HP ZE4500 modem driver
  • stevo1210
    • Oct 2006
    • 4156
    I traded my friend an ATi X300 128MB graphics card for his HP ZE4500 (sticker on base says ZE4523AP) laptop today. It works perfect in every way... except it's missing a battery and the power port is a tad loose and can be a pain sometimes.
    Anyway... I need the driver for the internal 56K modem and I can't find it on any HP site.
    This makes me wonder... why the hell does HP have to make my life so hard? Why can't everyone be like Dell or Toshiba and actually offer all the drivers and revisions of drivers? >_<
    Thanks.
  • Scenic
    o.O
    • Sep 2007
    • 2642
    Re: HP ZE4500 modem driver
    ftp://ftp.hp.com/pub/softlib/softwar...en/AKARH00.exe
    ^ driver package for ZE4000 series
    as for toshiba.. dunno where the problem is? easier than HP at least
    http://eu.computers.toshiba-europe.c...jsp?service=EU
    edit: modem driver directly from conexant
    http://www.conexant.com/support/files/HSFac97_WinXP.zip
    driverguide site has drivers for this specific laptop, but requires to register a free account there (which in turn spams your email)..
    • stevo1210
      • Oct 2006
      • 4156
      LOL i did say that Toshiba is much easier than HP up there somewhere haha.
        • 30997
        if by power-port you mean the charging soket,
        resolder it, or it will burn - and maybe burn the pcb too.
        this was very common on the old mac laptops with the fantastic coloered clamshell cases.
        • stevo1210
          • Oct 2006
          • 4156
          yes, that's it, the charging socket.
          I looked in the *hole* bit and the prong on the side is perfect and the stick bit in the middle is also fine... I don't know why it keeps losing power everytime I move the cord.
          Would I need a new socket? or has a solder joint broken in there?
          • stevo1210
            • Oct 2006
            • 4156
            Oh yes, where can I get a disassembly guide for this laptop?
            • stevo1210
              • Oct 2006
              • 4156
              okay, tried google... no help for a service manual or disassembly guide...
              How the hell am I gonna open this thing without breaking it?!
              • stevo1210
                • Oct 2006
                • 4156
                Actually... found this on the HP site...
                https://cdn.badcaps-static.com/pdfs/...ce36d25d29.pdf
                  • 30997
                  o.k. you make an interesting comment.
                  it could be bad soldering holding the connector to the board,
                  but it could be a broken wire where it enters the back of the plug.
                  can you lay your hands on another supply or something to plug yours into to test?
                  • PCBONEZ
                    Grumpy Old Fart
                    • Aug 2005
                    • 10661
                    .... or it could be a broken wire in the power brick.
                    Mann-Made Global Warming.
                    - Dr Seuss
                    • stevo1210
                      • Oct 2006
                      • 4156
                      i used a multimeter plugged into the plug bit of the wire... Twisted the wire and what not with no loss of voltages.... So i think it's the socket.
                      • kaniki
                        • 514
                        That is true.. there is a solid wire that runs down the back of the jack that is not flexible. if it get stressed too much, it just breaks in half. i have run into this before. I did not have a replacement jack to i just soldered the connection back together.
                        Jacks usually are soldered to the board by 4 prongs, one in each corner of the jack and are soldered through the motherboard. they do come free once in a while, especially if they do that electrostatic type of soldering, because there is not much solder there and just enough to hold it in place, and can break free over time. But there is also the possibility that the wire comes looses and break free from the center power part of the plug/jack, which in a case like that, the only thing you can do is replace the whole jack.
                        one other thing you can check.. see how the connectors are. I have seen some that have had a little bit of build up of dirt on the spring part of the jack that connects with the outside part of the power cord connector. or that the spring part in the jack did not have enough spring to the metal and would loose connection too. those two things, i would just scrape the top of that spring part to give a clean surface for good connection and then try to stick something under the spring steel and try to pry it up a little (using something like a pick or something long, thin, and with a point) so that it puts more pressure against the power cord when you plug it in.
