Troubleshooting B&W Original Powersupply
  • Delirious
    • Sep 2016
    • 29
    • Norway
    Hello all,
    I just registered on this forum and hope that someone might be able to help me. I am trying to repair an older B&W Zeppelin for my parents. The status light is blinking red which according to B&W means that it need a repair. I searched a little bit around the internet and the power supply of this product seems to be a common problem.
    I decided to open it up and take out the power supply. The first thing I noticed was that all the caps seems to be of good quality. Rubycon on the dc side and Panasonic on the ac side. (Excuse my terminology I am very much a beginner here).
    However one of the caps a rubycon 2200 uF 16 VDC seems to slightly be bulging. Also there seems to be several burned spots on the backside of the pcb.
    So as I see it there are two options:
    - Replace some caps?
    - Replace the power supply board for a new one (expensive)
    Replacing the whole power supply will be quite expensive however might be worth it if this is where the fault lies. But how sure can I be that it is the psu? Also I have never replaced caps before at all so I am very much a beginner. Please keep that in mind.
    I have attached some pictures of the board. Any help will be appreciated. The name and make of the psu is Abletec ALP0050-0000-H. Specs: +25V max 1A continuous 2.2A FTC/+5V max 1.5A continuous.
    • 31163
    Re: Troubleshooting B&W Original Powersupply
    nothing is burned, the brown is flux.
    that cap top-right is bad, as you dont have an esr meter, yuo may as well change the whole group of 4 to be sure.
    what exactly do they say on them?
    • Khron
      • Sep 2006
      • 1350
      • Finland
      Going by the just-visible markings, i'd say that bulged(?) cap is a Rubycon ZL(H?), 2200u / 16v.
      The bigger cap on the bottom right is a ZL 1000u / 35v, so it's a safe-enough bet the suspect one's a ZL as well.
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8297
        PSU is still in a good shape. Nothing burnt, but one cap (top right) is bad.
        x2 on stj's comment.
        • Delirious
          • Sep 2016
          • 29
          • Norway
          Thank you all. This is really good to know. I guess it is worth it to replace the capacitors. How confident can I be that the capacitors are the problem here?
          Capacitors:
          Top right (bulged) - Rubycon ZLH 2200 uF 16 VDC
          Middle one left - Rubycon XYG 470 uF 16 VDC
          Middle one right - Rubycon ZLH 220 uF 35 VDC
          Bottom right - Rubycon ZL 1000 uF 35 VDC
          Is new Rubycon caps a good replacement? They are easily available for me. Panasonic is also possible I think.
          Also what is the white liquid? I am thinking it is thermal paste. If so can I replace it with thermal paste used for vga and cpu coolers? Or is there a better type to use.
          Also how can you be so sure the top right cap is bad? Just curious. This is very helpful for me.
            • 31163
            right, lots of questions.
            rubycon is good, they only really fail from heat.
            make sure you use the same series (ZLH, YXG etc.)
            white stuff is nasty silicon grease, clean it off and use cpu cooler paste if you want - it will do the job better, but it's hardly critical.
            caps should have a perfectly flat top, if it's slightly domed them the chemical inside has produced gas and created pressure.
            sometimes instead of the top doming and then eventually bursting, the pressure forces the liquid out around the legs btw.
            • Delirious
              • Sep 2016
              • 29
              • Norway
              Thanks!
              So are you saying I should use lets say Rubycon ZLH for all the caps I replace?
              The reason I asked about the silicon grease was because I managed to remove quite a bit off it when removing and handling the board. Should I maybe add more?
              Any point in replacing the Panasonic caps?
                At least your version uses RUBYCON instead of the crappy caps.
                https://www.badcaps.net/forum/showth...ighlight=B%26W
                  • 31163
                  Originally posted by Delirious View Post
                  Thanks!
                  no, i meant match them all.
                  i just wonder if it matters because they used all different types.
                  if it's not important then i would just stuff it full of panasonic FR series.
                  • Delirious
                    • Sep 2016
                    • 29
                    • Norway
                    Would it be wise to replace the two 47 uF 400 VDC capacitors on the AC side as well?
                    Budm: Well I guess I got quite lucky compared to you.
                      • 31163
                      usually not needed.
                      • Delirious
                        • Sep 2016
                        • 29
                        • Norway
                        Thanks I will go with the Panasonic FR as you recommended.
                        • philo
                          • Oct 2015
                          • 14
                          • Argentina
                          Panasonic capacitors are part of the top greatest capacitors manufacturers along with Nippon Chelmicon, Rubycon, Nichicon, etc.
