Looking for info on Realtek RTD2132 ic
  • Andreasbest
    • Aug 2014
    • 1372
    • Hellas ( Greece )
    Hello
    Recently i received a motherboard with shorrcircuit in RTD2132, i remove it and motherboard works again, i also order a replacement to replace it.
    My problem is that i can't find any info on what exactly is the Realtek RTD2132.
    Sound ic, wifi, ethernet?
    Anyone knows?
    Thank you in advance!
  • Uranium-235
    Comrade Glimmer
    • Aug 2007
    • 5080
    • US
    • computers, electronic stuff
    Re: Looking for info on Realtek RTD2132 ic
    I would trace the circuits to what it's connected to (audio ports, ethernet ports)
    look for the other common I/O chips, you can probably narrow it down
    I *think* it's audio
    • Dan81
      SNES-powered
      • Oct 2013
      • 1866
      Found a Linux listing that says it's a DP to LVDS bridge chip:
      https://chromium.googlesource.com/ch...td2132/Kconfig
      Main rig:
      Gigabyte B75M-D3H
      Core i5-3470 3.60GHz
      16GB DDR3-1600
      Samsung SH-224AB DVD-RW
      Delux MG760 case
      • Andreasbest
        • Aug 2014
        • 1372
        • Hellas ( Greece )
        I really hope to be something so useless because if it's audio or ethernet and i don't manage to solder it properly the laptop will be useless.
          • 32068
          if it's the lvds driver you need it for the display dont you?
          • Andreasbest
            • Aug 2014
            • 1372
            • Hellas ( Greece )
            The screen is working after removal, probably has to do with DP output?
            I'll check it
            • R_J
              • Jun 2012
              • 9775
              • Making Money
              See if this helps, See page 26
              • Bimad99
                • Jun 2023
                • 39
                • Algeria
                I'll check it
                The screen is working after removal ??? how is that possible ???
                The RTD2132 is an eDP to LVDS bridge, and if it is soldered to the motherboard it means the PCH is not connected to the screen connector directly, right ??
                So how the screen is displaying, can anyone explain plz ???
                I know it's too late but can you provide the motherboard reference ???
                • Andreasbest
                  • Aug 2014
                  • 1372
                  • Hellas ( Greece )
                  It had to do with the DisplayPort output only, no big deal afterall
                  • kaypdss
                    • Feb 2015
                    • 8
                    • Argentina
                    Im working on a Toshiba L55 laptop, it had a display flex problem and stopped giving image, only black screen. I found that the 3.3v power is missing on the lcd panel and i followed the line to the pin number 15 of a RTD2132N chip on the laptop motherboard, Unafortunally there is not datasheet for this motherboard and i cant find neither the RTD2132N IC datasheet.
                    • kaypdss
                      • Feb 2015
                      • 8
                      • Argentina
                      Maybe if someone have the information of a another motherboard with a RTD2132N Chip with a motherboard datasheet available i would have at least the pinout of the chip.
                      • HOSCARLY007
                        • Dec 2020
                        • 6
                        • ECUADOR
                        • itzusman
                          • Jun 2024
                          • 17
                          • PK
                          RTD2132N Is a lvds signal transmission switch ic. It selects output of video signals on hdmi or lvds or dp or vga. It is used in very few laptops.
                          • delosit
                            Lenovo IdeaPad XiaoXin Chao7000-15ARR – only motherboard available, need help reconstructing clean BIOS
                            by delosit
                            I’m working on a Lenovo IdeaPad XiaoXin Chao7000-15ARR (Ryzen platform) and I need some help with BIOS reconstruction.
                            Unfortunately I only have the bare motherboard (no original chassis, no sticker, no working system).
                            The laptop came with black screen.
                            What I have:
                            - Original SPI dump read from the board (W25Q64DW 1.8V, 8MB)
                            - Official Lenovo BIOS update (.CAP file)
                            - Photos of the motherboard (front and back)
                            - Board powers on, but with original dump it stays black screen
                            What I tested:
                            01-15-2026, 09:11 AM
                          • Andreasbest
                            HP LA-H32AP motherboard power on for 5 secs
                            by Andreasbest
                            Hello.
                            Received a LA-H32AP motherboard with AMD cpu, only reaction is the power led (LED1) that lights up for 5 secs, nothing else.
                            Summary↓
                            The laptop was working normally the previous day.
                            When pressing the power button, LED1 (Power LED) turns on for a few seconds and then turns off. The motherboard does not boot.
                            Some power rails remain active for several seconds after LED1 turns off.
                            Troubleshooting already performed:
                            • Tested different RAM modules.
                            • Tested without RAM.
                            • Tested again with RAM installed — exactly the same behavior.
                            • Removed
                            10-19-2026, 03:11 PM
                          • glovecaps
                            by glovecaps
                            11-25-2024, 04:23 PM
                          • Docus
                            Legion Y540 17irh motherboard issue ( need help to know how to diagnose my motherboard)
                            by Docus
                            Hi everyone 😀,
                            I'm here today to ask for help with repairing the motherboard of a Lenovo Legion Y540 17IRH.
                            To give you some context, I'm passionate about computer repair so much so that I've invested in a lot of tools and started practicing on dead and old hardware. I've been learning how to solder and desolder components, mostly focusing on phone repairs.
                            Recently, I bought a broken Lenovo Legion Y540 17IRH for just €150, and there are two main reasons why I made this purchase:
                            1. I already own the exact same model, but its plastic chassis is badly damaged.
                            06-10-2025, 04:24 PM
                          • bubti
                            HP Spectre x360 15-eb1079ng Keyboard-Layout missmatch after new motherboard
                            by bubti
                            i hope i am at the right spot with my post and someone can help me.
                            I replaced the motherboad on my HP Spectre x360 15-eb1079ng with one i bought on ebay from a seller in china.
                            The old motherboard just died out of nowhere so i does not have the old informations of the old motherboard.
                            After i replaced the motherboard i noticed that the key with the <>| on my german keyboard does not work like it used to but it ist now a crtl-right key.
                            I found out, that i have to configure the keyboard layout in the BIOS and i also found that with the BiosConfigUtility...
                            03-09-2026, 11:02 AM
