Westinghouse LD-4655VX - My First LED
  • kevinm34232
    • May 2012
    • 1884
    Really?? I could not believe one little board sitting in the middle of this big panel, LOL.
    TV was dead, looks like may have been dropped. Uses external 19v power supply. When plugged into main board the voltage was dropping out indicating a short. I disconnected the 2 ribbon cables going to what Im assuming the LED lights. TV powered on. I then plugged in one at a time and the problem is the left side of screen. So TV works normally except a little dark on left side.
    The ribbon disappears through a slot in the chassis. Can the LED's be replaced?? I haven't opened it up beyond the pics..
  • ben7
    Capaholic
    • Jan 2011
    • 4059
    Re: Westinghouse LD-4655VX - My First LED
    Also it looks like there is a slightly bulged capacitor on the board too.
    I don't know if the LEDs can be replaced, these TVs are fairly new, so there is probably not too many parts out there.
    Muh-soggy-knee
    • kevinm34232
      • May 2012
      • 1884
      Found`the problem, in the lower left hand corner of the panel is the other end of the ribbon cable, it was smashed into the metal frame and the ribbon leads are all messed up and touching each other. Must have been the spot where it landed, can't believe the panel is not broken.
      • ben7
        Capaholic
        • Jan 2011
        • 4059
        Wow, you lucky duck!
        Hopefully, the ribbon will be easy to find!
        Good luck!
        Muh-soggy-knee
        • kevinm34232
          • May 2012
          • 1884
          Anyone know where Id find a ribbon cable?? I can probably run it around the bottom and right up to the main board..
          #'s on the cable are CFMG E316031 AWM 20706 60V 105C
          • cheebster
            • May 2008
            • 373
            google AWM 20706 gives quite a few results.. maybe digikey has some of those flex's ?
            how many pins, lenght ?
            • kevinm34232
              • May 2012
              • 1884
              ? Was hoping #'s would give that info, was just looking at some ribbon repair pictures.. It's not that many pins I could probably seperate the wires and tape them all in place. I'd hate to just end up selling the 1 board for this problem.
              BTW this was the easiest TV I've had to troubleshoot.
              • Mr Bill
                • Nov 2011
                • 648
                is there any slack on that cable? How many pins is it?
                • kevinm34232
                  • May 2012
                  • 1884
                  There is some slack if I reroute it. Looks like 12 pins.
                  • Mr Bill
                    • Nov 2011
                    • 648
                    you can trim the bad off and scrape the wire to expose new copper. Might not work if that cable is a press in style. Ebay has alot of these wires but all different lengths. If you can measure or guesstimate the length you can go that route.
                    • heavymachines
                      • Mar 2011
                      • 1028
                      junk laptops and other electronics have ribbons like that, pin count and minimal length is all you need to worry about if its longer it will still work i have borrowed ribbons from laptops to fix monitors before....12 pins should not be to hard to find.
                      • kevinm34232
                        • May 2012
                        • 1884
                        Mr Bill, can you elaborate? The 'bad' part is right by where it inserts into the connector at the LED connector at the panel. It seems like I'd need either a new cable or using the original cable to insert into connector and splice/seperate in wire. Both 'ends' are good.
                        Sorry for the bad pics my phone decides when to take clear pics or not.
                        • Mr Bill
                          • Nov 2011
                          • 648
                          do you want to elaborate on the scraping the old cable after you cut the messed up part?
                          • kevinm34232
                            • May 2012
                            • 1884
                            I was mistaken the LED side connector is pretty mangled, I will need a new cable. Amazingly the picture is really good with just the right side working it just fades a little dark towards the left.
                            • kevinm34232
                              • May 2012
                              • 1884
                              I was just asking what you meant to do I got the idea now...
                                Can you line up the cable next to the metric ruler so I can see the dimension and the conductor spacing?
                                • cheebster
                                  • May 2008
                                  • 373
                                  good idea !!!!
                                  i've done that before. you can use a sanding paper or a dremel on low speed but i've found sanding paper to be less destructive. tape the flat cable but leave about the lenght you need for the contact uncovered, and sand it using 180 or something, untill you properly expose the copper. then to be able to give the cable proper pressure when its in the connector, you can use the original blue plastic part you had on the connector.. rip it off and place it on the top of the cable.
