Dell 5580 - Bios/ Clean ME la-e152p Rev:1
  • Gerry68
    • Jul 2015
    • 10
    • germany
    Hello I need clear ME from my bios DELL 5580 LA-E152P rev 1.0
    could someone do it and help me?
    Many Thanks
  • Mazorca
    • Jan 2017
    • 463
    Re: Dell 5580 - Bios/ Clean ME la-e152p Rev:1
    Try this one and report back.
    • Gerry68
      • Jul 2015
      • 10
      • germany
      Hi
      Thank you it worked perfectly
      • Rebeli
        • Jun 2014
        • 3
        • Finland
        Dell Latitude 5580 LA-E152P BIOS
        Dell Latitude 5580 LA-E152P Rev 1.0. Board with Nvidia 940MX GPU.
        Aynone have working BIOS dump for these? Only one I found that works (and updates correctly) but fan's don't spin (ME region issue?) was from this post: https://www.badcaps.net/forum/showth...light=LA-E152P
        Some background:
        I have bunch of these laptops and some of them have a following issue; BIOS (and TPM) won't update and the laptop just restarts after trying (doesn't work from USB stick either).
        Tried to copy BIOS from another machine but the laptop wont even start after (no power). Can someone explain why this doesn't work? The BIOS versions are identical.
        In the attachment are two BIOS files from 2 different laptops. Version 1.30 works fine and was updated from earlier version. Version 1.24 wont update, and wont work if I use BIOS from another 1.30 laptop (or 1.24 for that matter). Service tags are in the folder names.
        Any help would be appreciated.
        • wzamoyski
          • Mar 2022
          • 28
          • Poland
          Hello
          I need help with BIOS (fix/clean):
          • Dell 5580 Latitude
          • CDP80 LA-E152P Rev. 1.0 (A00)
          • ST: B8416H2
          Original BIOS is corrupt - no fan, no working, black screen (attachments).
          Laptop working fine with BIOS in this topic:
            SMDFlea commented
            Editing a comment
            Thread merged with existing topic.No need to start a new thread....
        • karem adel
          • Jan 2023
          • 26
          • United Arab Emirates
          LATITUDE 5580
          CDP80 LA-E152P REV1.0
          ifx graphics
          • techrecycle
            • Jan 2024
            • 64
            • england
            hi everyone, needs TPM error
            SN: GMMKFH2
            THANKS in advance,,
            • testinglaptops
              • Oct 2022
              • 86
              Thank You Worked For Me 100%
              • Bowayne
                • Sep 2019
                • 40
                • South Africa
                Please assist with bios
                CDP80 LA-E151P
                REV 1.0 A00
                LATITUDE 5580
                SERVICE TAG CF94FH2
                ATTACHED BIOS
                NO POST , JUST SCREEN BACKLIGHT. CLEAN ME PLEASE
                • hardware1
                  • Sep 2021
                  • 2949
                  • N/A
                  CDP80 LA-E151P
                  REV 1.0 A00
                  LATITUDE 5580
                  SERVICE TAG CF94FH2
                  ATTACHED BIOS
                  I found this Service Tag in your file "5094JM2". Are you sure it's your original BIOS?
                  Your file isn't good, which SPI programmer do you use and do you a clip/clamp or de-solder the chip outside the motherboard?
                  What is your actual CPU because this laptop can be with H or U CPUs.
                  all donations are welcome,
                  • gizaha
                    Dell Latitude 5580 possible bios corruption
                    by gizaha
                    Dell latitude 5580, motherboard cdp 80 la-e151p
                    3 amber 3 white blinks. Dell website sais it's problem "bios recovery" and suggested solution "recovery image not found"
                    (from here https://www.dell.com/support/manuals...e7a&lang=en-us)
                    I try plugging charger while pressing ctrl+esc, machine turns on, nothing and after 20 seconds it gives 3 amber 3 white blinks again.
                    Since ssd is replaced and had clean install windows, i've...
                    02-13-2024, 07:18 AM
                  • zenius
                    by zenius
                    12-08-2024, 06:13 AM
                  • mikeybass
                    Dell 9010 MT BIOS Update Always Fails
                    by mikeybass
                    Hi, I hope some one has some advice for me. I searched the forums but didn't see anything relevant. I acquired two identical Dell 9010 Mid Tower computers from a business office upgrade (they were going to throw them out). Both of them have the same motherboard (00F82W). One of them works flawlessly. The other one had a corrupted BIOS. I tried flashing numerous main BIOS and EC files from the internet, but none of them worked. I decided to copy the main BIOS and EC from the working 9010 computer and successfully flashed the corrupted BIOS. This got the computer able to boot again and run norm...
                    04-23-2025, 04:30 PM
                  • capoplays
                    Help with BIOS update on Dell G15 5515 after chip replacement
                    by capoplays
                    Hey everyone,
                    I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
                    The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
                    When I check the BIOS using the F12 menu Flash...
                    10-24-2025, 06:53 AM
                  • Akhlz001
                    Dell Pro 13 Plus PB13250 Bios Unlock
                    by Akhlz001
                    Could someone help trying to unlock this BIOS, seems that Dell have changed the layout of new Dell Pro 8FC8 bioses from checking HXD - 4000 bits do not need changing, only 2000. However after FF the section starting from '01000' upto 2000 bits and then soldering the chip back it seems that the microchip on the motherboard is recovering the bios back to original settings after first boot. Has anyone found a way to crack this extra layer of security Dell have implemented? Seems both HP and Dell have upped bios security to match Lenovo by implementing extra measures on a separate...
                    09-20-2025, 07:15 PM
