There's at least one 3rd party program out there that can decode it that I know of but I'm not sure how they got the spec and it's unlikely they're going to share it.
    As an alternative, if anyone has some *small* TVW files they'd like to share, that might provide me a smaller search space to decode the puzzle.
    Most of the files I have now are 1MB+, something simpler more along the lines of 100K would be vastly preferred
    YouTube Repair Videos - https://www.youtube.com/user/19PLD73
    FlexBV BoardView software - Linux/OSX/Windows - http://pldaniels.com/flexbv
  • mon2
    • Dec 2019
    • 14657
    Re: WANTED: Teboview / TVW file format specification to write OpenBoardview decoder
    hi. attached are a few small filesize tvw files.
    Adding another boardviewer that can support the tvw format. Extract and launch the executable from within the same folder as it makes use of the dll files.
    https://we.tl/t-e8KqK8jigX
    • inflex
      • Aug 2012
      • 545
      Many thanks for that ... definitely a nice improvement to only have 1/10th the volume of data to dig through.
      Hopefully I can decipher the trickery they're using (I'm sure there's a real reason for it).
      It would be great if we could find something like a simple 2-layer board with only a couple of components on it. Not sure how or who generates tvw files but if it's possible, creating very simple boards is often a good way to start the decoding process too.
      Many thanks again mon2.
        • 21838
        Can you post an example of what youve decoded already,what should we be looking for
        • inflex
          • Aug 2012
          • 545
          I've created a github project for this reverse-engineering task
          https://github.com/inflex/teboviewfomat
          • inflex
            • Aug 2012
            • 545
            ahem... I mean https://github.com/inflex/teboviewformat
            • mmu
              • Aug 2019
              • 28
              • France
              Oh, Pascal strings everywhere :-)
              Looking at the 3 example files, and counting strings with backslashes inside, it seems to me the 4th value in the header after all the strings should be the layer count.
              I started writing a python parser, not much else to see yet.
              • mmu
                • Aug 2019
                • 28
                • France
                Managed to get TeboView to run under WINE. But it's 5am so I should sleep some hours first.
                • inflex
                  • Aug 2012
                  • 545
                  You can also try running "Boardviewer" which can decode the tvw file format, and might be doing a more simplified decoding process
                  • mmu
                    • Aug 2019
                    • 28
                    • France
                    What's with this "nail" thing that's always -1 anyway?
                    • mmu
                      • Aug 2019
                      • 28
                      • France
                      I'll be pushing what I have here, not much for now.
                      • inflex
                        • Aug 2012
                        • 545
                        Thanks for that, would you be also able to comment with some sort of breakdown of the structure you're decoding in addition to the python decoder, ie;
                        headerformat:
                        bytes / length | description
                        I'll update it on my file format description text so you can get an idea of the format; that way at least if it's documented it's easier for everyone to implement in their own script/language
                        • inflex
                          • Aug 2012
                          • 545
                          Trying to write a format table for these types of very dynamic (length) structures is frustrating. I'll try write something with more clarity
                          • mmu
                            • Aug 2019
                            • 28
                            • France
                            Yeah it's just trying stuff out for now.
                            • inflex
                              • Aug 2012
                              • 545
                              I've updated the fileformat description document with what I'm trying to achieve
                              Code:
                              PART entry:
                              type/details	| description
                              string		part name
                              int32		bounding box minimum x
                              int32		bounding box minimum y
                              int32		bounding box max x
                              int32		bounding box max y
                              int32		center x
                              int32		center y
                              int32		rotation (degrees)
                              uint32		unknown (132)
                              uint32		unknown (0)
                              uint32		unknown (1417)
                              uint8		unknown (1)
                              string		metadata about part (100K etc)
                              int16		unknown
                              string		package name (case insensitive)
                              string		unknown, possible UID
                              uint32		unknown (0)
                              uint32		pincount
                              uint32		unknown (2)
                              PINS			Array of pins
                              PIN entry:
                              uint32		networkID/map entry
                              uint32		unknown (0)
                              uint32		integer pin index (1-based, ie, 1, 2, 3...n)
                              string		pin name (1, 2, 3 etc for small parts, or AA42, B24 etc for BGA)
                              uint32		unknown (0)
                              • mmu
                                • Aug 2019
                                • 28
                                • France
                                Looking at the SOLDERMASK_TOP layer, the first part is actually a shape dictionary, with bounds and other things like radius, then there must be a list of them with the coordinates, since some shapes are identical.
