Money for scrap computers and copper heatsinks
  • Uranium-235
    Comrade Glimmer
    • Aug 2007
    • 5042
    • US
    Has anyone ever gone down this road? I have a number of copper (and copper plated :/ ) and aluminum heatsinks. As well as full computers. Ever heard of any companies that will buy them off me (for not that much probably). I've been sending them to e-recycling
    I kept a beige taaaaall antec case, going to try TC's yellowing remover and try to create an old system. Probably multiboot with DOS and 98 and 2k to cover all my bases
    Maybe even use a certain Voodoo5 card in it
    • 31247
    Re: Money for scrap computers and copper heatsinks
    metal recyclers publish their prices for different metals - you work out if it's worth your trouble
    • diif
      • Feb 2014
      • 6978
      • England
      They sell on ebay for more than scrap.
      • dmill89
        • Dec 2011
        • 2534
        ^This, steel isn't worth much (generally not enough to justify the cost of driving to the scrap yard unless you have a whole truckload of it), copper and aluminum are worth substantially more, but you'll still generally need 100 lb.+ to make it worth your while (unless the scrap yard is really close). Plastics and circuit boards have no value to the scrap yard, and "mixed metals" are generally priced at the value of the lowest-cost material (so something like a transformer with copper wire around an iron/steel core would need to be disassembled to get full value for the copper components).
        ^Also this, but of course for relatively "low-value" items you have to determine if the profit margin is worth your time (i.e. is it worth spending an hour listing something, packing it, and shipping it to make $5 or $10).
        • petehall347
          • Jan 2015
          • 4440
          i was breaking computers years ago and got good money for it ..processors were the best . a little bag of them was the best . then the motherboards after i had removed the steel parts . they stopped taking them in . i think they soon realised with the later processors the gold content was substantially less than it was . and the gold fingers on the boards .
          • Xenon-Codex
            • 186
            • Finland
            I got $20 for a couple of copper pipes. Clean copper was 9$/kg a few months ago, not that much anymore. Motherboards etc. $0,40/kg.
            • Topcat
              The Boss Stooge
              • Oct 2003
              • 16958
              None of the scrap yards even take plastics anymore unless its soda/water bottles, soap/detergents/shampoo bottles, and other normal household stuff..... I can toss all the plastic I want in my commercial dumpster....but it still pisses me off that they won't take it; even for free....I don't want money for it, I just need to get rid of it....but cringe at the thought of it going to the landfill...but I have no other choice.
              They do pay for electronic scrap (raw boards), more for older stuff than newer....I do separate it for this reason. I fill a few gaylords up with various boards; usually making a e-waste trip once a year. For intact but worthless electronics (printers, keyboards, cables, mice, etc) I don't break those down, I just take them over to the recycler and give them away....
              I never bothered with copper & aluminum in the form of heatsinks.....it takes a shitload of them to amount to anything....
              Steel OTOH, while not too terribly valuable,I fill a junk car up with all the scrap steel and broken glass I can cram in it....and when it won't hold anymore, off to the steel recycler it goes. Old metal TV backs are great for using self-tapping screws on to batten down a load!!
              <--- Badcaps.net Founder
              Badcaps.net Services:
              Motherboard Repair Services
              http://folding.stanford.edu/
              Team : 49813
              Join in!!
              Team Stats
              • desert-rat
                • Mar 2014
                • 4103
                There is not enough metal in a pc to be worth much . There is a method of getting the gold out of electronic items . I dont know if there is enough to be worth the effort . I have sold scrap copper and a/c parts from when I was a kid (mid 70s) . You can make a few bucks when the market is good .
                • kasfamily
                  • Aug 2014
                  • 774
                  • Russia
                  The old Soviet equipment contains many different precious metals, for example, capacitors-
                  • brethin
                    • Dec 2008
                    • 1907
                    At one point in time many years ago scrap was worth the effort, in today's thow it away culture it's not sadly.
                      by momaka
                      03-15-2023, 10:17 PM
                    • rictechie
                      copper pad in board peel off
                      by rictechie
                      Hi I'm newbie when it comes to electronics repair. My copper pad where my diode sticks has peeled off what is the most efficient way to make the copper pad stick to the board? epoxy? ink mask? I want to hear your suggestions
                      07-20-2024, 11:49 PM
                    • technicalspecialist
                      Vintage fan repair, copper wire question
                      by technicalspecialist
                      I currently have a customer's vintage fan on the work bench to repair.
                      It uses an induction motor with 4 poles. One of the poles is open.
                      I couldn't find the break so i cut off the original wire.
                      I have measured the other poles and the resistance is about 28 ohms per pole and I measured the diameter of the wire with my digital calipers and it is 0.35mm in diameter.
                      I need to work out how much 0.35mm diameter enamelled copper wire i need to order for it to be 28 ohms. I have used this calculator and it says i need 160.35 metres.
                      The enamelled copper...
                      03-16-2023, 12:54 PM
                    • Pawel Borowski
                      Solving Razer Blade 14 (2022) RZ09-0427 from scrap.
                      by Pawel Borowski
                      Hi folks,
                      I want to solve a Razer Blade 14 (2022) RZ09-0427 with Ryzen 9 6900HX and RTX 3070Ti from scrap, and I need your help with the diagnosis.
                      I have checked (I hope) all the voltage rails and found no shorts to GND and B+ except for the CPU VDDCR_SR rail (see the photo), which is near zero ohms to GND.
                      When plugged to PS, the laptop charges the battery, and after pressing start, it supplies voltage to all voltage rails except for CPU VDDCR_SR one and, of course, the dGPU, nothing more.
                      I have no experience in this type of repair, so please let me know if the low resistance...
                      05-05-2025, 07:37 AM
                    • mecha1166
                      Copper corrosion? Yamaha HS8S Audio 1 output only
                      by mecha1166
                      OAUD Yamaha HS8S Audio one output only.
                      I have pulled the output board. Output txsistors are ok (only 2 main output). Everything measures the same on each side. Customer did not bring in speakers so I cannot go too deep. I did notice a greenish tint on the tip of the solder joints that connect to the COPPER output connectors. All 6 have a greenish tint at the tip - each side has 3 pins each. Anyone else have copper speaker output pins that corrode at the place on the PCB where they are soldered? I will try to add a photo. Thanks.
                      08-04-2023, 02:55 PM
