Dim Clock LCD on Jenn-Air wall oven
  • bluto
    • Oct 2007
    • 560
    I actually fixed this bugger a while ago, but though it would document it now so someone else with the same problem might be able to Google this and save some $. I have a Jenn-Air electric wall oven with all digital controls. At some point the VFD display module began to get dim to the point it was unreadable. Some times it would come back to life but eventually faded out completely. After much teeth gnashing I determined the problem to be a bad capacitor. C3, a 68uf 35v was bad. It has been about 2 years now since replacing this capacitor and the clock is still going strong.
    The clock module has the following numbers on it: 100-00695-20 CN 7601P483-60. The Maytag part number is 71001799. The part costs around $170. It may also be used on other Maytag made brands (Maytag, KitchenAid, Amana, Magic Chef, Kenmore, Whirlpool, etc).
    The capacitor needed (C3) is a 68uf 35v, 105C, low esr cap. I recommend Panasonic FC series (Digikey p/n P10292-ND) capacitor, but any other brand that is good quality, low esr and rated for 105C will work. After removing the cap, clean up any electrolyte that may have leaked out of the bottom with a q-tip and alcohol. If your clock has a different value in C3, be sure to replace it with the same value as what was removed.
    If you order from Digikey, the cost is $0.31 as of 6/2018. They do not have a minimum order at this time. Be sure to choose first class mail as the shipping method and the total cost will be around $8. I would recommend purchasing from badcaps.net, but TC does not stock a cap of this value.
    It is usually not required to replace the other capacitors as described in some of the other posts in this thread. Try replacing C3 first to see if it solves the problem before attempting to replace any of the other caps.
    Some people have reported finding a resistor being attached inline with C3 in what appears to be refurbished clock modules. These modules may have an 'R' at the end of the part number on the sticker. See picture here: https://www.badcaps.net/forum/showpo...&postcount=126
    If your board has this resistor along with C3, it is safe to remove it and just replace C3 with a 68uf 35v cap as outlined above.
    Last edited by Per Hansson; 06-30-2018, 08:01 AM. Reason: Updating with more info per user request
  • japlytic
    • Oct 2005
    • 2086
    Re: Dim Clock LCD on Jenn-Air wall oven
    Those capacitors look like Panasonic units - are they original or replacements?
    Good repair job too.
    • bluto
      • Oct 2007
      • 560
      Thanks! The originals were Nichicon [PL(M)? 105C]. The until was about 10 years old when it failed. The replacement panny's are shown in the pictures that I took today. 3 FCs and one NHG on the left side. I had to remove the microwave recently for some under cabinet lighting, so I opened up the oven again for some pictures.
      • jeffschindler
        • Oct 2009
        • 1
        Thanks bluto for the great post for the problem/repair! I had the same issue and now I have fixed it with minimal cost rather than $170 for new board, which is what I would have done. I bought new caps from Digi-Key, whose web site was great for getting the exact caps you need. I replaced all 4 caps and the unit works fine again.
        Best Regards,
        <>< Jeff
        • paul gobat
          • 1
          Great post because I'm in the same boat. I need to replace the capacitors on the board and now I'm wondering what sizes they all are. I know C3 is 35V and 68 mFd but don't have any idea about the others. Can anyone help?
          • bluto
            • Oct 2007
            • 560
            Welcome to the badcaps forums!
            I guess I should have put all of that information in my original post. So after one more peek inside the oven, here are the specs and part numbers to order from Digikey. All part numbers listed are for Panasonic FC series capacitors. FM series part number shown in parenthesis where the FC series cap is out of stock at the time of this post.
            On the clock module:
            C1 & C4 470uF 35v P10301-ND (or the FM series: P12400-ND)
            C3 68uF 35v P10292-ND
            C7 22uF 50v P10318-ND
            On my oven I also replaced the two caps on the power supply/relay board as a precaution. They were as follows:
            3300uf 16v P10260-ND [filter cap] (or the FM series: P12373-ND)
            47uf 50v P10321-ND [the only other cap on the board]
            Of course the power supply/relay board could vary if you have a different model oven (gas for example).
