Hey guys, I picked up a LG 42LB1DR thinking this would be an easy fix. Its turning out to be a bit more difficult. I'm hoping you experts can shed some light on this repair for me. Basically everything I can find online about this specific model and issue states that it is directly related to some bad caps on the PSU. No problem, I crack it open, see that some of those known bad caps have already been replaced but there is still one on there. I decide to replace almost all of the caps on the board instead of just that one. This includes the ones that were already replaced because I have no idea where those caps came from. I get all my caps from Digikey. I pick up 25$ worth and replace all of the caps with a black dot on them in the picture. Install the board and same issue. Then while taking this unit apart some more I forgot to disconnect the main video cable and I break the connector on the LCD inverter board. So I replaced this board with a known good one I picked up off eBay, but alas the same issue occurs when it is powered on. The back lights come on and stay on but there is no picture on the screen. Also i have never seen one of these models working correctly but once it is powered on and you press the power button to turn it off it takes like 20 seconds before it actually kicks off. I would like to do some additional testing on the PSU before I even consider replacing the main board. The 2 biggest capacitors and some small ones I did not replace, should I? Any thoughts or ideas are appreciated. Thanks guys.
LG 42LB1DR No Video or Sound
Re: LG 42LB1DR No Video or Sound
Do you have a multimeter? Check the output voltages on the power supply.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search. -
Your fast, was just documenting those. Added two images to the OP. One has another picture of the PSU, the dots on the connectors are the key for the image with the chart of voltages on it. The top line on the each table in the chart represents the marks on the board and the second row is the voltages i received while testing. The top two connectors read the same, each one goes to one of the back light inverter boards (if that's the correct term).Comment
3.4V seems to be your problem if it's around 1.5-1.8V. *Especially if it is rising while you take the measurements.*
But... I note this TV has a HDD and that some LG TVs with HDDs have problems powering up with a bad disk drive. (I know, stupid design, given HDDs have a fairly high failure rate.) Try unplugging the HDD power and SATA cable and seeing if it powers up properly.
Can you remove the power supply and take a picture of the underside? I will try and figure out how the 3.4V is generated. On most LG TVs it is generated using a secondary DC-DC converter and it's possible this could go bad (but I've only ever seen bad caps on those types of converters, and only once on an LG LCD.)Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
"The back lights come on and stay on but there is no picture on the screen." That is the keyed words, if the backlights come on and stay on but you see no pictures, then the problem can be the main board or the T-CON board (this board is mounted on the to center of the screen). The purpose of the backlights is to give the light source for the screen and that is, newer TV uses LEDs for light source instead of CCFL. Please post the pictures of the whole chassis so we can see how all the boards are connected together.
Please read my basic guide in the PDF attached.Never stop learning
http://www.badcaps.net/forum/showthread.php?t=24809Comment
Please read my basic guide in the PDF attached.Comment
See the PDF, the T-CON is under the main chassis and it is also covered by another metal shield, very bad chassis design.
Sine I have never work on one of these TV with Hardrive, not sure if you will see anything on the screen if the drive is bad. Do you see anything using flashlights?Attached FilesNever stop learning
Sine I have never work on one of these TV with Hardrive, not sure if you will see anything on the screen if the drive is bad. Do you see anything using flashlights?Comment
Not sure how i should test those spots on the board. The board is reading 1.9v all over that area but it is not being signaled as on. For the PSU to be hooked up to the main board and get the ON signal it has to be mounted on the chassis so I can not test the under side of the board. How should I test for short circuit? After some fiddling and testing everything is hooked up the same as the last test and all 3.4v except the blue 3.4v which is ON/OFF are now reading 1.25v. Super weird. When the Green connector is removed from the PSU there is almost no voltage on the 3.4v lines. This may mean the 1.8v and 1.25v readings are coming from the main board instead of the PSU.Last edited by IRShifty; 03-06-2012, 12:37 AM.Comment
Hello guys,
I have a LG 42LB1DR . I have the problem with the tv having no picture/sound.The result of doing this is that I get nothing. When I plug the tv in, I can hear a click and a sound like something is spinning up. There is a red light on, on the front of the tv. I let it sit like this for a few minutes then hit the power button on the remote. The red light will change from red to a bluish white and flash for a few seconds. Then stay on steady. About this time the screen back light will come on but the screen is otherwise blank.
.So far with mor info its look like some off capacitor on the power supply . I bought so the caps, and replaced c201 c202 c219 and c235. However i still have the same problem.I have just a blue screen with no vedio or audio . is the is another capacitor need to bee chang or any thing ells . need help thanks .
