Netgear routers are also affected
    They seem to have used Tolon caps in 2003 routers. Mine has a blown cap.
    Many others on the Netgear forum seem affected also!
    Lets hope we don't see a Boeing 737 on this list!
    cheers
    Steve
    Re: Netgear routers are also affected
    My Netgear FS605 switch has UCC (KMG) caps. Quite a pleasant surprise for me.
      The issues get real serious when you go down that avenue.
      Infrastructure, national security,it's mind boggling.
      At least my mind is boggled.
      Jim
        some netgear stuff is designed by ZyXEL which is a great company. unfortunately ZyXEL is also using crap in their products....Supacon, Hermei etc.
        Cisco is using Nichicon. but most of the time you dont need the complexity or expense of Cisco gear. talking about national security what about the cisco IOS vulnerability that was exposed a few months back. would find a lot of cisco routers in government organisations.
        i see lots of companies trying for entrance to the enterprise market, LevelOne, ZyXEL, Dlink, Netgear etc. do they thing they will gain a position with crap caps?
          When I see smoke coming out of my local ATM machine, I'll be be very upset.
          Jim
            havent you seen pics of atm machines or airport announcement plasma screens GPF? i am waiting to see that live. most run on windows now.
              Isn't it funny that the almighty Mr. Gates seems to have more GPF's than most people,
              and always in front of everyone. LOL
              Jim
                Hmmm..have a dead router here at work...time to "look under the hood"...
                Ya'll think us folk from the country's real funny-like, dontcha?
                The opinions expressed above do not represent those of BADCAPS.NET or any of their affiliates.
                  about the gpf issue in atms: I once saw an ATM rebooting. Guess what OS it had: OS/2 Warp!!
                  The great capacitor showdown!
                    The amount of obsolete/legacy equipment still in use is amazing. My previous employer still used a 386-based DOS (5 or 6) system to run their conducted EMI test set-up in '04, and may still.
                    PeteS in CA
                      A bit OT but....No less than 6 months ago I was working for a big Aus retailer.
                      The Z/OS mainframe HMC (Hardware Master Console) was OS/2 Warp, on an equivalently old desktop.
                      It had a huge (sizewise) 9k modem always updating IBM with the status.
                      For those that don't know, if you loose both your HMC's you are in deep shizen.
                      Wish I looked at the caps in it back then.
                      All master consoles were from the early 90's, and their RSX controllers ran on old XT type servers running DOS5.? frontend for switching systems.
                      All since outsourced and shipped to CSC!
                        I used to have a Netgear 8-port hub, but that was replaced with a Billion ADSL Modem/Firewall Router, which contained Teapo SEK series and one Hermei HV series (3300uF 25V) unit; none of them were bulging since the modem was working for two years.
                        When I do find my Netgear 8-port hub, I will keep you updated.
                        (I cannot find anything about 'Tolon' capacitors; do you mean 'Tocon' capacitors?) www.tocon.com.tw
                          I wouldn't be upset at all if it had dispensed a load of cash to me right before it burned up!!
                            I've seen Windows here once
                              Unfortunately, I may literally be the one that has the most BSODs!!!
                              Because of the misery the way some PC builds go.
                              Many people report having crashes with newly built PCs.
                              Thanks to flawed motherboards and faulty processor chips.
                              ASRock B550 PG Velocita
                              Ryzen 9 "Vermeer" 5900X
                              eVGA Supernova G3 750W
                              Alienware AW3423DWF OLED
                                Yes, Netgear DG824M routers from 2003 are definitely affected, due to Tocon 2200uF caps.
                                My father and I both have one. His has just started failing to sync with the ADSL line, and has a classic bulging cap.
                                Mine was not used for over a year, so has had only about 18months usage. No damage evident so far on that one, but I have noticed an increasing number of disconnects.
                                Andy
                                  can you get a pic?
                                  are you going to recap it yourself?
                                  actually hubs/switches/routers are quite easy to recap. much easier than motherboards.
                                    My dad's Netgear router (not DG824M) that was bought in the year 2005 (it's not that old) has Teapo capacitors. They haven't failed yet.
                                    My gaming PC:
                                    AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
                                    ASUS M4A77TD AMD 770 AM3 Motherboard
                                    PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
                                    G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
                                    TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
                                    WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
                                    ASUS Xonar DG 5.1 Channel PCI sound card
                                    Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
                                    Antec Three Hundred Mid-Tower Case
                                    Microsoft Windows 10 Pro 64-bit
                                    Microsoft Windows 7 Ultimate SP1 64-bit
                                      http://forum1.netgear.com/support/vi...ight=capacitor
                                      picture of my blown cap
                                        Poked apart a DG834GT to add a serial console, it has TEAPO caps... There is also one Chemicon cap...
