Lenovo L560 - bios PWD
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Lenovo L560 - bios PWD
    Check for resistance to gnd on 3 and 5v coil to begin with. 0V at kbc means probably your 3v rail is shorted somewhere. Can be 'coz of KBC but there can be "N" number of reasons for 3v rail to pulled down.
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      Originally posted by magneh
      Do you know where I could by some programmed KBC's for this particular model?
      Once again, thanks for your time!
      Cheers
      I never buyed them online as i have all the tools. So cant say but try searching on ebay.
      • magneh
        • Apr 2014
        • 585
        • Portugal
        Yes, but the thing here is that the 2 laptops I flashed with the PWD clear dump, they both behave the same way.
        No power at all.
        In one of them I rolled back to original dump, and still the same.
        So its weird as I have the same problem with both. No power after bios programming.
        Im sure the 3v line is not shorted, as the diode mode measurements showed in BIOS chip IC pins.
        I will do some checks when Im at the office.
        • Pferd5
          • Mar 2018
          • 68
          which programmer do you use?
          Do you use a clip or desolder the chip?
          I made the observation that sometimes (with clip) some bytes aren't written correctly.
          I mainly used SkyPro II ... and from time to time TL866 II (should be better, but can't be used with clip)
          Try desolder the bios chip and check whats happen in this state and repgramm the chip with your old bios dump.
          • drgn997
            Banned
            • Dec 2011
            • 19
            I may be wrong, but customers have reported that some Lenovo ThinkPad models need bottom cover to be installed, otherwise bios chip won't get +3.3V... worth a try.
            • magneh
              • Apr 2014
              • 585
              • Portugal
              #26
              Try desolder the bios chip and check whats happen in this state and reprogram the chip with your old bios dump.
              Well finally back to these machines.
              I have 2 working L650 with bios locked.
              The 3.3V are not coming up after I de soldered the bios, re programmed with the dump posted here, and soldered it back.
              Since then machine is dead. No reaction at all. I can confirm the 3.3V are not present in pin 8 of the bios.
              I use a SP8-a programmer with the 8 pin adapter for the bios.
              Used directly on the programmer.
              I can confirm there is no damage on the bios pads or surrounding area/components.
              I did the same thing to a second L560. Same result. machine dead since then. Very weird...
              Ive measured the Bios pins in diode mode of a working and a non working L560.
              I can see considerable differences in certain pins.
              pin working L560 L560 KO L560 KO without
              bios chip
              1 .693 .654 .586
              2 .560 .544 .542
              3 .736 .580 .624
              4 0 0 0
              5 .727 .610 .631
              6 .590 .565 .631
              7 .727 .598 .626
              8 .357 .363 .360
              But even seeing this, this wont justify the 3.3V to not be present AFAIK...
              Seeing this, what would you more experienced guys do?
              Thanks for any inputs
              • magneh
                • Apr 2014
                • 585
                • Portugal
                #27
                wow
                And they are completely right...theres a little switch on the board that the cover push on when in place... some reset signal that prevents 3.3V on the board.
                So just need to put some tape on it and I have 3.3V on the bios, and both laptops booting up, still with Bios PWD.
                I feel like a donkey right now
                • magneh
                  • Apr 2014
                  • 585
                  • Portugal
                  #28
                  Has anyone been able to unlock/reprogram one L560 with bios PWD
                  Ive reprogrammed BIOS, KBC and still have bios locked
                  When the PC boots up the first time after bios flash I get this error
                  0183: Bad CRC of Security Settings in EFI Variable.
                  Could it be the security chip preventing the unlock??
                  Jeezz what a nightmare
                  • medinfo
                    • May 2016
                    • 328
                    • Morocco
                    #29
                    Thinkpad L560 Bios Password
                    Thinkpad L560 Bios Password ?!!
                    Possible to unlock it from eeprom ??
                    • digitalpc
                      • Jun 2016
                      • 305
                      • .DLL
                      #30
                      Re: Thinkpad L560 Bios Password
                      SupervisorPassword?
                      I usually use this method in ThinkPad, try it too.
                      https://www.youtube.com/watch?v=FW-RLkzjAS8
                      • foulou0238
                        • Mar 2014
                        • 109
                        • France
                        #31
                        hello
                        try flash ur motherboard with this dump and report result please
                        • majkel_27@o2.pl
                          • Sep 2013
                          • 26
                          • konin
                          #32
                          Hey, I checked your bios. Unfortunately, fan, high speed and dark screen, I have a clean ec. and factory bios but unfortunately tpm remains MFG mode and error 189 uuid error. at the original bios tpm is normal, so it probably remains to read the original password from the bios file. Any ideas?
