Motorola 22F43 14pin dip identify me
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8318
    Got an old Motorola page out controller here. Something honking old. Came in as no workie. Without schematic or anything. So I did some probing around and found two 14 pin DIP IC's that I need an replacement for.
    Motorola 22F43
    Motorola 22F44
    Got no idea what these are.I got semi lucky and found a 22F44 on a donor. Unfortunately the 22F43 is already missing. If anybody knows what these are and find a cross would be greatly appreciated!
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8318
    • truclacicr
      • Apr 2019
      • 341
      • australia
      Maybe try here?
      https://mirrorservice.org/sites/www....ents/motorola/
      The sequential part numbers suggest that these ICs may be a functional pair, perhaps a transmitter and receiver?
      • redwire
        • Dec 2010
        • 3912
        I found pretty much nothing, it's house numbered
        Motorola Telecommunications Device Data DL136 archive.org would likely have the (telecom) IC's but almost all have "MC" prefix. The older databook has app notes which can help if you know the building block functions. With no MCU, I expect a lot of vanilla CMOS logic though.
        Is this using DTMF or a codec, modem? All it has for UI is a 7-seg LED display? The IC's connect to a keypad?
        Only tidbits I found:
        87K01 - SC45070PK/45070 - MC14049UBE
        87K09 - MC14028BCP
        • CapLeaker
          Leaking Member
          • Dec 2014
          • 8318
          redwire
          This thing is a Pager for a Fire Department and is hooked up to a VHF radio. It has a single digit display and yes there is weird number pad hooked up to it. It must be somewhat programmable. You press the number 1 on the keypad, which sends out a DTMF two tone to open the squelch on the pager. Then you relay a one way message.
          I also had a look at an old Motorola book and didn't find anything a 22F43 or an 22F44. There must have been some real old Motorola books with cross references at some point.
          Those chips must have been available at some point, because one of them was socketed already. The donor had the socket and the IC missing.
          The number pad hooks up right to the pin strip top left underneath the transformer, below that resistor bank.
          Once powered up, this thing supposed to show a “0” and then turn to a “1”. First ist always stayed a “0” until I swapped the 22F44. Now it shows a “9” and the relay is continuously on. I swapped the IC to the right of 22F44 as it had a 50% chance of being bad, but turns out the 22F43 is bad, but I don't have a replacement, nor have a clue what it is.
          Thanks redwire, even for the little Timbits! This thing should be in a museum, not on my bench for repair. Lol
          • CapLeaker
            Leaking Member
            • Dec 2014
            • 8318
            Originally posted by truclacicr
            Maybe try here?
            It’s CMOS. I can tell you this much. If I pull 22f43 or the 22f44 it will hinder the unit and just displays “0” these two are not directly connected to each other and they have a few pins each going to the keypad. Also the 22f44 has something to do with the relay.
            • redwire
              • Dec 2010
              • 3912
              Ah the pic has more keywords "Motorola Alert Central Paging Encoder"
              I did see the 1976 service manual eBay USA https://www.ebay.com/itm/33521188797...item4e0c2f7d64 1 day left, maybe email the seller.
              Aaauuurgh fuzzy pics https://www.worthpoint.com/worthoped...ert-4584348476
              unit for sale on eBay Canada https://www.ebay.ca/itm/115744377976...item1af2e70c78
              "The Moden/100, Moden/36 and Alert Central paging encoders are pretty much the same thing with little difference in features. They all are covered by the same service manual. It is only capable of 6 tones in the PROM.
              The tones encoded are are controlled by ROM's U22, and U28. These are Harris Semiconductor HM1-0186 Commercial Diode Matrix. These are a 6x8 diode matrix, which adds up to 48 diodes on the inside.
              The links of the diodes inside represent the tones. There are tables in the manual that show how the bits should be.
              It's in a 14 pin package. These had to be pre-ordered in bulk from Harris."
              • truclacicr
                • Apr 2019
                • 341
                • australia
                If the chips are decoding the keypad, then perhaps one is driving the rows, and the other the columns. I would trace the circuit in that area, then we could see what common chips might fit the application.
                • CapLeaker
                  Leaking Member
                  • Dec 2014
                  • 8318
                  interesting find redwire. Damn... I wish I could find my glasses this morning... LOL I put em somewhere yesterday...