                                  usually does the job did it a few times.. that's if you have enough lenght left after the cable mess !!!
                                  • cheebster
                                    • May 2008
                                    • 373
                                    if what i see is what i see, the cable is messed just at the connector so it's long enough, you can really use that cable. 10 minutes job !!!
                                    • kevinm34232
                                      • May 2012
                                      • 1884
                                      There is not enough slack to cut the cable back far enough unfortunately, here a few pics sorry I cannot get the lighting better...
                                      Are the #'s on the ribbon relevant to the # of leads and spacing??
                                      • kevinm34232
                                        • May 2012
                                        • 1884
                                        It looks like this is the cable I need, it's 12 pins and measures 7mm wide like mine.
                                        http://cgi.ebay.com/ws/eBayISAPI.dll...#ht_1114wt_934
                                        However, it's not long enough. Wondering if there's a simple female to female connector that will connect them both together??
                                        I need a 2-3' cable, 70-80cm or anything close..
                                        • scubacamper
                                          Sharp Aquos LC-70C6400U Half Screen Dark
                                          by scubacamper
                                          I found another post on this site the other day which has been very helpful in troubleshooting this issue I am having with my tv. The left half of the screen is dark, and the other half is VERY slow to generate it's image - and it only generates part of its image at that.
                                          Based on this yt video, I have narrowed it down to an issue (short?) on the left side of the display, somewhere in the system of ribbon cables.
                                          when I remove the bezel and the rear cover, I can get the image to display correctly by manipulating the ribbon cables on the left side which connects the left lower display...
                                          05-03-2025, 12:19 PM
                                        • Shinju
                                          Razor Blade Steath 13" RZ09-01963 plugged in Not Charging (new battery)
                                          by Shinju
                                          Hey All!
                                          Long time forum member here with a problematic laptop issue!
                                          I got a RZ09-0196 with a bloated battery (still worked and charged fine) I pulled the old cell pack out and installed a new cell pack in its place.
                                          The laptop would not power on with the new battery installed without the power supply being plugged in.
                                          When booting into Win10 (all up to date BTW) I saw the battery icon with 49% plugged in not charging.
                                          TL;Dr version, old battery worked, charged but was bloated, installed a new non OEM replacement, laptop/windows...
                                          10-20-2021, 04:58 PM
                                        • torchzack
                                          Samsung 55" TV - Boot loop but sometimes works fine - UE55MU6470U
                                          by torchzack
                                          Hi Team - just joined to see if anyone can offer some expertise in diagnosing an issue with a TV.
                                          I've done a few hours googling and youtubing but just seeing if anyone has any insight here. I got a 55" Samsung UE55MU6470U which seems to boot loop and then after 10 mins will boot, work for a few minutes, then turn off and repeat.
                                          Whilst it's on into the normal Samsung menu/boot screen it looks perfect - so I can't see there being any screen issues. I've seen lots of videos with taping across clock lines to diagnose which particular one may be an issue but i don't...
                                          08-28-2023, 07:42 AM
                                        • karatzdi
                                          Denon AVR 1908, High pitch noise on Surround back Left channel after long overhaul
                                          by karatzdi
                                          I know some might say... just buy another one. Sell it as parts..!
                                          So had this AMP for quite some time. Recently I saw light smoke coming out of the AMP. Had my fire extinguisher close by. Just kidding. Turned immediately all devices off from mains.
                                          Let things cool a bit, and opened up the amp device. I clearly saw on the main board which hosts the 5X amp (5.1), 3 10 ohms 1W resistors had their leads looking black, while the rest of the remaining 2 x 10 ohms were brownish as being installed from factory.
                                          Spent some time downloading the Service...
                                          06-11-2024, 08:38 AM
                                        • jchang
                                          Samsung UN70NU6900F no picture and no sound
                                          by jchang
                                          Hi all
                                          I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
                                          Symptom:
                                          No picture no sound.
                                          When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
                                          No sound at all.
                                          What I tried:
                                          1. I tried unplugging the left or right ribbon...
                                          01-09-2023, 06:28 PM
