LG LED TV Model 42LE5300 not switching on
  • angelos
    • Dec 2012
    • 573
    • South Africa
    Hi Guys,
    I have another unit that's beating me up here.
    This set starts up and is in standby mode. Upon pressing the power button the set makes a relay clicking sound and then the on board "piezo speaker" which sounds when pressing any of the on board buttons starts making a long beeping sound. In the mean time the secondary voltages (those that should start up when pressing the power button) do not come up.
    This is my findings so far.
    1. When adding a 680 ohm resistor from +3.5V rail to the "Power ON" pin to force PSU secondary voltages on my PFC circuit does work because my mains smoothing cap voltage goes from 330VDC to 393VDC.
    2. The power supply section responsible to generate the secondary voltages is operated by a L6599D. I scoped the gate drive pulses on switch on and i could briefly see some square waves but it shut down.
    3. I then checked all secondary diodes for short. Only thing i saw was the Schottky diode is leaky in reverse bias but that's normal.
    4. I replaced L6599D with no difference
    5. I checked opto coupler and zener on the feedback circuit and found no fault. There is however a SMD chip with a marking "438" which is 3 pin and might be a SMD type KIA431, not sure could not test.
    I have added pictures as needed to assist you in your diagnosis.
    All tests above were done without the main connected and PSU forced on.
  • angelos
    • Dec 2012
    • 573
    • South Africa
    Re: LG LED TV Model 42LE5300 not switching on
    I have added the PSU to main plug voltages whilst all boards connected and wrote down both standby and power on voltages
    • angelos
      • Dec 2012
      • 573
      • South Africa
      Any help would be greatly appreciated.
      • angelos
        • Dec 2012
        • 573
        • South Africa
        looks like i will be forced to order the complete power supply. 51 Views and no response must mean a real head scratcher.
          • 12284
          • U.S.
            So PS-ON is present (3.38V) and the PFC Boosted Voltage is also present, correct?
            But the rest of the power supplies come on. So all the fuses on the board are good?
            You also do not have DRV-ON (BL-ON), Dim controls.
            • angelos
              • Dec 2012
              • 573
              • South Africa
              Hi Budm, yes the PS-ON and boosted voltage is correct (PFC = 390V). I dont get the other voltages that are 12V, 20V etc coming from those two transformers that look identical.
              There are 3 fuses all measuring correct.
              I do not get the DRV-ON from the main (perhaps as a result that the 12V does not start up to feed the main???)
                PS-On signal is response for turning on the PFC, the switched 12V, etc. so we need to find out why those two large power transformers are not being driven.
                Is the L6599D getting the VCC Voltage to run?
                What Voltages do you have on Q102, 103 pins?
                Is R219 OK?
                Is C114 OK?
                Also check the resistance of R115 ~118 which are for Line sense on pin 7 of the IC that monitor the PFC Voltage, it will shutdown the IC if it thinks that PFC Voltage is too low, but isnce your PFC Voltage is OK but the resistors have drifted up in value then that will cause the problem, look at the spec sheet of the IC as to how pin 7 functions and what Voltage it should have on that pin.
                LG EAY60803201 (YP42LPBL) Power Supply Unit.
                Pictures provided by shopjimmy.
                • captainKKK
                  • Sep 2018
                  • 287
                  Looks like C256 and R259 have heat damage?
                  • angelos
                    • Dec 2012
                    • 573
                    • South Africa
                    Is R219 OK?
                    Is C114 OK?
                    I will check this afternoon and get back to you. Thanks.
                    • angelos
                      • Dec 2012
                      • 573
                      • South Africa
                      Thanks CaptainKKK will check those two components as well this afternoon.
                      • angelos
                        • Dec 2012
                        • 573
                        • South Africa
                        Hi CaptainKKK,
                        Cap C256 is a 47uf 25V cap measuring 48uf and ESR of 0.5 ohms
                        R259 is a 10 ohm and measures 10 ohms. Some of these resistors have a dark background color, even on the shopjimmy photo of the same PSU they are darker.
                        • angelos
                          • Dec 2012
                          • 573
                          • South Africa
                          Is R219 OK?
                          Is C114 OK?
