Lenovo L560 - bios PWD
  • majkel_27@o2.pl
    • Sep 2013
    • 26
    • konin
    #41
    Re: Lenovo L560 - bios PWD
    the original ec was dead
    • imranromi
      • Jan 2015
      • 1288
      • Pakistan
      #42
      This error reason i use patch file patch file work without error.Now you save old main bios?
      • majkel_27@o2.pl
        • Sep 2013
        • 26
        • konin
        #43
        I wrote ec from another disc and wrote down the old bios now is no password tpm is ok. I could turn it off but I got stuck on error 189 and 2201 uuid.
        maintrence saving does not help
        • holu00
          • May 2020
          • 9
          • Mexico
          #44
          Dear bad caps community!
          I could successfully read/write from my BIOS chip 25q128fvsq to a raspberry pi 3b+ and vice versa using a "8 pin SOIC8 Test Clip" and "6 x female to female jumper wires" (thank you "PA8600: Tech Videos and More").
          Unfortunately the provided unlocked bios dumps from mcplslg123 and dr_laptop05 did not work for me. As majkel_27@o2.pl wrote the fan was speeding up and there was a dark screen after flashing the bios chip and pressing the power button.
          What steps do I need to do in order to patch my original/backuped bios dump in order to get rid of the annoying supervisor password?
          Since I have 3 x lenovo L560 laptops I also plan to exchange the portion of the HEX difference with the other two laptops as soon as I have a working unlocked bios dump from the first laptop.
          Please help to save environmental resources...
          Many thanks in advance!
          Other sources:
          https://github.com/bibanon/Coreboot-...h-Raspberry-Pi
          https://tickett.wordpress.com/2018/0...ssword-part-2/
          https://www.badcaps.net/forum/showthread.php?t=63912
          • DrSnuggles
            • Dec 2021
            • 4
            Re: LENOVO BIOS AUTO-PATCHER for Supervisor Password Removal
            I have a L560 with SVP.
            Here is my unpatched and my patched bios:
            The Laptop Fan runs high for about 3 Seconds and then it turns itself off again with the patched bios.
            I tried pulling the hard drive off and put it on again. Also tried other ram. Anyone an Idea what I could try?
            Bios chip 25q128fvsq
            KBC Nuvoton NPCE388NA1DX
            Board LA-C421P rev 1.0
            just found my S/N FC-04KEZX
            • DrSnuggles
              • Dec 2021
              • 4
              I am not exactly sure if this is the right place but you people seem to have the same issue as me.
              There seems to be a tool called autopatcher that can be found here https://www.badcaps.net/forum/showthread.php?t=87588
              Some people claim that they successfully got rid of the SVP on a L560 in that thread but so far I have not been able to recreate that. I ordered a t48 since the ch341a is crappy even with the 3,3V mod and a whole bunch of bios chips. I hope the power will be sufficient to read the chip with a clamp, otherwise I will try thicker magnet wire and soldering.
              A good tip if you attempt this: use low melt solder. You can get mechanic x for around 12 bucks from china. Makes desoldering much safer for the laptop. Just be aware that you need more flux.
              I also found a few people on ebay selling chips or images of chips that are supposed to be able to unlock the L560 but somehow I think they just use the autopatcher and call it a day.
              There are a few questions I am asking myself
              a) is there an option to reverse engineer the actual password on the MEC/EC?
              b) can I just take a MEC and bios chip from a donor board or will this get issues with things like mac adresses?
              c) Is there some cheaper alternative to those svod programmers for the nuvoton chips now?
              • lamdy
                • Jul 2013
                • 11
                • Japan
                #47
                I can comfirm autopatcher is not working, and will destroy your notebook.
                I have a L560, it is working. I set the SVP, read BIOS, use autopatcher patcher the bios. write patched BIOS back, and it cannot power on.
                I reflash back the original BIOS, still not power on.
                I am not de-soldered BIOS CHIP, using onboard flash. this method works for L380/L390/T480s etc. but it failed for L560.
                NOW my L560 is dead.
                • karem adel
                  • Jan 2023
                  • 26
                  • United Arab Emirates
                  #48
                  l560
                  need patch
                  • volinakis
                    • Jan 2021
                    • 2827
                    • N/A
                    #49
                    because you didn't read properly your bios. this happens when you read it onboard instead desoldering. I unlocked several L560 without problem. The fact that writing back original bios dump you save it and not working should tell you that you didn't read it properly.
                    • volinakis
                      • Jan 2021
                      • 2827
                      • N/A
                      #50
                      Originally posted by karem adel
                      l560
                      need patch
                      [ HOW TO USE THE PATCH ]
                      STEP 1: Flash and replace current BIOS with the generated patch file
                      STEP 2: Boot the machine
                      STEP 3: Press ENTER/F1/etc. to enter BIOS settings
                      STEP 4: Enter any character when asked for Supervisor Password
                      STEP 5: Press enter when it shows Hardware ID
                      STEP 6: Press space bar 2x when asked
                      STEP 7: Turn off machine
                      STEP 8: Restore original BIOS
                      STEP 9: Reset BIOS settings to factory default
                      • karem adel
                        • Jan 2023
                        • 26
                        #51
                        My brother, I have another laptop, the same problem, this patch does not work with it
                        • karem adel
                          • Jan 2023
                          • 26
                          #52
                          • volinakis
                            • Jan 2021
                            • 2827
                            • N/A
                            #53
                            But it worked for laptop it was patched for? Of course it will not work for ANOTHER laptop, original bios has to be patched.
