Neon C3298DVB stuck in standby
  • sienoki
    sienoki
    • Jan 2012
    • 314
    #61
    Re: Neon C3298DVB stuck in standby
    Originally posted by sienoki
    Fuse tested ok..do i black probe screw chassis n red probe power i pins on mainboard on continuity setting?
    Took the shield off & cant seem to find any info on the ic..thx
    What type of cystal is this as im gonna replace it & not sure what to get..thx
    https://www.badcaps.net/forum/attach...5&d=1345298168
      You would need a scope to debug the crystal. I'm in Uni from late September but you'll have to give me a couple of weeks to get settled. If you have any troublesome TVs left, let me know.
      • sienoki
        sienoki
        • Jan 2012
        • 314
        #63
        Ok fella catch up with u when u settled in..im stuck with this set now as i dont want to spend much more on it..thx
        If u help me i give u free bus travel
        • sienoki
          sienoki
          • Jan 2012
          • 314
          #64
          Im off 2 farnells tommoz 2 stock up on bits carnt i just get a 12.000mhz quartz crystal 1s used for IC & microprocessors Order Code:9712950 from farnells..they only cheap & easy 2 install..thx
          • sienoki
            sienoki
            • Jan 2012
            • 314
            #65
            Tom scoped this mainboard 4 me & found the new epprom wasnt working proper..so i probably got ripped off with a blank 1..anyways ive ordered another mainboard from EMOs..installed it & she fired right upBUT the mainbord must have been configured with a different panel..mines a samsung panel..my problem is i cant access service mode 2 see if i can change any panel settings..ive tried source 2580 but 2 no avail
            This is the remote i got with the set & looking on ebay its saying its an original so im stumped..thx
              Try this
              Select TV mode
              Press Menu or LCD Menu
              Enter 1147
              Press Menu or LCD Menu (optional)
              • sienoki
                sienoki
                • Jan 2012
                • 314
                #67
                Try this
                Select TV mode
                Enter 1147
                Source 2580 was the correct code..it had 2 be done when the tv was on & not in standby doh!..when in there i turned TI MODE off in the function section & all is good
                  Great, it's now fixed?
                  • sienoki
                    sienoki
                    • Jan 2012
                    • 314
                    #69
                    Its vestel inside so probably not for long..will just sell it on now & probably get what ive got in it bk
                      Neon isn't Vestel.
                      Doesn't mean they are any good though!
                      If I were keeping it I would re-cap the PSU.
                      • OHM SUPPLIES
                        • Feb 2013
                        • 7
                        Im a new member but I’d like to interject. Please do not short pins 5 & 6 out on Eeproms, espachally this type. (25x32v) unless you are aware of what you’re trying to do. On this IC it won’t work but will probably corrupt any info. in the ic (unless you know that the ic is already corrupted). A replacement ic would be a preferred option meaning you don’t have to buy the main board.
                        Regards
                        Andy
                          It is not an EEPROM. It is a serial flash for firmware.
                          On this device a 5-6 jump would not work because the idea behind jumpering 5-6 is that it will cause the micro to ignore the eeprom and go to default values.
                          Due to a lack of pull ups, 5-6 on this device would likely damage the processor due to excessive output current if continued for too long. The flash device itself would likely survive.
                          • OHM SUPPLIES
                            • Feb 2013
                            • 7
                            By shorting out pins 5 and 6 (clock and data) you are trying to blank the eeprom. On some designs of board, the micro will re-write this on switch on, on some the info. in the eeprom is needed for the set to work.
                            The ic is an eeprom, which is a very broad term, but has a different pin out than a 24cxx etc. The program contained in these is very specific to each model, so replacing it with the correct type is the best way to repair the set.
                            regards
                            Andy
                              I'll repeat. It's not an EEPROM. An EEPROM is a low density, byte-programmable device. A serial flash is only page programmable (down to nearest 512 byte or 4Kbyte typically.) Which means it's difficult to use it to store settings (to change one byte you must erase full page, then write back the page with the changed byte.) I learned this the hard way with a project of mine.
                              EEPROMs are typically used to store the user configurations like channels, previous input used, input labels, last settings etc. as well as service settings like panel make/model, hours used, region, etc. Serial flashes are typically used to store firmware (the TV's software.) The processor is dead without firmware. The firmware is the software for the TV - interface, processing, etc.
                              Sometimes the firmware can be fixed to e.g. having a DVD player or a certain panel. Other times it is generic across all models and the EEPROM changes those settings.
                              The 5-6 jump trick I know of only works on some older Samsung models -- it's probably a mere coincidence that tricks the microprocessor into booting. It's not directly erasing the EEPROM, though. When the TV sees the EEPROM cannot be read, it loads it with default values.
                              • multimeter
                                • Jan 2011
                                • 739
                                • united kingdom
                                #75
                                tom is right,they are serial flash chips,the same on the neon c2469f model (location u7),i did before think they were a eeprom but i was wrong.
                                there is someone selling them somewhere cant remember who,but is asking about 17 odd pounds for them plus postage etc !,bit of a rip off really.
                                ive got a load of winbond 24*32 chips coming from china and plan to program these,so if any one wants one for the 24" version let me know,i succesfully programed a new one i had with the firmware,tv fires up no problems. will prob just flog them for a fiver each ,lots better than 17 quid!
                                i will also do the c3298dvb series too when i get the firmware
                                fixed so far...376 lg lcd tv's,24 onn tv;s,24 panasonic lcd,16 jvc lcd,12 marshall jcm800 amps,refurb of various disco equipment lighting,old style disco decks ,and a flymo!