            Please update this thread if this information is useful and you are able to repair your clock module.
            • rogerstkr
              • Mar 2010
              • 1
              Thanks for the repair info. I had already replaced the clock module on my 8 year old Jenn-Air Radiant Range with Convection Oven (Model SCE30600) about 4 years ago. I wasn't about to add another $160 to the range's total cost by purchasing yet another complete module.
              I replaced just the 68UF 35V ELECT FC RADIAL capacitor in position C3 as suggested in this thread. Ordered cap from DIGI-KEY (P10292-ND $0.28 + $8.13 for ground shipping) since I couldn't find it locally. The bad cap registered around 34UF on my meter. No signs of external leakage or damage. Put everything together and success!
              • bluto
                • Oct 2007
                • 560
                Glad to hear that your clock is visible again. You could probably re-cap your 1st clock module if you still have it and put it on ebay! Just a tip, parcel post on digikey is usually cheaper than UPS ground.
                • Edcap
                  • Sep 2010
                  • 1
                  Hey Bluto I have to thank you also for posting you original message more than a year ago now. I had the same exact issue of a dimmed display on my Jenn-Air display and this fix worked like a charm! C3 cap replaced just saved me 170 bucks! Glad I decided to do a quick search online to see if anyone had the same issues! Can't thank you enough! Where can I send you a Virtual payment for the virtual troubleshooting ;-) j/k!
                  • bluto
                    • Oct 2007
                    • 560
                    glad to hear the there are still plenty of these out there that are repairable!
                    • Professor Peach
                      • Oct 2010
                      • 18
                      I assume 2497 measns week24, 1997.
                      Amazing to see such a lot of t/h components this late-on.
                      AFAIK, Robertshaw are now part of Invensys, after combining with Barber-Colman, Satchwell, et-al.
                      • bluto
                        • Oct 2007
                        • 560
                        Yes the oven was manufactured in 1997. Still going strong! But then again it has only been turned on about 15 times in the last six years that I have lived here
                        What is a t/h component?
                        • Krankshaft
                          • Jan 2007
                          • 2328
                          Through hole components.
                          • bluto
                            • Oct 2007
                            • 560
                            Right. I knew that. Just never have seen it written like that.
                            • PCBONEZ
                              Grumpy Old Fart
                              • Aug 2005
                              • 10661
                              Couple weeks ago I fixed a controller board for a fridge that was manufactured in 2001.
                              It was also all through hole.
                              Same-same with a compressor board from 2005.
                              Perhaps when they have lots of room through hole is still cheaper.
                              Mann-Made Global Warming.
                              - Dr Seuss
                              • Professor Peach
                                • Oct 2010
                                • 18
                                You're not a great one for cooking then!
                                Yes, that is, indeed, through-hole, sorry for the confusion.
                                • Krankshaft
                                  • Jan 2007
                                  • 2328
                                  It's kind of bizarre since after etching they still have to drill all those through holes for the components with a computer aided drill.
                                  Maybe it's cheaper because the SMD placement machinery costs more than their coarser through hole counterparts?
                                  • Krankshaft
                                    • Jan 2007
                                    • 2328
                                    You'd figure that extra step would cost more.
                                    Maybe it's cheaper because the SMD placement machinery is more costly to operate or costs more upfront than their coarser through hole counterparts?
                                    • PCBONEZ
                                      Grumpy Old Fart
                                      • Aug 2005
                                      • 10661
                                      Small companies might not even have machinery. They may outsource the PCB manufacture and use Chinese girls fingers for component placement & soldering. I imagine they can pay a lot of Chinese girls for a long time for the cost of one high-end machine.
                                      [That scenario is probably where the odd-ball brand 'DEER' based PSU's come from.]
