Sylvania LC320SLX shutsdown quick
  • high-tech
    • Sep 2010
    • 197
    This tv shutsdown to standby so fast the B/L wont flash nothing. I'm not familiar with this chassis. I checked mosfets on inverter and the 4 xformers are ok on the secondary. If I pull all the wires off the inverter and power up it stays green. IDK, I think I attached pics will see if they show up... Referring to pulling the wires I mean the ribbon going from main to inverter.
  • PlainBill
    • Feb 2009
    • 7034
    Re: Sylvania LC320SLX shutsdown quick
    I appreciate the pictures. This is an unusual design; I don't think I've ever seen anything like it. What I find most remarkable is the 'inverter' seems to be unusually complicated. Of course, it's got it's own power supply. But where is that ribbon cable at the bottom of the inverter going?
    PlainBill
    • high-tech
      • Sep 2010
      • 197
      Hi Bill, there is no per say T CON board on this tv. that ribbon you speak of goes to the screen as well as 1 from the hdmi to the right side.
      • high-tech
        • Sep 2010
        • 197
        Update, problem solved and unrepairable. Cracked screen, I unpluged the screen and backlight came on and stayed on...
        • antontv1
          • Oct 2011
          • 1
          I have the same tv here for repair,but there is no power at all. no 3.3 or 5volts. not sure were it comes from. anyone have a schematic on this LC 320SL ?
          thanks
          antontv1
          • x_orange90_x
            Vizio E55-E1 bad backlights or bad inverter?
            by x_orange90_x
            I just got this tv today and it appeared to have no backlight on. After taking off the rear cover and checking again in the dark I can see that MAYBE one quadrant is lit.. But still it's quite dim. I was going to check the LEDs with my tester, and I found LED 1 and LED 2 + pins on the wire from the inverter, but I couldn't identify a ground. Nonetheless I tried using a mounting screw on the inverter board and also the chassis as ground but regardless my tester reads 300 which is what it reads when there is no voltage draw.
            I don't know how exactly to test the inverter itself. Is it...
            01-29-2025, 09:24 PM
          • Gentian
            APSINT3636VR 3600W APS INT Series 36V DC 230V AC Inverter/Charger schematic
            by Gentian
            I have a tripp-lite aspint 3636vr inverter charger which blow some of mosfet transistors. I replaced them repaired also the driver circuit and tested but the mosfets burn again.
            It work very well as inverter and also as charger if I let the rear switch in auto mode (inverter) and charger only(charging) but in auto when I connect the feed line 220V AC first time it pass ok to line and start charging the batteries but when I remove the feed line it pass to inverter mode and if I do it again the second time when passing from charging to inverter the Main transformer start making a...
            03-06-2023, 07:07 AM
          • valvashon
            Insignia NS-LCD19-09 (PS OK, Inverter problem?)
            by valvashon
            For some reason I'm just not going to let this 19" TV defeat me. I guess because I have a schematic to work from I feel like I'm oh so close.
            History- while adding a turn-on circuit I let a small screw roll under the power board. Worked through all of that circuitry, probably replacing a MOSFET and PWM controller that were not bad but I was following the service manual. Finally figured out that the power supply is in working order when the inverter section (for the backlights) is disconnected. When the +12 supply to the inverter is disconnected the +12 and +5 will come up...
            01-04-2024, 01:44 PM
          • eccerr0r
            A modified sine wave inverter + a grid tie inverter?
            by eccerr0r
            If I had a solar fed grid tie inverter (GTI), a modified sine wave inverter, and a power outage occurred, what would happen if you disconnected mains, backfed the modified sinewave inverter (MSI) into house power, and hooked up the GTI to the output of the MSI, would it work?
            Next thing is trying to charge the batteries using solar power, but that's another issue ...
            08-31-2023, 09:14 PM
          • caseyjay_48
            Sony KDL-46BX450 Inverter Troubleshoot Logic
            by caseyjay_48
            I am currently on a troubleshoot of 46” Sony KDL-46BX450 tv. I came back from Washington to Texas on medical emergency and had to leave all my tools up there. All I have is a couple of screwdrivers and a dvm. I wish to ask the community a troubleshooting question. Please forgive stupid questions as meds I am taking produce brain fog.
            I have well maintained Sony KDL-46BX450. It went black one day. After turn-on, I get solid green light and Sony logo in screen center for about 1-2 seconds, then black. No blinking LEDs, no hissing. Flashlight test shows screen characters dimly viewable,...
            09-23-2022, 08:08 PM
