Has anyone delt with badcaps in dsl modems
  • Bishop
    • Apr 2009
    • 99
    I just opened up my 4th Motorola DSL modem to try and repair. The first three all had Capxon, and I was able to restore two of the three back to life by replacing three bad of the same kind. Thye both work now.
    The third is still dead, even after changing out the same three Capxon as each had. 2 out of 3 is not bad.
    Today a co-worker gave me another Motorola dsl but there were no Capxon inside, they were all Samxon caps. None were openly defective.
    Motorola must have changed from Capxon to Samxon brand.
    All six Samxon caps looks OK, any suggestions on the Samxon brand?
  • 370forlife
    Large Marge
    • Aug 2008
    • 3112
    Re: Has anyone delt with badcaps in dsl modems
    Samxon can actually be bought here at badcaps.net, they are a pretty good brand. I recall there are a few older series that have a problem with heat (like UCC KZE) but cannot remember what series they are.
    • Scenic
      o.O
      • Sep 2007
      • 2642
      Samxon GF and GL are the lemon series..
      • Bishop
        • Apr 2009
        • 99
        They are all the GF series, but none show any signs of damage, all are flat top and no corrosion or leakage.
        Every caps I've changed on anything has been swelling tops.
        How often do caps fail without any visible failure?
        • retiredcaps
          • Apr 2010
          • 9271
          Caps don't have to be visibly bloated to fail. They can have incorrect capacitance or high ESR.
          Many of the members who have ESR testers (not me - I don't have one) see many bad caps with high ESR and no visible failure.
          --- begin sig file ---
          --- end sig file ---
          • seanc
            • Nov 2008
            • 1319
            I can attest to that.
            Monitor with an external power supply, a nice 12v coming out of the supply but a dead monitor.
            Leading up to the total lack of power, it had been taking a long time to switch on.
            Found a small 100uf 16v cap (looked absolutely fine), 7Ω, replaced and working fine.
            Also I've removed quite a few Samxon GF from LG monitors, some swell, some don't. They usually show low capacitance or abnormal ESR.
            • ratdude747
              Black Sheep
              • Nov 2008
              • 17136
              i thought that gf/gl were fakes.. or was that a different series?
              sigpic
              (Insert witty quote here)
              • kaniki
                • 514
                same here too.
                I have a video card here that has something like a 1000uf cap on it.. tested it and it tested at something like 300uf. looks perfectly fine and all the rest of that series tested within about 30uf of that 1000 uf except that one which was less then half..
                • NxB
                  • Feb 2009
                  • 1595
                  A few months ago I found the reason why a major hotel was having problems with their dsl setup. 75% of the modems have capacitor issues. They are 2 years old. Upper management doesn't believe in repairs and instead wants to upgrade the server. I think they've probably fallen flat on their face by now. Some of the caps were samxon.
                  • severach
                    • Aug 2007
                    • 1055
                    I've fixed them before. I just get the tools out of the car and replace the caps on the spot. Stocking capacitors is a lot easier than stocking modems.
                    sig files are for morons
                    • Scenic
                      o.O
                      • Sep 2007
                      • 2642
                      GL are possible fakes (IMO). especially since they (coincidentally?) look like a 1:1 clone of CapXon GL.. only difference being CapXon -> SAMXON. They also fail just as much..
                      GF is genuine, but a lemon series (like NCC KZG).. good brand, crappy series..
                      • CapLeaker
                        Motorola 22F43 14pin dip identify me
                        by CapLeaker
                        Got an old Motorola page out controller here. Something honking old. Came in as no workie. Without schematic or anything. So I did some probing around and found two 14 pin DIP IC's that I need an replacement for.
                        Motorola 22F43
                        Motorola 22F44
                        Got no idea what these are.I got semi lucky and found a 22F44 on a donor. Unfortunately the 22F43 is already missing. If anybody knows what these are and find a cross would be greatly appreciated!
                        01-21-2024, 09:12 AM
                      • chth96
                        Can I replace KME cap with Samxon GF cap?
                        by chth96
                        Hello.
                        I have 29inch LG CRT TV,And Yesterday,Whenever I connect AC power cord to power outlet without switch on, I heard a sound like white noise, And When I switched on this CRT TV, It sometime displayed correctly But usually It won't last more than 20 minute and The screen begin to dark and It finally did not display at all for hours..
                        Today,I dismantled its plastic case and discharged the biggest capacitor(400wv 470uf) which still holds 250 voltage,and I finally detached PCB from cathode-ray tube.
                        I measured ESR value of most of caps in PCB with MESR-100 and I found that KME(25v...
                        04-17-2024, 07:11 AM
                        by momaka
                        03-15-2023, 10:17 PM
                      • CapLeaker
                        Motorola Minitor V pager no audio / sound repair
                        by CapLeaker
                        Got a bunch of Motorola Minitor V pagers from Fire Departments here trying to fix some out of the non working ones. These pagers are known for either no sound / audio or they don’t charge. The internet is full of suggestions like metal shavings inside the speaker?
                        Anyway so I took one of the Minitor’s apart for my amusement in order to see why that is and nobody can fix em. There are no service manuals or schematics for these that I know of. However… I did find the problem!
                        On the main board of this unit where the speaker connects to there is a metal shield....
                        06-10-2025, 07:44 PM
                        Motorola Moto E7 XT2095-1 XT2095-2 Schematic
                        Motorola Moto E7 XT2095-1 XT2095-2 Schematic...
                        10-29-2024, 02:07 PM
