Turn 7 into Xp...sort of....
  • Junk Parts
    Court Jester
    • Jun 2006
    • 8953
    Changing the Windows 7 Taskbar to XP/Vista Style
    To revert back to the older style, the first thing you'll need to do is
    right-click on any open area of the taskbar and choose Properties from the menu.
    From the Taskbar buttons drop-down menu, you'll want to choose “Never combine”,
    which will make every window show up as a separate button on the taskbar, or you
    could choose “Combine when taskbar is full”, which does just like it says.
    Now you should see the buttons show up with text labels like you are probably
    used to… but in the Windows 7 style.
    If you chose the “Use small icons” checkbox in the properties screen, the
    taskbar will actually shrink down to look very similar to Vista.
    The only problem is that the “pinned” icons are still sitting on the taskbar,
    which isn't the same as Vista or XP, but you can easily remove all of them by
    right-clicking and choosing “Unpin this program from taskbar”.
    And now the taskbar looks and works very similarly to Windows Vista:
    If you wanted to be really silly, you can choose the “Windows Classic” theme
    under the Desktop \ Personalize section… but that would be taking it a little
    too far, I think.
    I strongly urge you to at least give the new Windows 7 taskbar a try… it takes a
    little getting used to, but it's really a nice move forward. Does the new “dock
    style” taskbar work for you? Tell us in the comments.
    | More This article was originally written on 01/20/09
    " Tried it and it works!" I love good old Xp. 7 is ok but this is the fix I was looking for. Now 7 works or doesn't work how ever you look at it just the way I wanted it to.
    Mark Twain
    John Paul Jones
    Rod Serling
  • kikkoman
    • Jul 2007
    • 691
    Re: Turn 7 into Xp...sort of....
    but i love the 7 taskbar!
    i HATED the combined tabs in XP but the preview in 7 totally makes up for that.
    i'm not sure if it works if you don't use Aero though.
    "Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin slitting throats." - H.L. Mencken
    • Junk Parts
      Court Jester
      • Jun 2006
      • 8953
      I don't need a fancy OS. I'm only on 7 right now because my Xp install on the other hard drive is broken. I'll fix it some day soon. All this thing is used for is the net and burning DVD's. Xp is fine for this.
      Mark Twain
      John Paul Jones
      Rod Serling
      • Krankshaft
        • Jan 2007
        • 2328
        I was annoyed with the Windows 7 start menu at first but I love it now.
        Especially the search menu in every folder makes it a snap to find certain files quickly.
        I still hate how they restructured the control panel though. Like how Add/Remove Programs became Programs And Features. Sure just make a simple function sound as vague as possible.
        • c_hegge
          • Sep 2009
          • 5219
          Junk Parts, Have you found a way to revert back to XP's memory usage? (~180MB for a new install of XP vs ~800MB for windows 7 or ~1GB for vistrash)
            master hoarder
            • May 2008
            • 12175
            Originally posted by Junk Parts
            If you wanted to be really silly, you can choose the “Windows Classic” theme under the Desktop \ Personalize section… but that would be taking it a little too far, I think.
            Actually, if I was to get Windows 7 for my computers, one of the first things I would do is set it with the Windows Classic theme and turn off all animations and other flashy stuff. Not that I don't like the Win7 style (I do), but I still prefer the simpler look of Windows Classic theme (it saves a lot of resources, too).
            • kaniki
              • 514
              but was not as bad as vista.. i tried that for about 1 day and hated it so bad that i never used it again.. and that was after i turned UAC off too.. that was one of the most annoying features i have ever seen.. 7 i like though.. just some minor things like some things that you can not get to without the search feature or really digging.. and example of that would be the power management console.. One thing i did find with 7 that i did not like. the way that UAC control works. If you have a program that does not work, or should i say made for 7, (looking at self extracting programs), if you dont turn off UAC in 7, a lot of programs when you try to install them, then extract, then nothing. UAC keeps them from going any farther. Turn off UAC, and they install fine though.. They should have made UAC work better with older self extracting programs.
              For those that dont know, UAC = User Access Control and can be found in the user accounts settings.. both on vista and 7
              • Junk Parts
                Court Jester
                • Jun 2006
                • 8953
                Here we are again at Xp vs Vista vs Windows 7. Meanwhile back at the Ranch The Evil Gates Gang is hard at work on Windows 8.
                Mark Twain
                John Paul Jones
                Rod Serling
                • ratdude747
                  Black Sheep
                  • Nov 2008
                  • 17136
                  i put in a vote for ubuntu
                  sigpic
                  (Insert witty quote here)
                    • 31094
                    or any other Linux distro.
                    my order of (personal preference)
                    Mandriva
                    SuSE
                    • reformatt
                      Windows 11 Start menu/Taskbar hanging
                      by reformatt
                      Couple of Windows 11 machines have come in this week with the same issue. After you login, the taskbar will not appear (or just be a black bar). No access to Start Menu. Task Manager (use CTL+SHIFT+ESC) works, however the Performance stats seem stuck with CPU on 100% for Task Manager itself. Trying to exit Task Manager result in it hanging as well. No issue if you boot into Safe Mode.
                      First machine, tried many things to no avail (System Restore from last Windows update, rebooting in Diag mode, trying to reinstall Windows Apps via Powershell). In the end, I did an in-place upgrade...
                      04-23-2024, 10:16 PM
                      LENOVO ThinkStation ThinkStation D20 (415518G), UK ThinkStation D E5520 Specification for Upgrade or Repair
                      This specification for the LENOVO ThinkStation ThinkStation D20 (415518G), UK can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ThinkStation ThinkStation D20 (415518G), UK boardview and ThinkStation ThinkStation D20 (415518G), UK schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                      09-12-2024, 03:36 PM
                      LENOVO ThinkStation ThinkStation D20 (415521G), DE ThinkStation D E5506 Specification for Upgrade or Repair
                      This specification for the LENOVO ThinkStation ThinkStation D20 (415521G), DE can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ThinkStation ThinkStation D20 (415521G), DE boardview and ThinkStation ThinkStation D20 (415521G), DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                    • Kambi13
                      HP Deskjet 3720 power light flashing and LCD with all icons flashing as well
                      by Kambi13
                      Hello all need some help, I've got a Deskjet 3720 that turns on but everything is flashing, power light and everything on the lcd also is flashing. There's no paper jams or anything like that, printer is clean inside
                      12-02-2023, 05:26 AM
                    • ciferluis
                      old HP PRESARIO CQ60-202EL with Vista O.S.
                      by ciferluis
                      HI guis ! I've and old HP PRESARIO CQ60-202EL with Vista O.S. I tried to update it to WIN 7 ultimate but when i try to install, it show to me this message: "Windows cannot be installed on a battery-powered computer. If battery power runs out during installation, some data may be lost. To continue the installation, connect the power supply." Infact, battery level 67% signs that is running without beeing charging. But the power supply led is white and cable gives 17,34 ouput DC Voltage. When i try to enter BIOS with F10 key, F10 key not works ! Only F9 key works (change hdd, dvd or usb...
                      04-12-2021, 03:37 AM
