Toshiba 46L5200U flash logo on screen when turn on
  • Nick's Tvs
    • Jan 2014
    • 621
    Re: Toshiba 46L5200U flash logo on screen when turn on
    Diah,
    The 94 v is actually not a voltage rating, but a heat rating. I spoke with a tech from Digi key about this a while back about what those numbers meant, and that's what he told me. Makes sense because so far 100% of all my LED strips have a 94v rating on them. Doesn't matter how many LED's are on the strip and how many groups there are.
    5 dots = 4 groups 1 ground? If it was 5 groups and 2 grounds, how would it be shown? Or should I just auto assume 1 ground every time?
    • Diah
      • Feb 2013
      • 6614
      he may correct if its heat rating , but this value you can read it also printed at some PSU PL section. any way..
      about 5 dots, it explained the socket wiring, 5 wiring, 4 go separated to each group, and 1 connected to all first Diode of the groups.
      if 5 groups and 2 grounds the print and strips will be separated
        Digikey is correct! not may be. I have to put that marking on my PCBs I designed as the safety compliance requirement.
        http://www.we-online.com/web/en/leit..._Kennung_1.php
        https://cdn.badcaps-static.com/pdfs/...51607e408d.pdf
        Yep, 94V-* is the UL Flammability standard for the PCB, nothing to do what so ever with the LED Voltage.
        Did you verify that the 7030 Dual LED is 6V (connected internally in series) type or 3V (connected internally in parallel) type?
        • Diah
          • Feb 2013
          • 6614
          with you.. learn to be polite and respect other, to earn other respect.
          okay, you are the F::K professor over here... did your ass calm now.
          kids.
            kids.
            Crying because you are wrong again? POOR BABY IS CRYING!
            94V for 94 Volt LOL! and you are the professional?
            Keep giving out wrong information LOL! WTF INDEED.
              kids.
              Respect?
              Remember this?
              i don't know why you posting here some things Fishy, 400mA are the real specif action of this SMT LED, why it should fail , or you just use here to drive other bought from yours shops,,
              end of the subjects what i wrote here i did tested and used and passed for many years. so don't bother others and lez people go with less cost.
              specification :
              3528 2835 SMD LED 1W LG Cool White
              Model Number: LATWT470RELZK
              Brand Name: LG
              Forward Current:400mA
              lumens: 100LM
              Forward Voltage:3.05-3.65V
              • Diah
                • Feb 2013
                • 6614
                you F..K professor , i suggest you to read and learn Delta PSU training program then you get know what others from wise people talking over here.
                  Poor BABY IS STILL CRYING! PROFESSIONAL?????? REALLY?
                    • 31294
                      Did you learn that from that training? if the power supply is rated at 4A if then you should have 4A and nothing to do with the load?
                      the 12 Volts should have 4A, any less than this value it will be delay to start.. and make noise at picture. wasting time and spend penny on caps better than starting with panel which it may broken at any little human mistake.
                      https://www.badcaps.net/forum/showthread.php?t=52876
                      and at the end, it is the panel problem, even 16Yr reece knows that.
                      • Nick's Tvs
                        • Jan 2014
                        • 621
                        Doesn't matter who is right and wrong, we are all here to help one another and learn from our mistakes. Send private messages if you are going to complain.
                        DIAH,
                        Thank you for your help, you have helped me better understand LED strips
                        Budm,
                        Thank you for helping with the correction on a mistake made earlier and also for those links.
                        As nerdy as it is, I look forward to reading it ha.
                        Thank you to everyone
                        • Diah
                          • Feb 2013
                          • 6614
                          one ask ( Did you verify that the 7030 Dual LED is 6V (connected internally in series) type or 3V (connected internally in parallel) type? )
                          exp:
                          if the groups had 16 LEDs , they are 6 volts in general
                          if the group contain 27-28 Led then 3V.
                            DIAH,
                            Budm,
                            Post 23: I provide the info about UL 94V and the A HOLE got pissed and talking about respect, WTF indeed.
                            Post 24:
                            A HOLE "WTF with you.. learn to be polite and respect other, to earn other respect.
                            WTF kids"
                            • ReeceyBurger123
                              Never Give Up !
                              • May 2014
                              • 7325
                              • Britain
                              #34
                              Lol you two stop it haha
                                Well, it looks to me if I give an answer and not even mention the A HOLE name, he will follow my answer with his stupid remark like in post 24, so basically I should not answer questions in any thread if the A HOLE is in the thread.
                                • paulstef
                                  • Dec 2013
                                  • 724
                                  Had the exact same TV with one burnt LED.
                                  If anybody wonders how to separate LED strip from heatsink, it is not glued (as I assumed) , just slide the LED strip in the direction of the connector, it`s gonna come off. Also, peak LED current is about 150mA, I would recommend to lower this current or it`s gonna happen again very soon with other LEDs. The current can be lowered by changing the resistor values of the three 4R7 resistors that are in parallel and then in series of the source of each of the 4 MOSFETs on the ssl460_3e1b driver board. Just remove one of the resistors and peak current will drop to 100mA or change them altogether to a convenient (higher) value.
                                  • Ihandyrepair
                                    4 red flash led 65X950G boot Sony and android logo but then black
                                    by Ihandyrepair
                                    HI guys
                                    I got here a Sony 65X950G - I tried to find any repairs guides for this model but not many online
                                    here is the issue
                                    I have Sony and android logo. but then 4 led red flash lights front of the tv
                                    I have 3.3v ref. 12v reg then T con 12v when I press the power on button
                                    but then I get black screen and 4 red flash light at the front LED
                                    but I get 3 led flash on the LED driver board.
                                    I check that few X900F or C YouTube repairs, seems that if you have 4 led red flash it could be due of LED black light error
                                    so I tried...
                                    07-11-2024, 01:45 AM
                                  • YvD-Electronics
                                    Request BIOS files to flash Toshiba C55-A-1TX laptop
                                    by YvD-Electronics
                                    I need the BIOS (bin files) to re-flash the BIOS chips on a toshiba laptop.
                                    Why I am pretty sure I need this to repair?
                                    1) Power supplies seem OK.
                                    2) Battery has been replaced, is charging well ... also not the CMOS battery CR2032, also not OK without RAM, or 1 or the 2 RAM modules (RAMS are OK).
                                    3) Laptop does really rare (seems random things) with the 3 leds (power, net, ...)
                                    4) In the past, when trying to restart 100 times via power button, it was sometimes succeeding, now no more.
                                    08-09-2024, 10:05 PM
                                    Toshiba Portege Z30-C Notebook Specification for Upgrade or Repair
                                    This specification for the Toshiba Portege Z30-C Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Z30-C boardview and Z30-C schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba Portege...
                                    09-06-2024, 05:33 AM
                                    Toshiba Portege R30-C Notebook Specification for Upgrade or Repair
                                    This specification for the Toshiba Portege R30-C Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the R30-C boardview and R30-C schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba Portege...
                                    09-06-2024, 05:30 AM
                                    Toshiba Satellite Z30t-A-10C Notebook Specification for Upgrade or Repair
                                    This specification for the Toshiba Satellite Z30t-A-10C Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Z30t-A-10C boardview and Z30t-A-10C schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                    09-06-2024, 05:27 AM