                            • karem adel
                              • Jan 2023
                              • 26
                              #54
                              Yes, it works with the laptop it's patched for...thank you
                              I have two others with the same problem
                              Other laptop same model L560
                              help me please
                              • volinakis
                                • Jan 2021
                                • 2827
                                • N/A
                                #55
                                help me please
                                post bios dumps.
                                • volinakis
                                  • Jan 2021
                                  • 2827
                                  • N/A
                                  #56
                                  now you have proof autopatcher is working if you read bios offboard. Problem IS NOT with autopatcher, is the way you made your bios dump.
                                  help me please
                                  • karem adel
                                    • Jan 2023
                                    • 26
                                    #57
                                    Another laptop BIOS password
                                    • volinakis
                                      • Jan 2021
                                      • 2827
                                      • N/A
                                      #58
                                      here, same steps as previous.
                                      • karem adel
                                        • Jan 2023
                                        • 26
                                        #59
                                        Another
                                        • volinakis
                                          • Jan 2021
                                          • 2827
                                          • N/A
                                          #60
                                          Another
                                          here. please consider donating few bucks in order to keep this forum alive, thank you!
                                          • lucaszmn
                                            Summary of BIOS Whitelist Removal Problem Lenovo Thinkpad T560
                                            by lucaszmn
                                            Problem:
                                            I am attempting to remove the WWAN card whitelist from my Lenovo ThinkPad T560.
                                            Initial Findings:
                                            • My current BIOS version is N1KET58W (1.45).
                                            • I have a CH341A programmer and have successfully created two full backups of my BIOS.
                                            • I have the ability to use command-line tools on a Linux machine.
                                            Troubleshooting Steps & Conclusions:
                                            • I attempted to use several automated and manual patching methods on my N1KET58W (1.45) BIOS, including using hex strings. These attempts all failed.
                                            • I concluded that the
                                            08-12-2025, 03:01 PM
                                          • Wahaz
                                            by Wahaz
                                            10-30-2023, 08:42 PM
                                          • grimacelord
                                            Lenovo Legion T5-26AMR5 Desktop - Corrupt BIOS
                                            by grimacelord
                                            Hello there.
                                            I am working on a Lenovo Legion T5-26AMR5 desktop that currently has a corrupt BIOS and I have been unsuccessful thus far in trying to fix it myself.
                                            History:
                                            1. This computer came to me initially with an error message that said "BiInitializeLibrary failed 0xc0000001" or "0135 fan error". It would always be one of the two errors. It should be noted that when it produced the fan error, there was no physical problem with the fans. They were all spinning just fine.
                                            I searched for this error online and discovered...
                                            03-15-2023, 03:29 PM
                                          • jendkkd jeje
                                            Lenovo IdeaPad 330 15-AST 81D6 BIOS Recovery
                                            by jendkkd jeje
                                            So a couple of years ago i got a bios update through Lenovo Vantage, so i installed it and bricked my whole BIOS, so i couldn't fix it so i put that ideapad in a box, 3 years later i found that one PC and want to recover it to switch from a 2014 hp laptop to this one.
                                            I found a method to recover the BIOS of many lenovo laptops tha consists in pluging in a USB Flash with the BIOS files and power on the laptop with Fn + R keys pressed until fans go loud and start beeping loud, but nothing worked, so i think filename is wrong, i tried naming the bios file as 07WW.BIN, BIOS.BIN, BIOS.fd,...
                                            10-11-2024, 03:12 PM
                                          • 1g0r
                                            Lenovo ThinkPad L15 G3 Bios 1 IC conductor track
                                            by 1g0r
                                            First, the data in brief:
                                            Manufacturer: Lenovo
                                            Model: ThinkPad L15 G3 21C3-0016GE
                                            motherboard: LG4 LT5 ADL RT UMA MB 8L - 448.0PZ26.0011
                                            IC Bios 1: MX77L25650F
                                            IC Bios 2​: MX25L25673G
                                            EC Chip: NPCX997KAABX
                                            So far I've been a silent reader, but now I need your help
                                            I bought a laptop. The seller said the bios was locked. I was looking for a way to remove this ban.
                                            I then got the CH341A and pulled the corresponding files from here https://www.badcaps.net/forum/troubl...evices-and-ele...
                                            The laptop was brought in with a BIOS problem and a password. After reading the dump, the information was damaged. I ask for help in the BIOS with a clean ME region. Motherboard 213035-1. Serial number: PW+04e998, Type number: 21c3-0016ge
                                            01-18-2025, 02:39 AM
