LG Flatron 47" Turns on for 10-15 seconds then screen goes black
  • sprtcrazy17
    • Oct 2012
    • 3
    • usa
    First post here. So I found this 47" monitor with the intention to fix it. The screen turns on, then after a few moments it'll have lines appear in the screen and then go out. Once it goes out, not even the menu screen will appear. So that rules out the external device malfunctioning or the cable (xbox/hdmi).
    I've examined all the boards for blown caps, didn't see any(or anything blown).
    I'm leaning towards it being bad inverter board(s) after reading the symptons. I just don't want to buy $80 worth of boards without somehow testing them to be sure that's the problem. So that's my mian question, how would i go about testing these specific boards? I couldn't find a wiring diagram online about them to know the pin outs and specs
    The picture I first got, looked clean and crisp.
    Model number
    Power board
    T? board
    that one board...
    Master inverter
    Slave inverter
    Thanks for the help,
    Joe
  • sprtcrazy17
    • Oct 2012
    • 3
    • usa
    Re: LG Flatron 47" Turns on for 10-15 seconds then screen goes black
    **Edit**
    Sorry for not using the proper picture etiquette.
    Took a vid of the monitor turning on, ignore the background chit chat w/ my drunk roomate.
    http://www.youtube.com/watch?v=qNrGg...e_gdata_player
    Here's a short clip in the dark showing the backlights being on
    http://www.youtube.com/watch?v=7eFUG...e_gdata_player
    That's all it'll do, turn on, backlight turns on, but the menu won't display or anything.
    Would this most likely be the T-con board at fault?
    Does that rule out the power/inverter boards?
    I tested the small fuse on the t-con board and it was good, as are all others.
    Thanks for any help,
    Joe
    • Dax Corrin
      • Oct 2012
      • 13
      Hello, welcome. First, caps do not need to be swollen to be bad.
      I just recently fixed a couple of Hanns-G 28" monitors that both had bad caps on the power supplies that looked great upon visual inspection. Check the 5V outputs of the power supply once the image goes out to see if there is a problem there. Since the backlights do not go out, I would go to the video/controller board first. One of the 2 monitors I had had about the same issue you do, the image was there for about 10 seconds, then went dark. The capcitors on the video board right next to the voltage regulators were defective. It could also be the TCON board, but start with the one you labeled as "that one board".
      • Th3_uN1Qu3
        Believe in
        • Jul 2010
        • 6031
        • Romania
        Backlight stays on, that means you can absolutely rule out the lamps and the inverter. Fading with lines pretty much screams Tcon board.
        A working TV? How boring!
        • sprtcrazy17
          • Oct 2012
          • 3
          • usa
          I tested the video board to see if it had power, that was good. Decided to turn it on, and it was working while the monitor was leaned forward. Moving it made the picture cut out, started jiggling cables and the port on the T-con board is janky. But I got it to work and keep a stable clear picture for the time being. Otherwise a new board will be in my near future I suppose.
          Thanks for the suggestions
            You may want to reseating the cables at the T-CON board a couple times.
            • Stephen
              MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable
              by Stephen
              MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable to reset the computer. I disconnect the battery fully and then reconnect it and it won't turn back on. After letting it sit for a day I plug the battery back up, and the MagSafe 3 cable and it powers on and stays ons, once I plug in a USB C cable into the port closes to the MagSafe port it turns off and the Amber light turns off and won't turn on. No water damage, nothing, I want to do a DFU restore to wipe the computer since the customer stated they did an update and ever since it just decided to not work...
              03-15-2024, 09:37 AM
            • www
              LG L192WS-BN backlight turns off after 1 second
              by www
              I am testing an old LG L192WS-BN monitor I have that gives an image, but has a backlight issue. When you turn it on the backlight turns on 1 second and it turns off, turns on again, 1 second and it turns off and stays off. Using a flashlight I can see there's still an image.
              I replaced a bulged cap on the main board, but made no difference. I also got another exact same model monitor that has a broken ccfl (the connector got ripped from the panel and the main screen connector is also broken so I can't use this panel to test), tried using the main board from this one, same issue....
              03-24-2024, 05:26 PM
            • zklgfs
              Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
              by zklgfs
              I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
              08-11-2025, 02:14 PM
            • andrhouseolly
              Dell Precision 5510, AAM00 LA-C361P Rev:2.0 turns on, no image.
              by andrhouseolly
              Hi.
              I kindly ask you to help me solve the problem.
              Dell Precision 5510, motherboard AAM00 LA-C361P Rev:2.0
              The board turns on, there is no image.
              Read more. When the power supply is connected, the front panel indicators light up briefly.
              When you press the power button, the button indicator lights up. The board works
              there is no image, there is no matrix initialization, there is no image on HDMI.
              When turned on, the fans do not spin, but when they warm up they start spinning.
              When you turn off the button, the fans spin up to full speed for a short...
              05-11-2024, 03:14 PM
            • Egidio85
              Samsung UE55F8000SZ Turns on and off immediately
              by Egidio85
              good morning, I have a samsung UE55F8000SZ tv that turns on, shows the logo and turns off after 1-2 seconds.
              This defect happens continuously, hearing the classic click of the relay every time.
              Power supply board BN44-00636B
              disconnecting the mains and lamps from the power board always causes the same problem.
              Is it normal that without anything connected this power supply turns on and off cyclically?
              any suggestions on what to check?
              thanks in advance
              03-11-2025, 12:45 PM
