Rage mobility driver
  • pentium
    • Mar 2006
    • 2778
    So after hassling with this blasted little Vaio PCG-C1VN Picturebook I finally got it loaded with an up-to-date install of Windows FLP and got it pretty much as decked out as I can get (short of the rare 300mb ram upgrade).
    The only issue I'm having is with the confounded ATI Rage Mobility-M1 (the 1 denoted it's the 8mb model) graphics chipset.
    The Sony driver installer provides some sort of driver but windows says there are missing files (and I don't know where the installer extracts the driver files) and fails to install the driver so I'm stuck at 640x480, google has yet to yeild a hit for a suitable replacement and even ATI says that the model GPU exists however supplies no information on where to find the drivers.
    Any assistance?
    Unrelated to the issue above, another thing I noticed an issue with is that I don't have any power saving options. This thing does support standby/suspend/hibernate mode but windows didn't configure itself to use it when it was installed and I lose a good chunk of my battery life when I'm not using it. Is there a way to enable it again?
    Find Nedry!
    Check the Vending machines!!
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Re: Rage mobility driver
    enable acpi?
    FLP=XP when it comes to drivers.
    I found it on driverguide.com, but it is too big to attach, ill PM with my email so i can get it to you that way.
    enjoy!
    sigpic
    (Insert witty quote here)
    • pentium
      • Mar 2006
      • 2778
      As in enabling ACPI in the BIOS? The BIOS does not have an option for that so I'm assuming it's locked on by default.
      Find Nedry!
      • ratdude747
        Black Sheep
        • Nov 2008
        • 17136
        in windows... look it up, idk how to force it... if it was linux, i could tell you how, but this DOES:
        http://support.microsoft.com/kb/314088
        you have to edit a file, it says how about halfway down the page.
        sigpic
        • seanc
          • Nov 2008
          • 1319
          Try running Windows update? Sometimes it offers drivers for random hardware.
          • Junk Parts
            Court Jester
            • Jun 2006
            • 8953
            I have and ATI rage mobility card in my old Dell Lappy. I have the driver for it from Dell as well as from ATI. Let me know if you want it and I will attemp to email them to you.
            Mark Twain
            John Paul Jones
            Rod Serling
            • pentium
              • Mar 2006
              • 2778
              I have to edit a file on the installation CD? Ummmmm... :/
              Hey junk. Send me an email with the drivers and I'll se if those work.
              Find Nedry!
              • Wrog
                • Oct 2009
                • 472
                Same here, I had an Inspiron 9300 that Dell never posted updates for, so I used the ATI Mobility Modder Tool to be able to install the latest driver set for mobile chipsets. I didn't see the OP's hardware listed on there, but maybe it's worth a shot?
                • pentium
                  • Mar 2006
                  • 2778
                  I hate this god damn time limit.
                  I checked the Computer tab in the device manager and it says the system is an ACPI PC sp ACPI is already enabled. Bizarre.
                  Find Nedry!
                  • seanc
                    • Nov 2008
                    • 1319
                    I could be way off the mark, but I think I recall some power saving options go awol if you don't have the correct graphics drivers installed.
                    • Junk Parts
                      Court Jester
                      • Jun 2006
                      • 8953
                      I'm trying to email you these drivers but you have your email locked.
                      Mark Twain
                      John Paul Jones
                      Rod Serling
                      • pentium
                        • Mar 2006
                        • 2778
                        Go check your PM inbox now.
                        Hmm, that might be true here as I saw somethign similar before.
                        Find Nedry!
                        • Junk Parts
                          Court Jester
                          • Jun 2006
                          • 8953
                          I tried to send it off to you but it was returned as having and illegal attachment. The the upload of my other driver was blocked because it was over 25mb. You can go to the Dell site and get it. Its listed as number R68764.
                          Mark Twain
                          John Paul Jones
                          Rod Serling
                          • pentium
                            • Mar 2006
                            • 2778
                            Tat is a driver for the Mobility M7 which is a vastly different breed than what I got here.
                            Find Nedry!
                            • washu
                              • Jul 2009
                              • 310
                              Try the driver for the Inspiron 3800. It came with the ATI Mobility-M1.
                              • Junk Parts
                                Court Jester
                                • Jun 2006
                                • 8953
                                The file for the ATI Rage Mobility M1 in the Sony Vaio PCG-C1VN is on the Sony site. Its six something megs. Its number may be VDO772AXPB. It tried to mail you this one and it was returned again! The AMD/ATI site did state that the driver for you unit is porpriatary to Sony and you must use the sony driver version. It has something to do with your flat screen in your unit.
