Go Back   Badcaps Forums > General Topics > General Capacitor Questions & Issues
Old 03-10-2010, 01:19 PM   #121
kgordon
Default Re: List of Bad Cap Manufacturers
Ltec
Gold script Ltec enclosed in oblong circle. Gold lettering for values. Caps are green with gold negative-post stripe. Cross-shaped vent. 1500 uF at 6.3 V. Two each in two different no-name 3DF-FX5200TV video card. ALL bulged or leaking.
All other caps, which appear to be OK, are also Ltec. mid-sized 470uF at 6.3 are dark blue with white or light-gray lettering and stripe, small ones, 100 uF, 16 V, 105oC are black with gold lettering and stripe.
kgordon is offline   Reply With Quote
Old 03-15-2010, 02:35 AM   #122
Oerg866
Originally Posted by bambino
Nichilon(Fake Nichicon)
OK: Bad Cheap Cap Copy of a brand that's bad cheap already? How desperate
Oerg866 is offline   Reply With Quote
Old 03-15-2010, 03:45 AM   #123
370forlife
Large Marge
370forlife's Avatar
City & State: Kalamazoo, MI
My Country: United States
Line Voltage: 0-120VAC 60Hz
I'm a: Hobbyist Tech
If nichicon is bad for HM/HN, then United Chemi-con is bad for KZE and KZG.
Originally Posted by JFK
The American, by nature, is optimistic. He is experimental, an inventor and a builder who builds best when called upon to build greatly
370forlife is offline   Reply With Quote
Old 03-15-2010, 04:46 AM   #124
PCBONEZ
Grumpy Old Fart
PCBONEZ's Avatar
City & State: Phoenix, AZ
Line Voltage: 120V 60Hz
I've only seen one complaint about bad KZE in like the last 5 years.
Why do you keep running with that one?
Have you seen bad KZE?
Mann-Made Global Warming.
- Dr Seuss
PCBONEZ is offline   Reply With Quote
Old 03-15-2010, 07:01 AM   #125
370forlife
Large Marge
370forlife's Avatar
Ooops, I wasn't sure about KZE.
Old 03-16-2010, 07:13 PM   #126
PCBONEZ
Grumpy Old Fart
PCBONEZ's Avatar
It's KZG [for sure] and KZJ [maybe].
Not that many KZJ's around to fail so that one hard to say.
Old 03-17-2010, 04:38 PM   #127
Oerg866
KZG is bad? and I had them in my "good"-stash :/
Old 03-17-2010, 05:02 PM   #128
PCBONEZ
Grumpy Old Fart
PCBONEZ's Avatar
Yup
KZG have heat issues and will fail with no bloating.
Just search the forum, KZG problems are all over in here.
Old 03-17-2010, 05:22 PM   #129
Oerg866
Dang.
*goes trash all leftover KZG caps*
I just found out my local eletronics shop sells Panasonic. Horay
Old 05-09-2010, 07:27 PM   #130
larrymoencurly
larrymoencurly's Avatar
Are there any bad brands of polymer caps?
Who makes these polymers (BioStar G41V-M7 mobo) with the small "s" inside the large "C", and are they OK?
larrymoencurly is offline   Reply With Quote
Old 06-21-2010, 06:12 PM   #131
enduser
I just found another crap cap that can be added to the list. The name of this brand is "Lasting". What a play on words. If you try to locate any information on it using a search engine you will be flooded by "long lasting" capacitor stories. Very clever indeed.
enduser is offline   Reply With Quote
Old 06-22-2010, 03:00 AM   #132
paul_h
City & State: perth, australia
Originally Posted by willawake
Any post here will be deleted. Please post any update in "bad cap manufacturers - please post yours here". or start another thread.
So I gather this rule is no longer in effect?
Interesting that teapo and OST is on the list (which some major PSU suppliers use), but fcon is not, which is used by even cheaper PSU manufacturers.
IE antec for the the former, huntkey for the latter.
paul_h is offline   Reply With Quote
Old 06-22-2010, 04:38 AM   #133
Scenic
o.O
Scenic's Avatar
City & State: Duisburg
My Country: Germany
Line Voltage: 230VAC 50Hz
low(er)-end seasonics also use OST.
The USA have Barack Obama, Bob Hope, Stevie Wonder and Jonny Cash.
We have Angela Merkel, no hope, no wonder, no cash.
Scenic is offline   Reply With Quote
Old 07-23-2010, 05:08 PM   #134
valepkins1985
hello everyone.
valepkins1985 is offline   Reply With Quote
Old 08-09-2010, 02:07 PM   #135
krazykev64
you should add JENPO and S.Y. just came across a few in a dead standalone dvd recorder. jenpo's were bulging and the S.Y was leaking like a sieve
krazykev64 is offline   Reply With Quote
Old 08-14-2010, 06:46 PM   #136
bigcape
Not new at it!
City & State: Austin, TX.
Hey all where is the list of GOOD caps?
I have 15 "popped" Rubycon 6.3v 1500uF up through 6.3v 2200uF for a Dell 470
bigcape is offline   Reply With Quote
Old 08-14-2010, 07:16 PM   #137
japlytic
japlytic's Avatar
City & State: Rockhampton, Queensland, Australia
My Country: Australia
Line Voltage: 240VAC 50Hz
I'm a: Hobbyist
May we add JUNZL units to the bad list? I found one bulging in a set-top box.
japlytic is offline   Reply With Quote
Old 08-14-2010, 07:27 PM   #138
momaka
momaka's Avatar
City & State: VA (NoVA)
My Country: U.S.A.
Line Voltage: 120 VAC, 60 Hz
Here you go:
http://www.badcaps.net/forum/showthread.php?t=588
Rubycon are regarded as one of the best capacitors avaliable, along with Panasonic. Perhaps that Dell 470 has bad ventilation like some of the SFF and USFF Dells.
Old 08-14-2010, 08:03 PM   #139
bigcape
Not new at it!
Originally Posted by momaka View Post
Here you go:
Rubycon are regarded as one of the best capacitors avaliable......
Thank you momaka
So if these are of the "one of the best" then what would you replace them with? sure is gonna be some work!
Old 08-14-2010, 08:31 PM   #140
ratdude747
Black Sheep
ratdude747's Avatar
City & State: Madison, IN
Line Voltage: 120VAC 60Hz
Thank you momaka
yup. the 470 is a rebadged easybake. they will cook almost every good brand due to the heat.
you should poly mod it... start a new thread on it, post some cap values there, and we will teach you what to do tho fix that.
btw, mac g5's do that too (hence the poly kit). too hot to handle.
(Insert witty quote here)
ratdude747 is offline   Reply With Quote
