New build
  • stevo1210
    • Oct 2006
    • 4156
    New build
    I'm building a new PC for my brother and I shall be reusing most of the old parts he has. The only new items are the motherboard and CPU.
    This new build is an AMD Phenom x4 system with a AMD 945 CPU and the new motherboard will be a Gigabyte branded one, model GA-MA770-US3. The reason I want this board here is because it uses DDRII RAM and not the newer and more expensive DDRIII stuff. I have (4GB) 4x 1GB Kingston DDRII 800MHz RAM chips which shall be reused from the system he has now.
    The chipset on the motherboard is an AMD 770+ series NB and an SB170 southbridge. The total cost of the two items are $250. $165 for CPU and $85 for the motherbaord which I think is a great deal.
    As for the hard drive, I will be re-using the 500GB SATAII Seagate drive he has now and also the 1GB 9600GT PCI-E 2.0 graphics card. The power supply is a 24 pin Delta electronics 350W unit which I think is enough power.
    So what do you guys think? Any changes I should make?
    Thanks.
    Don't find love, let love find you. That's why its called falling in love, because you don't force yourself to fall, you just fall. - Anonymous
  • 370forlife
    Large Marge
    • Aug 2008
    • 3112
    Re: New build
    Sounds good to me.
    • AudioCraZ
      • Sep 2009
      • 147
      Re: New build
      I would do the math on the hardware, and make sure that power supply is enough. If you are close to max, definitely replace the power supply with a more powerful one. You never want to use a power supply at 90%-100%.
      • stevo1210
        • Oct 2006
        • 4156
        Re: New build
        yeah that was another discussion i had with my brother. But i guess we'll try with the psu we have now and then if thats suss, we'll get the 550w seasonic unit.
        • Scenic
          o.O
          • Sep 2007
          • 2642
          Re: New build
          uhm... i'm running an overclocked Core 2 Quad Q6600 (2.4 @ 3.2) with 6GB RAM, a Geforce GTX260 and a ton of HDDs and other crap on a 430W Antec (seasonic OEM).. and i still have room for even more hardware..
          makes me laugh at the people who scream "ZOMFG you need a 600+W PSU for that!!!11" .. and at the same time recommending some noname POS PSUs
          i also had my old Geforce 8800GTS 320MB (the old hot running powerhungry G80 core version) running in that comp as a 2nd card... no probs on full load..
          a quad on a 350W psu is a different story though, but the 9600GT is much less power hungry than both my GTX260 and the 8800GTS.
          especially if it's the newer generation of 9600GT's without the PCIe power plug
          • c_hegge
            • Sep 2009
            • 5219
            Re: New build
            That PSU should be enough. I find that delta can sometimes be a bit under-rated (ie. they can handle more than they are rated for).
            • stevo1210
              • Oct 2006
              • 4156
              Re: New build
              Just before I buy this stuff tomorrow... Are there any objections to my CPU and motherboard choices?
              • AudioCraZ
                • Sep 2009
                • 147
                Re: New build
                Gigabyte boards are ok. Not a huge fan of them, but have used them in the past.
                My main thing about power supplies is if you run them at max, or near max output, they run hotter, and tend to not last as long. The main reason to go overkill with your power supply is typically if you under watt your power supply, it will be more efficient. Plus, you can usually pick up 650 watt power supply for the same price as 550watt.
                From most of the reviews of power supplies, at max average power supplies are 70%-80% efficient, when you run them at 50%-70%, they can get up to 89% efficient. I rather have the power savings, for the few extra dollars.
                • toastygoodness
                  • Jul 2005
                  • 813
                  Re: New build
                  sounds great. gigabyte make the best am3/am2+ boards.
                  deltas will work fine. they are really underwatted.
                  besides, what he's asking for will do nothing more than 250w.
                  http://extreme.outervision.com will tell you.
                  • AudioCraZ
                    • Sep 2009
                    • 147
                    Re: New build
                    What OS you going with?
                    4 gigs would mean you need a 64bit os... so Win7?
                    The only thing I would make sure you get is FANS... A gaming computer can never have enough fans.
                    • etnietering
                      • Apr 2009
                      • 379
                      Re: New build
                      According to what I plugged into this: http://extreme.outervision.com/PSUEngine which involved some guesswork on my part, the recommended PSU wattage they gave was 335W, so your 350W is just fine. Keep an eye on the fan though, especially if it's an older unit. You know more about the specifics of the system, so you can plug things into that form and generate a more accurate number.
                      • stevo1210
                        • Oct 2006
                        • 4156
                        Re: New build
                        Yeah we're going with Windows 7... in fact he already has Windows 7 installed on the PC he has now, so it's just a matter or re-activating and that's about it.
                        As for the fans... There is a 12cm intake and a 12cm exhaust at the back... is this enough? The case is a Thermaltake Mambo series so I think it should be designed to cool properly.
                        Thanks.
                        • stevo1210
                          • Oct 2006
                          • 4156
                          Re: New build
                          Yeah I used that program and got 338W, so it's very close to what you got. So I guess the Delta is sufficient for now...
                          • toastygoodness
                            • Jul 2005
                            • 813
                            Re: New build
                            you should probably consider a cpu fan, like arctic cooling freezer 64 or somthing.
                            phenom ii's don't run hot hot but a good cpu fan will get it good temps. mine runs at 24C idle and 34C max load games and 44C on Core Damage with the freezer64 and AS5
                            • 370forlife
                              Large Marge
                              • Aug 2008
                              • 3112
                              Re: New build
                              Well, high efficiency is usually only achieved around 20-100% loading, because thats what 80plus tests at. When idle, most are around 75% efficient. Having a higher wattage psu will not only be more expensive, but at low loads you probably aren't going to see much of a difference, so I don't think it's worth shelling out the extra dough.