                                • mmu
                                  • Aug 2019
                                  • 28
                                  • France
                                  For some reason Boardviewer complains it doesn't have Mono despite mono-complete being installed…
                                  • mon2
                                    • Dec 2019
                                    • 14657
                                    @mmu, try this Boardviewer:
                                    https://we.tl/t-Gs3ZMzhbWY
                                      • 21838
                                      It is in dot net. Theres a good app for windows called dotPEEK that might help to decompile part of it
                                      • mmu
                                        • Aug 2019
                                        • 28
                                        • France
                                        Thanks, this one runs, but doesn't help much.
                                        The decompiled version doesn't have much info, just tons of hex :-)
                                        • ahmedtou
                                          HOW CAN I UPDATE HL-DT-ST BD-RE GGW-H20N XA02
                                          by ahmedtou
                                          Hi everyone,
                                          help me please
                                          I have an HL-DT-ST BD-RE GGW-H20N with ROM version: XA02.
                                          When I tried to burn a 25GB Blu-ray disc using ImgBurn, I got an error.
                                          I will share all the details with you, including the disc information.
                                          Code:
                                          HL-DT-ST BD-RE  GGW-H20N XA02 (ATA)
                                          Current Profile: BD-R
                                          Disc Information:
                                          Status: Empty
                                          State of Last Session: Empty
                                          Erasable: No
                                          Free Sectors: 12,219,392
                                          Free Space: 25,025,314,816 bytes
                                          Free Time: 2715:27:17 (MM:SS:FF)
                                          Next
                                          08-27-2025, 08:49 AM
                                        • m1ch43lzm
                                          Notice to users of XGecu TL866II Plus / T48 / T56 / T76 programmers regarding BIOS backup file size
                                          by m1ch43lzm
                                          Hi everyone
                                          I noticed on the Xgpro software the BIOS backup files have extra bytes at the end when reading some chips, this is because the Xgpro software also reads the OTP region of those flash chips, and by default will append that region to the saved file
                                          Programmer models: XGecu TL866II Plus / T48 / T56 / T76
                                          Example: GD25LQ128D (1.8V), IC size is listed as 0x1000000 Bytes (16777216 bytes) + 0xC00 bytes, those extra 0xC00 bytes will be appended to the end of the saved file by default, resulting in a file size of 16780288 bytes
                                          There's also an extra OTP Secu.R...
                                          09-06-2025, 05:47 PM
                                        • to5it0
                                          Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e 2H1703-27220F Rev. A Marked as U2501 on the motherboard.
                                          by to5it0
                                          Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
                                          I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
                                          This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
                                          I have opened the laptop and identified the main BIOS chip...
                                          Yesterday, 01:35 AM
                                        • testaccgta
                                          Unable to verify IC or write/erase/flash BIOS file to XMC QH128AHIG SPI chip using NeoProgrammer/AsProgrammer
                                          by testaccgta
                                          Hi, everyone!
                                          I've recently acquired two brand new SPI chips to replace the one currently in my Acer A514-54G laptop MB (FH5AT LA-K092P). The reason why I'm replacing the current SPI chip is because I had some difficulties with a third-party IT assistant who pretty much lacked the soldering skills and ended up destroying the current SPI chip soldered to my MB from factory.
                                          I've decided to do this on my own because I spent the past month or so learning some soldering skills and BIOS modding through Badcaps and WinRaid forums, hence the attempt. I've also chosen to buy...
                                          09-01-2024, 08:24 PM
                                        • Forest79
                                          Lenovo ThinkStation P520 BIOS file needed
                                          by Forest79
                                          I got a Lenovo ThinkStation P520 (Type 30BF) from a friend, asking me for a repair. Windows 11 offered a firmware upgrade as an optional update, and it failed.
                                          The emergency flash procedure from the hardware manual has also failed. So, I asked an acquaintance with better skills to flash the BIOS directly.
                                          However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...
                                          07-23-2023, 07:39 AM