                          • andy007007
                            • Dec 2016
                            • 1
                            • United Kingdom
                            I have the red light flashing, took mine apart and can't see any swollen damaged chips caps anywhere. Help
                            • Hotdog
                              • May 2018
                              • 1
                              • Denmark
                              Hi Delirious
                              What actually was wrong. you wrote in your latest post that you did fix it.
                              Thx :-)
                              • exee
                                • Aug 2019
                                • 1
                                Wow! Using this thread and the iFixit guides https://www.ifixit.com/Wiki/How_to_R...f_the_Zeppelin and https://www.ifixit.com/Guide/How+to+...Zeppelin/55158, I was able to replace the 2200uf 16V and 470uF 16V Samxon caps (whose tops were inflated and didn't test out) with Panasonic FRs from Mouser and it is working. I had a lot of trouble desoldering the caps and in the process destroyed the solder pads, so I didn't think I was able to solder the new ones in well, but I put it back together and the Zeppelin is working so I must have managed it! I have not been able to get the covers back on completely... For anyone else who tries this, be careful to desolder without destroying the solder pad (wick worked better for me than pump) and make sure you note the polarity and the stripe on the cap so that you get the new one in correctly. If anyone has any advice on how to get the covers to snap into place, I'd appreciate it. Thanks to all (Delirious, sti, Khron, Capleaker, budm, phil - all of whom posted helpful info).
                                • granted
                                  • Jan 2020
                                  • 2
                                  Great thread! I'm also repairing my Zeppelin and in my case the Rubycon 2200uf 16V capacitor was bulging and the T-fuse had popped.
                                  And the white silicone whatever will be replaced!
                                  • volcanotop
                                    • Feb 2020
                                    • 2
                                    • United Kingdom
                                    Good thread. Very grateful to find this. I've got an original B&W zeppelin with the red flashing light problem. it went back to B&W once in ~2014 for a free fix under warranty. But the problem has resurfaced. Maybe bad/cheap components? or maybe a poor design. I don't know. it you look on ebay there are dozens of broken Zeppelin listed.
                                    If anyone else follows this path. As of emails I has with B&W in Feb 2020 they no longer offer support for the original Zeppelin. (previously there was a £80 B&W repair service as i understand).
                                    So its a DIY fix or the Zeppelin goes in the bin.
                                    When it works the sound from the Zeppelin is FANTASTIC. So I've ordered some capacitors and solder and will give the fix a try and hope my soldering skills are up to the job.
                                      • 31163
                                      they probably shouldnt of named it after something that went up in flames!
                                      • volcanotop
                                        • Feb 2020
                                        • 2
                                        • United Kingdom
                                        Which are the suspect caps here? Not as obvious bulging as id have expected.
                                        The two small ones between the two larger?
                                          Acer Extensa EX2540-56BF + PowerCube Original Notebook 15 Specification for Upgrade or Repair
                                          This specification for the Acer Extensa EX2540-56BF + PowerCube Original Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EX2540-56BF + PowerCube Original boardview and EX2540-56BF + PowerCube Original schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                                          09-06-2024, 08:16 AM
                                        • m1ch43lzm
                                          by m1ch43lzm
                                          05-12-2025, 08:37 PM
                                        • harp
                                          can fanless heatsink replace poor original on RX26PG2
                                          by harp
                                          I have RX26PG2 graphic card with incomplete original heatsink, only aluminium plate... but in original solution it look like such bad termal design that I asking if is proper fanless heatsink be adequate replacement ot better... what you think? Till powering on, it is propper hot......
                                          06-25-2025, 10:56 AM
                                        • kingiii
                                          downloaded bios is smaller than the original bios dump
                                          by kingiii
                                          Can someone help me explain how to fix the original bios when downloaded and exacted bios is much smaller than the original one?
                                          Thank you very much
                                          06-07-2025, 04:21 PM
                                        • Capacitorial
                                          Powersupply has all the voltages - Monitor still no power
                                          by Capacitorial
                                          Hello guys,
                                          I have a Philips 240B7QPJEB. The monitor seems completely dead.
                                          I opened it and measured the voltages of the powersupply. I found that a mosfet was dead and replaced it.
                                          On the connector, that goes to the TCON board, all voltages 15-19V and 5V are present.
                                          The small connector on the left of the PSU has two cables with 18V and all the other have 0.2V. It connects on this small connector on the left ontop of the panel. I guess the backlight? Seens fine I guess.
                                          The weird thing is, that the Power LED is powered over the TCON board.
                                          On The TCON...
                                          12-28-2024, 02:12 PM