                          Hello Budm, i checked the following,
                          1. Is the L6599D getting the VCC Voltage to run? Yes 13V on the VCC pin.
                          2. Resistors R115~R118 each measure 1 Mohm as indicated on resistor.
                          3. What Voltages do you have on Q102, 103 pins?
                          Q102 G = 0V, D=390V, S = 0V
                          Q103 G = 0V, D = 0V, S = 0V
                          4. Is R219 OK? Its a 1 Mohm res measures ok.
                          5. Is C114 OK? Bingo...................... Measuring in the picofarads.
                          This is a 203J 800V cap. I assume 20nf @ 800V. I need to find a replacement
                          and i am wondering if this will be the only fault. Anything else i must check for? The mosfets measure fine. If i trigger them the Drain - Source goes short and if i Short all three legs then Drain - Source goes open circuit.
                          Thank you for your guidance thus far.
                          Awaiting your response before i put in this cap.
                          • angelos
                            • Dec 2012
                            • 573
                            • South Africa
                            Just an update...
                            I put two 10nf 2kv caps in parallel and wiggled them in so that they fit and voila... The set is working and on test.
                            Thanks Budm, i am so chuffed about this repair. That cap has no signs of failure.
                              Glad to hear, that dc blocking/coupling cap is one of the commonly fail cap in that circuit.
                              • Unspun01
                                • Jun 2011
                                • 349
                                Glad to hear your TV is now working after replacing that bad capacitor C114.
                                In case anyone else finds it useful, I wanted to mention that I had resistor R103 (3 ohm, big black rectangle) fail open on one LG power board I worked on with no power.
                                L6599 IC is also a good candidate to check/replace.
                                  That R103 (in series with TH101) will go open circuit if the bypass relay RL102 is bad, I.E. bad contact, so it is not bypassed by the relay.
                                  • Unspun01
                                    • Jun 2011
                                    • 349
                                    Hi BudM:
                                    Thanks for weighing in. I have no idea what it was for, but R103 was completely open (not 3 ohms) so I replaced it and a few other components. I don't know if R103 being open would prevent the TV turning on, but it was part of my troubleshooting.
                                    What is the purpose of the bypass relay?
                                      The resistor and the TH (NTC) are for inrush current limiting when TV is first on and they need to be bypassed by the relay once the TV is on, if they are not bypassed then resistor and NTC will run hot, that resistor has built-in thermal fuse and it will go open circuit if it gets too hot. You can verify if the relay contacts are goo or not by taking the AC Voltage reading between the two legs of the Resistor and the TH, it should be 0 VAC if the relay is working. This also common problem with Sharp TV's also.
                                      • Unspun01
                                        • Jun 2011
                                        • 349
                                        Would R103 prevent the TV from turning on? It was bad, but it was not the only part I replaced so I don't remember if it was a cause, or collateral...
                                          by sam_sam_sam
                                          03-31-2024, 02:12 PM
                                          by sam_sam_sam
                                          After all of...
                                          07-13-2024, 08:14 PM
                                          by sam_sam_sam
                                          07-01-2024, 06:34 AM
                                          DVR camera recorder switching power supply capacitor failure really
                                          by sam_sam_sam
                                          These cheap non brand capacitors at it again
                                          Last night we had a power outage [ long drawn out trying three to come back up before going out completely ] and when I went to turn the DVR camera recorder back today no go 3 bad capacitors ( one capacitor no ESR reading on DVR board the other 3 capacitor on the power supply board over 40 ohm this is not a misprint ) on the external switching power supply and one capacitor on the DVR camera recorder board where the power supply that goes to the hard drive disk is
                                          Well at least I have the cameras back on line I to try the...
                                          01-22-2022, 06:28 PM
                                        • michel74
                                          How does this switching PS work ?
                                          by michel74
                                          Yes ! How does this switching PS works ? :-)
                                          I understand (not in deep, of course) the switching PS principle; typically, I'd expect to get a VCC just to "feed up" the STR or the Switching regulator, but I cannot figure how this VCC is "created" (on a TV switching PSU, I often see some cascaded resistors, but here, I believe that one of the transformer input should make the permanent VCC, but I cannot figure where )
                                          Thanks for your help. I already wrote some explanation of what I was having and did some measurements here ...
                                          11-02-2023, 12:35 PM