                                Mark Twain
                                John Paul Jones
                                Rod Serling
                                • pentium
                                  • Mar 2006
                                  • 2778
                                  Yeah, it has a really weird set of resolutions.
                                  Hmm, 'm getting the feeling I'm going to need to figure out where it's extracting its files for me to solve this if the regular ATI drivers are not what I need.
                                  Find Nedry!
                                  • Junk Parts
                                    Court Jester
                                    • Jun 2006
                                    • 8953
                                    Could your missing files be DLL's? Sony listed a few DLL packages for your unit. Speaking of resoluton I had some issues when I added the Flat screen optiquest Q9 to my Lappy. Windows Xp loaded some sort of driver for it and it worked but not very well. At anything above 800x600 the picture was way to bright and the colors sucked! I searched out the real Optiquest Q9 drivers and installed them in Xp. On the reboot the Optiplex came right in at its native resolution setting and looked great.
                                    Mark Twain
                                    John Paul Jones
                                    Rod Serling
                                    • pentium
                                      • Mar 2006
                                      • 2778
                                      I downloaded all the necessary software, files and drivers from the Sony website. Everything that I can get my hands on has been installed.
                                      Find Nedry!
                                      • osrex
                                        LED DRIVER KEEPS DYING
                                        by osrex
                                        Hello, this is my first post and im just a beginner, so be easy on me guy. thanks
                                        i have a LED chandeilier that switches colors from white to cool white to warm when toggling the switch, it has 24 LED arms, each arm is 30 CM length.
                                        i have no datasheet at all for the LED lights, all i have is its length.
                                        long story short, testing the chandelier on the ground, and it works fine for 1 - 2 - 6 hours, no problem.
                                        as soon as i fix the chandelier to the ceiling and bury the driver inside the hub,...
                                        05-05-2025, 03:36 PM
                                      • howardc64
                                        Vizio E55-F1 dark backlight zones. LED failure or Dimming Zone Driver?
                                        by howardc64
                                        Problem
                                        Fixing a dimming zone TV with LEDs not lighting up. Dimming zone circuit introduces added variable to diagnose LED and/or Dimming Zone Driver board? Some 1/2 rows of LEDs appears to be out in active dimming zone off AND some brightness flickering with active dimming zone high while playing changing video
                                        Model & Board Pics
                                        Conflicting Spec
                                        Vizio indicate this TV has 10 dimming zones. However, LED strips and Zoned light driver connector suggest 12
                                        https://www.shopjimmy.com/vizio-gj-2k1...
                                        10-10-2024, 01:16 PM
                                      • charif
                                        Audio Driver for Thomson P14C4BK128
                                        by charif
                                        Need Audio Driver for Thomson P14C4BK128 (Windows 10/11)
                                        I'm looking for help finding the correct audio driver for my Thomson P14C4BK128 laptop.
                                        The sound is not working properly, and I believe the audio driver is missing or not installed correctly.
                                        Here are the details:
                                        • Model: Thomson P14C4BK128
                                        • Operating System: Windows 10 64-bit
                                        If anyone has a working link to the driver or knows where I can download it, I'd really appreciate it.
                                        Thanks in advance for your help!
                                        04-30-2025, 05:41 PM
                                      • bohaboha
                                        how to install gl usb2.0 uvc camera device driver on windows 10
                                        by bohaboha
                                        Hello all am trying to reinstall my AMCAP Microscope on windows 10 but it is not working anymore. But the cam and the drivers are present in the Device Manager but there it saysWindows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39) the drivers is : gl usb2.0 uvc camera device driver and i also get this mesage: Windows found driver software for your device but encou​ntered an error.
                                        but it is quite strange because it did work on this same OS for one week ago and even for sometimes ago on that same but now nix.
                                        any help?
                                        01-26-2025, 08:33 PM
                                      • Daveleone
                                        UN55D6900 BN44-00428B partial led driver circuit failure
                                        by Daveleone
                                        Hello TV experts! I have a UN55D6900. The successfully TV turns on, and the backlights light up, and I get a picture, but there is a section that is dim. I took it apart and 1 out of 4 segments of backlight LEDs are not lighting on both sides of the TV (in other words, the same segment is out on both LED strips).
                                        I tested the LED strips with my LED tester and all of the LEDs light properly, so I believe the problem is with the PSU/LED driver board (BN44-00428B). The voltages at CNM810 (between PSU and main board) look ok to me. The voltages at CNL801A and CNL801B look off for one...
                                        07-23-2021, 06:31 PM