Any help?Comment
Check the inductors I highlighted using your ohmmeter - they should read close to zero ohms.
Check the voltages at those points with the board plugged in and powered up, it may be possible to check from the top side.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
BTW all 3.4 are back to reading 1.8Last edited by IRShifty; 03-10-2012, 04:16 PM.Comment
Both inductors read zero ohms. The only thing in that voltage area on the top side is a capacitor and I can not test the + on the capacitor with it in the circuit. Would it be a sufficient measurement to remove the capacitor and then power the unit on and test the + on the board? Thanks
I have just noticed there are these copper fins (probably heatsinks) on the top and that they are connected to certain nodes in the circuit. One of them connects to the input voltage to the buck converter for the 3.4V output. It's likely to be this one, but it could be the one to the right of it. Check the voltage on each of these relative to the metal case or a spare screw hole while the TV is on.
Also what is the part # on U214 (the black 8-legged chip.) It's on the bottom of the board (green side) and near those copper heatsinks.Last edited by tom66; 03-10-2012, 06:46 PM.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
I wouldn't recommend removing the capacitor, as it may have an important function.
Also what is the part # on U214 (the black 8-legged chip.) It's on the bottom of the board (green side) and near those copper heatsinks.Comment
I expect that the controller itself is faulty then or the MOSFETs are.
Here's a datasheet for the controller. http://pdf1.alldatasheet.com/datashe...IRU3037CS.html
The 1.8V on that fin is unexpected. However, it may be that your multimeter is averaging out the waveform there (which would make sense as that is how a buck converter sort of works.) The intermittent start-up seems familiar as we have seen that before with faulty controller ICs and voltage regulators.
Just for future reference -
I note they are being sold on eBay: http://www.ebay.co.uk/sch/i.html?_fr...All-Categories
but DigiKey has them for $3.75 http://search.digikey.com/us/en/prod...FCT-ND/2441095 +$2.75 shipping
How confident do you feel about taking some voltage measurements on U214 while the TV is plugged in? Do you think you could flip the board and make the measurements?Last edited by tom66; 03-11-2012, 05:18 AM.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
How confident do you feel about taking some voltage measurements on U214 while the TV is plugged in? Do you think you could flip the board and make the measurements?Comment
Just check the voltage on each pin relative to an exposed screw hole.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
by m1ch43lzmHi, this is my personal laptop, which the original board (lets call it Board A) blew up PU8700 (TPS51486), making a hole on the board, i had left the laptop at my desk one day with the battery fully charged and didn't touch it for a week, but when i tried to turn it on it didn't
Thought the battery was dead, so i plugged in the charger then tried to power on, the power LED blinked once, charged LED still orange, unplugged the charger, plugged in again and I noticed the "magic smoke" smell, so i unplugged the charger, removed the back cover and saw the blown IC (the "magic... -
Assuming...7 Photos -
by slimmy182Hello, I bought this Mac from a friend, he said that it simply stop working. The MacBook looks very clean but does not power on, stuck on 5v 0.42A, and sometimes display 5V and 0A (then 0.071A and again 0A).
I opened it looking for some problem, it was not touched before for sure and the board is very clena, no spot of corrosion at all from what I can see. Voltage on multimeter of the board off the case it's the same, 5V 0.42A. But then I noticed this "clicking sound" come from the board ( I attached here the audio file).
Looking on google I found this:... -
by Aimbitvideo: https://www.youtube.com/watch?v=S-xBu7m6SwE
Hi all. I was given this JBL Flip Essential speaker that 'fell from about 8 feet' and then the bluetooth would no longer function. It seems to power on normally and responds to button presses, but it will not showup on bluetooth for any device I try to connect to it.
The bluetooth daughter board has a 26mhz oscillator that I could not get to read the proper frequency so I tried replacing that to no avail. Thought maybe something was wrong with the bluetooth IC it's connected to, so I tried replacing that as well. None...10-28-2024, 09:29 PM -
by mrtekHi I am new to this kind of repairs but I want to learn..I have a Samsung UN65JS8500F. the TV used to work and I tried to fix darker areas in the middle only ( img 1,2,3). I thought the led strip were bad..not the case. I did not research in advance what kind and where the LED were located. In this model they are located vertically on right and left side. Took the TV apart and put it back together. Now the tv shows no welcome screen and no sound is available thru the speakers. ..just a black screen..Backlight LED do turn on...also noticed a 5 blink code , not sure if that was there before. I can...6 Photos
- Loading...
- No more items.
