Vizio M492i-B2 Won't Turn On
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8163
    Re: Vizio M492i-B2 Won't Turn On
    We have to find the BLon signal in order to rule out the main board. Other than that, if the BLon is present, I would look hard on that those LED control IC's.
    The BLon would act the same as PSon. Look for a DC voltage that appears when the TV is turned on and disappears when the TV is off.
    • John90
      • Aug 2016
      • 27
      • united states
      Took a break from the TV over the weekend. Still working on finding the BL-ON. I will let you guys know as soon as I find something.
      • John90
        • Aug 2016
        • 27
        • united states
        CapLeaker, if my BL-ON is present what do I need to look for on the LED control IC's? Having trouble finding BL-ON so I'm hoping I can work backwards from the LED control IC's.
          Per post 17, we need the P/N of the ICs to look up the spec sheets.
          • CapLeaker
            Leaking Member
            • Dec 2014
            • 8163
            As budm mentioned, we need the part numbers of the IC's. Then go for the obvious like does the IC get proper VCC power. After that, its maybe see if we can disable the protection then switch out the IC's or get a new board.
            But first we go there, we really need to figure out if the main is sending BLon, other than that, we will be troubleshooting all day long for nothing on the wrong board.
            • John90
              • Aug 2016
              • 27
              • united states
              #26
              Sorry about that. This is what I see on them.
              U900/904-44DE S29B
              U902/903-AS3820E E 1414XBH
              • John90
                • Aug 2016
                • 27
                • united states
                #27
                Guys, I have checked every pin on CN1, CN30, and CN901 and I do not see anything that goes from 0V to 3V when I try to turn on the TV. I thought maybe I was just missing it or something since nothing is labeled but I checked again and get nothing.
                • CapLeaker
                  Leaking Member
                  • Dec 2014
                  • 8163
                  That doesn't look good. The AS3820 is the LED control IC.
                  You say U900 and U902? At SJ I see U902 and U903 on the LED driver board?
                  At this point I'd say replace the LED driver board and see what happens. We know for some reason one side measures different from the other, which shouldn't be.
                  • John90
                    • Aug 2016
                    • 27
                    • united states
                    #29
                    I believe Budm asked about U900 and 904 as well but 902 and 903 are the AS3820's. ShopJimmy has a LED board for ~$18 so I will order one and hopefully that will fix the problem. If not, then problem is probably the main board?
                      I would take a chance on $18 Dollars.
                      • John90
                        • Aug 2016
                        • 27
                        • united states
                        #31
                        Ordered! I will let you guys know what happens when I get it.
                        • John90
                          • Aug 2016
                          • 27
                          • united states
                          #32
                          Well guys, I have some bad news. Got the LED driver board in and hooked it up and still have nothing. Nothing happens when I try to turn on the TV. What should I do next?
                            The 24VDC was on R9008 and 9010.
                            The voltage I am getting on capacitors TC903 and TC901 is
                            TC901=8.84VDC
                            TC903=12.54VDC
                            Still have the same Voltage reading as the old board?
                            • John90
                              • Aug 2016
                              • 27
                              • united states
                              #34
                              Just checked and I have the same readings on TC901 and TC903.
                                This is not going to be easy at all since none of the connectors for that board is labeled.
                                • CapLeaker
                                  Leaking Member
                                  • Dec 2014
                                  • 8163
                                  That's not good. you can do a full board swap out. It's $75, which would be the next easiest thing.
                                  Hard to do anything on that set without knowing what the pins do. At this point I would say that the main board isn't sending BLon.
                                  • John90
                                    • Aug 2016
                                    • 27
                                    • united states
                                    #37
                                    Should I just buy the main board? Found one on ebay for $30.
                                    • CapLeaker
                                      Leaking Member
                                      • Dec 2014
                                      • 8163
                                      That is preference, I guess... but 75$ for all the boards from a trusted seller is a better deal to me... not that you are going to need something else later... The TV should be worth a 100 bux... since it is a fairly recent model.
                                      • John90
                                        • Aug 2016
                                        • 27
                                        • united states
                                        #39
                                        Update!
                                        The good new is, I ordered a main board and it just came in. I installed the new board and now the TV turns on! Finally!
                                        Bad news....looks like the display is cracked
                                          Oh man! you just cannot win on this one.
                                          • Mulp
                                            VIZIO M65-C1 Does Not Turn On
                                            by Mulp
                                            Hi All,
                                            I am having an issue with my Vizio M65-C1 where it does not turn on. When I plug it in the stand by light on bottom left of screen turns on (white) then fades away. If I press the power button it turn back on and then fades until it is super dim.
                                            When I remove cover, there are no illuminated leds on the main board, I've seen others with a red/blue led that turns on.
                                            I've done some research and what is interesting is my voltages all seem slightly different from other people. For example +5/3.5v is 3.48V when on which is different from others on here....
                                            01-13-2024, 09:57 PM
                                          • pajdek
                                            Lenovo Y700-17ISK turn on and off
                                            by pajdek
                                            Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
                                            09-20-2023, 02:49 AM
                                          • RdeveLabs
                                            MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
                                            by RdeveLabs
                                            To all the members here...
                                            Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
                                            So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
                                            05-05-2025, 04:59 AM
                                          • robante15
                                            Acer Aspire 4520 won't turn on after reboot
                                            by robante15
                                            Hello, I have an Acer Aspire 4520 from a couple of decades ago and I want to repair it solely for nostalgia.
                                            It happens that when I turn it on after having been disconnected for a long time, it turns on without problems, it tells me that the BIOS has been reset and that it will load the factory settings, if I tell it to continue, the computer turns on and everything works fine.
                                            The moment I turn it off and want to turn it back on a second time, or restart it and try to start it again, it no longer gives an image, and it no longer responds.
                                            If I remove the...
                                            04-06-2024, 06:50 PM
                                          • SS454
                                            vizio e650i-a2 backlight flashes then turns off
                                            by SS454
                                            vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                                            panel: au optronics T650HVN05.4
                                            72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                                            link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                                            Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                                            https://www.shopjimmy.com/vizio-56-0...-power-supply/
                                            Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                                            08-20-2020, 03:57 PM