                          • majkel_27@o2.pl
                            • Sep 2013
                            • 26
                            • konin
                            #33
                            Here is a clean factory ec. and a clean factory bios. and bios with a password can someone help put it together so that it works properly.
                            • imranromi
                              • Jan 2015
                              • 1288
                              • Pakistan
                              #34
                              Password not store in bios this Model.Buy patch or if have i/o programm then you can.
                              • majkel_27@o2.pl
                                • Sep 2013
                                • 26
                                • konin
                                #35
                                Uploaded clean Bios, clean EC, replaced TPM. There is no password but there are errors and tpm is in MFG mode. I play bios with password, TPM is normal still error 189, but asks for generating uuid, but this I can not do because bios the default is in the uefi mode, do you know where else the password can be stored?you mean Maintenance Diskette
                                • imranromi
                                  • Jan 2015
                                  • 1288
                                  • Pakistan
                                  #36
                                  Password in MEC.../ITE/ENE/Nuvoton Which chip have this board?
                                  • majkel_27@o2.pl
                                    • Sep 2013
                                    • 26
                                    • konin
                                    #37
                                    novoton npce388
                                    the new clean feed is erased and uploaded
                                    • imranromi
                                      • Jan 2015
                                      • 1288
                                      • Pakistan
                                      #38
                                      Yes use Maintenance Diskette if support your model
                                      • majkel_27@o2.pl
                                        • Sep 2013
                                        • 26
                                        • konin
                                        #39
                                        I've tried unfortunately
                                        • imranromi
                                          • Jan 2015
                                          • 1288
                                          • Pakistan
                                          #40
                                          Try programm back original Ec check what results lock or unlock?
                                          • Wahaz
                                            by Wahaz
                                            10-30-2023, 08:42 PM
                                          • grimacelord
                                            by grimacelord
                                            Hello there.
                                            History:
                                            03-15-2023, 03:29 PM
                                          • jendkkd jeje
                                            Lenovo IdeaPad 330 15-AST 81D6 BIOS Recovery
                                            by jendkkd jeje
                                            So a couple of years ago i got a bios update through Lenovo Vantage, so i installed it and bricked my whole BIOS, so i couldn't fix it so i put that ideapad in a box, 3 years later i found that one PC and want to recover it to switch from a 2014 hp laptop to this one.
                                            I found a method to recover the BIOS of many lenovo laptops tha consists in pluging in a USB Flash with the BIOS files and power on the laptop with Fn + R keys pressed until fans go loud and start beeping loud, but nothing worked, so i think filename is wrong, i tried naming the bios file as 07WW.BIN, BIOS.BIN, BIOS.fd,...
                                            10-11-2024, 03:12 PM
                                          • mximiliandz
                                            help bios lenovo ideapad s145-14iil type 81w6
                                            by mximiliandz
                                            Good morning, gentlemen, I hope you can help me with my laptop, I told you that I saved it about 2 years ago because it wouldn't turn on, now I have a ch341a programmer, I made a backup of the bios, I flashed an original downloaded from lenovo and it started, but it turned off after a few minutes, I entered the bios configuration and the brand, model, serial number, windows serial number, etc. did not appear, I request your help, I did everything I found in the forum but I could not solve it, also now it won't start again, it turns on but the fan does not turn, I will share all the information...
                                            06-20-2025, 06:50 AM
                                          • 1g0r
                                            Lenovo ThinkPad L15 G3 Bios 1 IC conductor track
                                            by 1g0r
                                            First, the data in brief:
                                            Manufacturer: Lenovo
                                            Model: ThinkPad L15 G3 21C3-0016GE
                                            motherboard: LG4 LT5 ADL RT UMA MB 8L - 448.0PZ26.0011
                                            IC Bios 1: MX77L25650F
                                            IC Bios 2​: MX25L25673G
                                            EC Chip: NPCX997KAABX
                                            So far I've been a silent reader, but now I need your help
                                            I bought a laptop. The seller said the bios was locked. I was looking for a way to remove this ban.
                                            I then got the CH341A and pulled the corresponding files from here https://www.badcaps.net/forum/troubl...evices-and-ele...
                                            The laptop was brought in with a BIOS problem and a password. After reading the dump, the information was damaged. I ask for help in the BIOS with a clean ME region. Motherboard 213035-1. Serial number: PW+04e998, Type number: 21c3-0016ge
                                            01-18-2025, 02:39 AM