                              The 335W number that the extreme calculator comes up with is the absolute maximum that your system can use, that being running a cpu burn in on your cpu while at the same time running furmark on your gpu. Unrealistic and non-real world scenarios.
                              • c_hegge
                                • Sep 2009
                                • 5219
                                Re: New build
                                I think Gigabyte Ultra Durables are the best boards available. I've only ever seen a three or four fail.
                                A 338W gutless wonder = 180W-200W Delta, so it will be more than enough.
                                • AudioCraZ
                                  • Sep 2009
                                  • 147
                                  Re: New build
                                  you guys neglected to add in other factors though.... How many usb devices, and are those powered by the USB port? How many fans? It is just the hardware he is running, but what else he is running. PS2 keybords pull off the 12v line. USB pulls off the 5v line. The Firewire on the board has 12v on it, are they going to use that? In all honesty, no, that 350 isn't going to be enough for the average user. Like I stated before, better to buy a bit of overkill now, then to pop the power supply, and hope it doesn't take something with it. Comon guys, don't be cheap asses.
                                  Also, what temp is the office/area the computer is going to be set at? You also got to take in account that when the ambient temp is hotter, the power supply puts out less, due to heat. It may not be a problem at all, but here in California, we get 115deg f summers.
                                  You can do what you want, in all honesty, but I always build a system with a bit of overkill. Gives room to grow, and gives a bit more stability.
                                  • AudioCraZ
                                    • Sep 2009
                                    • 147
                                    Re: New build
                                    Same here, But I tend to use Intel, Supermicro, and MSI boards, typically workstation class boards. The reason is I build systems for clients that the systems will run reliably for 3-5 years. It is a rare event I use MSI boards, but I will use them. The mass majority of my computers due last 5 years, and run great, with only the usual HDD replacement up until they are ready to build a new system. I don't build cheap systems (as in low cost computers), and it isn't I am pompous, it is just what my customers want. For friends, I will build them whatever, but try to get them to spend a bit more. Some friends do, some don't. Depending on their budget.
                                    • 370forlife
                                      Large Marge
                                      • Aug 2008
                                      • 3112
                                      Re: New build
                                      Delta's won't blow up. Period. I have seen plenty of systems with core 2 quads and 8800gts's run off 350W hipros, deltas, and even bestecs (mostly in HP's and a few dells) You probably won't get over 300W while intense gaming. (hey, I ran a 754 3200+ oc'd at 2.53ghz and a 8600gt off a rosewill 350w that came free with a case and never had any problems)
                                      Most fans, usb devices, etc... use negligible amounts. Common 8cm fans use what like 6w when at full blast? A keyboard uses a lot less than that, 5v and 3.3v you don't have to worry about in a modern system as not much uses them anymore.
                                      • AudioCraZ
                                        • Sep 2009
                                        • 147
                                        Re: New build
                                        It depends, low end fans are around 2-4w (around 60cfm), and high end fans can get up to 50w (noisy 150+cfm).
                                        • Dobrowol
                                          Dell Latitude 3520 help with bios build/repair
                                          by Dobrowol
                                          Hello. Ive got problem with Dell Latitude 3520. After power on, no display and fan goes crazy. Standard job, I exported a clean bios from update via pfs extract.
                                          Steps i done and results:
                                          I exported a clean bios from update file via pfs extract.
                                          1. Build clean bios with clean ME, PMC, PCH in flash image tool.
                                          Result: Dead
                                          2. Build clean bios with no changes in ME, new PMC, PCH
                                          Result: Dead
                                          3. Build old bios with clean ME, new PMC, PCH
                                          Result: The same
                                          09-22-2023, 02:43 AM
                                          ACER Revo M2-601 Revo Build i3-6100U Specification for Upgrade or Repair
                                          This specification for the ACER Revo M2-601 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Revo M2-601 boardview and Revo M2-601 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for ACER Revo...
                                          09-12-2024, 03:28 PM
                                        • iotaa
                                          How to build this little device please for my campervan security
                                          by iotaa
                                          You will probably find this funny, and it is, but it's also a project I'd like to take seriously.
                                          I have a campervan and I'd like to avoid thieves to break in it when I am inside it or not.
                                          For this purpose I imagined a simple device that can play a sound based on a vibration detection (in case of intrusion attempt) or by pushing a button manually.
                                          The sound wil be a growling dog, which will deter any thief, thinking there is a big dog inside the van
                                          This sound can be manually triggered by me if I'm inside the van, or played automatically...
                                          09-18-2022, 09:52 PM
                                          NTE Electronics “NTE5251K” Zener Diode 9.1V @ 50W Do-5.5% Want to build a 9.1 output from a 9.6 lipo4 battery pack
                                          by sam_sam_sam
                                          I have bought this Zener Diode for this project what size and wattage resistor value do I need to use to get near 50 watt output
                                          I bought this from an eBay seller but unfortunately they only had one
                                          I bought three from Vetco Electronics these are Sylvania ECG5185A 9.1@10w A to Stud what size and watt resistor do I need to use to get near 10 watt output
                                          I bought three of from them to also make battery packs with this output power limit in mind
                                          I want to use this battery pack and turn it into a 9.1 output battery pack output to eliminate using 9 volt battery...
                                          04-23-2025, 05:50 AM
