Can SSD Password be recovered from BIOS bin?
  • ajithpoison
    • Aug 2021
    • 8
    • India
    Recently a friend of mine bought in a Panasonic toughbook CF-54 with a locked BIOS. I was able to unlock the BIOS with the help of good samaritans here. After unlocking I realized that there was an SSD password. Before unlocking the BIOS, when I switch on the laptop, it would boot into a custom windows 8 with preloaded software without asking for any ssd password. Now I did not know the password and as it was urgent, I bought him a new ssd and sent him his way home. Now I have the old ssd with the password. (Attached the picture). I inserted this SSD into an old dell laptop and it prompted me for the SSD password which I do not know. The ssd does not have PSID to do a PSID revert. I also tried the HDPARM method but it failed. I have the copy of the locked BIOS bin with me (Attached the bin). Is it possible to retrieve the password from the BIOS bin? Is there any other method to unlock the drive? I don't need the data. I just want to make the drive usable again.
  • TechGeek
    Computer Geek
    • Jan 2015
    • 2254
    Re: Can SSD Password be recovered from BIOS bin?
    What errors do you get when you try to use the hdparm method?
    Permanently Retired Systems:
    Kooky and Kool Systems
    sigpic
      • 31026
      although a password could be in the UEFI partition, it's more likely to be in the TPM eeprom
      • ajithpoison
        • Aug 2021
        • 8
        • India
        SG_IO: bad/missing sense data
        I followed this guide - https://grok.lsu.edu/article.aspx?articleid=16716
        I am attaching pictures for reference. I tried this on a laptop as well as on a PC. Same error in both. Tried power cycling but it didn't work.
          • 31026
          "enhancedp"
          try without the p
          • ajithpoison
            • Aug 2021
            • 8
            • India
            Originally posted by stj
            "enhancedp"
            try without the p
            If you look at the next command, I corrected it. It still did not work.
              • 31026
              you still tried to pass the "p" as a password though
              • ajithpoison
                • Aug 2021
                • 8
                • India
                I reproduced the steps in the following guides.
                https://ata.wiki.kernel.org/index.php/ATA_Secure_Erase
                https://www.ibm.com/docs/en/linux-on...ion-sata-drive
                I am still getting the same "SG_IO: bad or missing sense data" error
                However, I also tried your recommendation now. It says "Missing PASSWD"
                The HDPARM erase command requires a password it seems. That's why in all these guides there is a step to set the user password and then run the secure delete command using the user password. I am also attaching another image. Let me know if it helps.
                • pfrcom
                  Oldbie
                  • Jun 2006
                  • 1230
                  You have something similar to mine, which needed quite an effort to achieve
                  https://www.badcaps.net/forum/showthread.php?t=105765
                  https://www.badcaps.net/forum/showthread.php?t=105808
                  Seeing your PM851 has no PSID on its label (a 32 character code I believe), PSID Revert isn't an option for you
                  Although there may be faint hope if PM851 is Opal compliant:
                  https://github.com/Drive-Trust-Allia...ki/PSID-Revert
                  Failing that, based on my experience, you may need to get back the CF54, put the PM851 back in it, then go through a process similar to that required to unlock the CF54 BIOS
                  better to keep quiet and be thought a fool, than to open your mouth and remove all doubt
                  • AAAC
                    • Jan 2020
                    • 458
                    • Mexico
                    @ajithpoison
                    In some laptop models there's an hdd master password in one of the DXE drivers, 32-hex pair password, that is used as a recovery to secure erase the hdd.
                    • ajithpoison
                      • Aug 2021
                      • 8
                      • India
                      Unfortunately the drive is not OPAL compliant (refer attached picture). I did go through all your posts before posting this new thread. I have gotten in touch with my friend to see if he can hand over the toughbook for a few days so that I can try something with it. Will keep everyone posted once I get a hold on the laptop.
                      • ajithpoison
                        • Aug 2021
                        • 8
                        • India
                        Originally posted by AAAC
                        @ajithpoison
                        Is there a way to find it out? Probably a guide of sorts? When switching my PC on it asks for a user password. It also gives me an option to hit ESC and enter the master password. (I don't know either of these passwords)
                        • zenius
                          by zenius
                          12-08-2024, 06:13 AM
                        • traxformania
                          TONGFANG "GM7TG7P" Bios Password Problem?
                          by traxformania
                          I tried :
                          -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                          11-15-2023, 07:32 AM
                        • tlindi
                          Toughbook CF-18KHH65LE (Customer Special Configuration) Supervisor Password needed remove HDD locking and BIOS Access ...
                          by tlindi
                          Sublect line continuation: ... Jaguar IDS PC aka Panasonic
                          Ack
                          Ack
                          01-30-2025, 04:26 AM
                        • Nopslide
                          by Nopslide
                          04-01-2024, 04:27 PM
                        • BlackVisor
                          How to Decode BIOS password for RedmiBook Pro15 2022 6800H
                          by BlackVisor
                          RedmiBook Pro 1542022 6800H
                          SKU: TM2113-39463
                          Model Number: RMA2204-AB
                          CMIIT ID: 2022AP1835
                          SN: 39463/22WD01355
                          BIOS version: RMARB5B0P1010 20230628
                          1. I bought this laptop from flea market, and the seller said that he had never set a password, however here is a password required when pressing F2 to enter BIOS.
                          2. And after entering incorrrect password 3 times, there is no any useful information like "recovery code"
                          3. I used universal bios backup tool, and dumped 8MB bin file, but hex code after "SystemSupervisorPw" is...
                          01-14-2024, 06:35 AM