                                please let us know if everything works ok if your tv gets fixed, as it will be and aid for anyone else having the same problem and wishing to fix it.it would save people clogging up this site with topics that are duplicated,and can be found easily using the search function.,and taking up valuable space.enjoy your fixed tv!,hopefully!
                                  Yeah -- if I could get hold of the firmware, I would both upload them onto the internet for all to download, and I would sell chips for a nominal price. LOL, not 17 quid. multimeter, do you think you could send me a copy of that file to upload to tgohome.com/ServiceManuals?
                                  • multimeter
                                    • Jan 2011
                                    • 739
                                    • united kingdom
                                    #77
                                    tom i sent the .BIN file to you a while back for the c2469f model,about 4 months ago i think.
                                    i dont have the BIN file for the c3298dvb model as yet but still looking !
                                      Ah I've probably uploaded it already. I'll see if I can find any other .BINs.
                                      • multimeter
                                        • Jan 2011
                                        • 739
                                        • united kingdom
                                        #79
                                        there might be a chance that the c2469f .BIN file MIGHT work on the larger 32" model,by going into service menu and changing the screen size.
                                        i dont have a 32" model at the moment,one may come up soon,be interesting to see if it will work
                                        • flocko
                                          • Nov 2012
                                          • 1121
                                          • uk
                                          #80
                                          Hi I have just today got a soundwave C3298f stuck in standby.have checked it by disconnecting the Av board from the power board and with a resistor between 5v s/by and ps/on all the voltages come up,so i am thinking it could be the flash chip/ eeprom,could this be wiped and reprogramed,or is a new reprogramed chip needed.The other problem is i have no remote.
                                          • lepak06
                                            TV LED 4K Selecline 65S18 ( T.MS3458.U801) stuck in Standby mode
                                            by lepak06
                                            Hello
                                            I have an TV Led 4K Selecline 65s18 with mainboard T.MS3458.U801
                                            The TV is faulty with stuck in Standby RED LED. Can't power the TV.
                                            Before this problem , the TV stuck the picture with artefact , i unplug the AC cable and since the tv is stuck in standby .
                                            All voltage are OK on PSU and main board for regulator. I tried flash firmware 25Q64 with many dumps
                                            But the voltage on power button is 0.6V not 3.3V. When i press power button the voltage up to 0V. I tried to add 5V with Power Supply on 5V_STB and 3.3V on Power...
                                            01-12-2023, 01:43 AM
                                          • toty79
                                            Hisense LTDN50K220WSEU stuck in standby
                                            by toty79
                                            Hello to all friends of the forum and well found, here I am asking for your help and sorry for my translated English.
                                            As per Hisense tv title LTDN50K220WSEU stuck in standby
                                            PSU rsag.820.5687 HLL 4855WF
                                            Main rsag 7.820.5842
                                            I enclose the psu diagram, after the first routine checks I find myself with a regular standby voltage of 3.3v blue light on steady when the power button is pressed nothing happens, psu disassembled and bench checked ... forced ignition by sending a signal 3 , 3v on the SW and PWM2 pins the psu turns on and delivers all the voltages...
                                            05-01-2022, 04:39 PM
                                          • lego1234567
                                            LG 32LB1R - stuck in standby mode
                                            by lego1234567
                                            Hi. I have the following problem with my TV. After connecting to mains, the standby led (red) turns on, but TV is not responding to remote control or buttons on TV. After some measurements, I found out that +5 V standby voltage is present, but I dont have ON/OFF signal coming in to turn PSU on. It stays at zero volts. After looking at the schematic of the mainboard, I should get ON/OFF signal coming in at the R1402 resistor, but it stays around +3,5 V. So I removed it and I was able to turn on TV with buttons on TV, but not with remote control.
                                            What could be the problem ? Thanks...
                                            01-21-2024, 03:39 AM
                                          • Stunt
                                            Hp Laptop Stuck on Hp protected by hp sure start screen
                                            by Stunt
                                            Hi guys i've got an Hp laptop Zbook 17 g5 Stuck on Hp protected by hp sure start screen.
                                            I have tried almost every bios available on various platforms about this laptop but the problem is still the same.
                                            I even successfully build my own bios using the one from the Hp website but the problem the laptop still getting stuck there.
                                            Even if i try to press Esc key nothing happens. I tried f10 it doesn't go to bios still stuck there i just saw entering setup menu on the bottom left corner of the
                                            screen that's it and stuck there. I left it until the following day and i still...
                                            09-02-2025, 01:51 PM
                                          • Rusenga
                                            Samsung UA39EH5003R Stuck on standby
                                            by Rusenga
                                            Hi techs, I have a Samsung ua39eh5003r which switches on and then goes to standby. I have to wait for a day or two for the tv to switch on again, all the time it is stuck on standby. I have checked the voltages on the power supply board on both occasions when it is on and off and these are my findings:
                                            Connector CNM803:
                                            TV ON
                                            Pin1,3,4,5(Vamp),7(Vamp)- 12.6V; Pin2(PWM_DIM)- 0.96v; Pin6(BLU_ON/OFF)- 4.41v; Pin8,9,10- grnd; Pin11,12,13- 5.16v; Pin14(Power ON/OFF)- 3.3v
                                            TV OFF
                                            Pin1,3,4,5(Vamp),7(Vamp)- 12.6V; Pin2(PWM_DIM)- 0.06v; Pin6(BLU_ON/OFF)-...
                                            09-18-2021, 11:51 AM