                                      Alternately there are CAD machines that are 30-40 years old that can't do high density high accuracy drilling jobs, but work fine and reduce the initial investment.
                                      During my short stint as a Millwright [2002-ish] one of the machines I maintained was a drilling machine from the 1940's. It was originally manual but had been custom modified in-house several times over the years. By the time I had to deal with it it had hydraulics, controlled by pneumatics, controlled by PLC's, controlled by [a very simple] computer via an LCD/button panel.
                                      There was NO documentation on how this thing worked but other than an occasional oil or air leak it never had problems.
                                      - Dr Seuss
                                      • Professor Peach
                                        • Oct 2010
                                        • 18
                                        Yes, but this is Invensys, a huge corporate company.
                                        • asuwish824
                                          Jenn Air Wall Oven Dim LCD
                                          by asuwish824
                                          I recently purchased a Jenn Air Wall Oven model number jjs2730ws00. It functions properly except that the lcd display is rather dim. No adjustment in the settings seems to improve or even change the dimming/brightness of the display. My hope is I can repair the current display instead of purchasing a new or used unit to replace. I prefer to fix at the lowest point for the joy of the repair. Also throwing out what would otherwise be a perfectly good part just because perhaps a capacitor or other small part is bad seems obviously wasteful. Any guidance would be appreciated.
                                          PS It...
                                          05-18-2022, 10:30 PM
                                        • Fsufan1391
                                          LG Oven model LREL6325F
                                          by Fsufan1391
                                          Hello everyone my oven is less than 2 years old and all of a sudden recently when i run the oven for 15 minutes or so and i am done with it and shut it off. after about 10 minutes it starts chiming and randomly putting it in different modes like the touch screen is being touched but no one is around it. I have tried to reset it by unplugging it multiple times and no luck. I took it apart to see the main board and everything looks fine. I am wondering if i should replace the main board or if its in the control panel. the touch screen is very responsive and works like it should. its only acting...
                                          04-23-2025, 05:42 AM
                                        • Joe24
                                          Maytag Whirlpool Kenmore clothes dryer data bus
                                          by Joe24
                                          Patient is a Maytag/Whirlpool/Kenmore clothes dryer. Not sure of exact model, doesn't matter. All boards are out of production.
                                          Specific problem is a Maytag 8544799 / WP8544799 motor-control board, aka Diehl Controls 708879-05. Customer states the board "doesn't work, motor doesn't run". Not sure how the repairman made that assessment, or if it's even accurate. He can't get replacement boards, and the owner decided to buy a new dryer, so whether this board is the problem is speculation on his part. Again, doesn't matter.
                                          I've been over the board looking for...
                                          01-13-2025, 06:50 PM
                                        • bpjl
                                          SEF 551.10 - Error starting the reflow oven.
                                          by bpjl
                                          When starting the SEF 551.10 reflow oven, the following problem occurs:
                                          It seems to me that this is related to corrupted software. Does anyone have files that can fix this device? Or maybe someone uses such an oven and is able to make a sector copy of the memory card located in the computer controlling this oven?
                                          PS.: Of course, appropriate emails for help have been sent to the manufacturer and distributor in my country. No response yet, but I don't expect much. It's a fairly old device and from what I know, it's no longer...
                                          10-17-2024, 06:30 AM
                                        • goodpsusearch
                                          Daewoo microwave oven repair
                                          by goodpsusearch
                                          One day my microwave oven stopped heating.
                                          It would turn on and rotate the plate but no heat.
                                          I removed the cover and checked components with digital multimeter.
                                          Found that the high voltage fuse was blown.
                                          This is not the AC fuse, if the AC fuse was blown then the oven would appear totally dead.
                                          Then I tried to find replacement fuse on local electronic parts stores and this specific value was not available so I got the closest I could find.
                                          I replaced fuse and tried to heat up a glass of water.
                                          Strange noise...
                                          01-24-2021, 03:56 PM