                        • stevo1210
                          • Oct 2006
                          • 4156
                          Yup, it's a broken solder joint alright.
                          Since I haven't used a soldering iron for two years or so, I had a few problems figuring out how to apply solder lol.
                          The first two times I had cold joints so I was like WTF?
                          Then I realized I had the solder tip on the metal prong instead of the base *solder hole*... so only the prong was getting hot and the solder hole base was still cold lol.
                          Out came the soldering wick twice and now I have a nice, shiny solder joint.
                          • stevo1210
                            • Oct 2006
                            • 4156
                            Everything is back together and I'm glad to say the problem is solved and the lappy works perfectly!
                            • osrex
                              LED DRIVER KEEPS DYING
                              by osrex
                              Hello, this is my first post and im just a beginner, so be easy on me guy. thanks
                              i have a LED chandeilier that switches colors from white to cool white to warm when toggling the switch, it has 24 LED arms, each arm is 30 CM length.
                              i have no datasheet at all for the LED lights, all i have is its length.
                              long story short, testing the chandelier on the ground, and it works fine for 1 - 2 - 6 hours, no problem.
                              as soon as i fix the chandelier to the ceiling and bury the driver inside the hub,...
                              05-05-2025, 03:36 PM
                            • howardc64
                              Vizio E55-F1 dark backlight zones. LED failure or Dimming Zone Driver?
                              by howardc64
                              Problem
                              Fixing a dimming zone TV with LEDs not lighting up. Dimming zone circuit introduces added variable to diagnose LED and/or Dimming Zone Driver board? Some 1/2 rows of LEDs appears to be out in active dimming zone off AND some brightness flickering with active dimming zone high while playing changing video
                              Model & Board Pics
                              Conflicting Spec
                              Vizio indicate this TV has 10 dimming zones. However, LED strips and Zoned light driver connector suggest 12
                              https://www.shopjimmy.com/vizio-gj-2k1...
                              10-10-2024, 01:16 PM
                            • charif
                              Audio Driver for Thomson P14C4BK128
                              by charif
                              Need Audio Driver for Thomson P14C4BK128 (Windows 10/11)
                              I'm looking for help finding the correct audio driver for my Thomson P14C4BK128 laptop.
                              The sound is not working properly, and I believe the audio driver is missing or not installed correctly.
                              Here are the details:
                              • Model: Thomson P14C4BK128
                              • Operating System: Windows 10 64-bit
                              If anyone has a working link to the driver or knows where I can download it, I'd really appreciate it.
                              Thanks in advance for your help!
                              04-30-2025, 05:41 PM
                            • Daveleone
                              UN55D6900 BN44-00428B partial led driver circuit failure
                              by Daveleone
                              Hello TV experts! I have a UN55D6900. The successfully TV turns on, and the backlights light up, and I get a picture, but there is a section that is dim. I took it apart and 1 out of 4 segments of backlight LEDs are not lighting on both sides of the TV (in other words, the same segment is out on both LED strips).
                              I tested the LED strips with my LED tester and all of the LEDs light properly, so I believe the problem is with the PSU/LED driver board (BN44-00428B). The voltages at CNM810 (between PSU and main board) look ok to me. The voltages at CNL801A and CNL801B look off for one...
                              07-23-2021, 06:31 PM
                            • master3112
                              Lenovo T480 NM-B501 no picture
                              by master3112
                              I have a T480. After pressing the power button, the device boots up. I can hear the Windows welcome melody. However, the screen remains black.
                              The device has a CPU with an integrated GPU. If the device is switched on briefly without the CPU cooler, only the CPU core area heats up under the thermal camera. I measured the PU402 and PU403 inductors. These are responsible for the core voltage. I have 1.1V at these. Everything is OK, therefore the device starts up.
                              But I have 0V at the PU404 inductor, which is responsible for the GPU voltage. The power management of the CPU is solved using...
                              03-04-2025, 04:19 PM