                  • redwire
                    • Dec 2010
                    • 3912
                    Just don't sit on them lol. I need new ones but got used to the blur.
                    This pager thing is a ~1976 design with 1980's build. A long run. It's hard to know how this works - no MCU means it's a simple state-machine I guess.
                    I wonder if the keypad IC's get zapped with static. Strange they are another numbering scheme different from the other IC's. The Motorola keypad IC's of the era are scan/decode to tone. Like MC14419 does keyboard scan to BCD, MC14410 tone encoder.
                    • CapLeaker
                      Leaking Member
                      • Dec 2014
                      • 8318
                      Left my glasses on my workbench at work. At least I didn’t sit on it. lol. It’s not the keyboard that gets zapped. On most of them the little transformer has an open primary and they just put a DC wall wart on it. That 22f43 also has something to do with the relay. No MCU on this old thing. I don’t understand the old numbering scheme from Motorola at all. Never seen the letter F in between numbers.
                        • Jul 2011
                        • 6060
                        I got to ask the question what do you plan on doing with this device if you manage to get it working again
                        • CapLeaker
                          Leaking Member
                          • Dec 2014
                          • 8318
                          Goes back in service to a certain FD.
                          • thesame
                            DVR HIKVISION DS-7208HWI-E1/A BOARD DS-80104 REV 2.2 help identify burnt components
                            by thesame
                            Hy guys , i have a DVR board DS-80104 REV 2.2 that was powered wrong, i have some smds on the board that are blown and i can't identify them , maybe if someone has this board somehow and we can identify the smds', i have searched online and i can't find a schematic.
                            The smds are SOT-23-6 , one of them i think it has the marking ADJF since i found another one on the board with this marking , but the other one it seems that it starts with AG or it looks like. I would really apreciate if someone could help me identify those IC's .
                            02-27-2024, 04:31 AM
                          • silver60618
                            Lenovo Legion 7 - Help Identify IC
                            by silver60618
                            Hi gang, its a long shot, but working on Lenovo Legion Pro 7 motherboard NM-F091, and trying to identify this component near GPU with marking "eHFQH" that is burned and shorting the board. Looks like power management IC
                            I couldnt find any schematic or boardview. The CPU side also has same chip. Any way to identify this chip? or take measurements from the good chip to determine what it is?
                            Any help would be appreciated...
                            07-02-2025, 12:16 PM
                          • chth96
                            How can I identify varistor which have been blew up?
                            by chth96
                            I mistakely pluged 100v japanese retro game console to 220v outlet.
                            So It seems that glass fuse and varistor have been blew up.
                            I can identify that voltage and ampere value of glass fuse(250V LF 1.6A),but It is impossible to identify varistor type in my sega saturn PSU(YAMAHA 35M07U XR258)
                            Is there any way to identify varistor type in my sega saturn PSU?
                            Any reply would be appreciated.
                            EDIT:
                            It seems that I finally found out what type this black varistor is. It is Panasonic ERZV05D221 “ZNR” Transient/Surge Absorbers (Type D) Varistor Voltage...
                            11-26-2023, 08:52 AM
                          • freakorio
                            Need Help To Identify Component on Ymain LJ41-05120A
                            by freakorio
                            Hi guys , i hope this is the right place , i got Plasma Samsung PS-50Q91H and i need to repair Ymain LJ41-05120A , but those component are burn and i can not identify to replace those part , and the part are blue capacitor and the location are C5105 and C5106 and here i attach the part that need to identify , and one more thing , i also need to replace Zener Diode on location ZD5502 and the part are BZV55C because mine is short but i don't know the voltage because those parts are release with many type of voltage. Looking forward for your kindly reply
                            05-21-2024, 02:32 AM
                          • baiceanu_stefan
                            nm-f251 Schematic, boardview or help identify componente
                            by baiceanu_stefan
                            Hello, I have a legion pro 5 16arx8 serial number pf4bf4aw mb code nm-f251 rev1.0 which was dissasembled by the client for cleaning. Now it does start but for 20 secs after that fans run at maximum and then shut down. Found PU8302 burned but cannot identify it the part. It is written eHFAA on it but didn't found any info, no boardview, nothing. Can anyone help identify the part so I can order it from somwhere? Ataching some pictures of the motherboard, serial number and part. Than\k you...
                            04-24-2024, 12:49 AM
