I still use and I still like Windows Xp. Now here is a question for you. Since Gates Soft is going to discontinue the live update thing how can I capture the updates to a disk??? Do I capture them from my PC that is already updated or do I capture them in some way from the update site??? I need these updates because Xp is a sick puppy without them...Does any third party offer these updates on a disk already???
Windows Xp Home Update
Mark Twain
John Paul Jones
Rod SerlingTags: None -
Re: Windows Xp Home Update
Hmm?
I don't think support for Windows XP Service Pack 3 is ending until 8th April 2014. Service Pack 2 dies on 13th July 2010.
If you're not running Service Pack 3, why not?
http://windows.microsoft.com/en-US/w...packs?os=other -
There are still about 72 updates the PC will get even after the install of Sp3. I do run Sp3 and have it on disk."It ain't what you don't know that gets you into trouble. It's what you know for sure that just ain't so."
Mark Twain
John Paul Jones
Rod SerlingComment
My Xp CD has Sp2 built into it. I install sp3 right after the install of the windows OS with sp2. Next I turn off the automatic updates and install the rest of my progies. After I'm all done on my end I turn the automatic updates back on and go to the windows update page and let the OS do its thing."It ain't what you don't know that gets you into trouble. It's what you know for sure that just ain't so."
Mark Twain
John Paul Jones
Rod SerlingComment
I don't now how to do what you said there....I'm a dumb ass."It ain't what you don't know that gets you into trouble. It's what you know for sure that just ain't so."
Mark Twain
John Paul Jones
Rod SerlingComment
You have a Western Digital drive don't you?
Perhaps Acronis will work for you: http://support.wdc.com/product/downl...19&wdc_lang=en
I've not tried this for backup/restore purposes on a single PC, I'll test it later on in the week for you. 10:30pm, no time for playing with Windows at this hour.Comment
The old updates will be there for quite some time, there just won't be more after the dates seanc posted. After July 13th of this year SP2 wont get any NEW updates, but the old ones will still be available.
Windows update was still up for NT4 and 98 last time I checked, just nothing new.Comment
There was a piece of software available that I used to use (when I did not broadband) that could do what you want. It would connect to the update website and download all the updates in a folder. I would have to dig it up and have a look for you.Comment
If you want to integrate all those updates you will have to jot them down, download them individually, and then integrate them with nLite. I think if you check there's a torrent where someone did this already.Comment
I use Acronis True Image for complete system cloning. It's a really reliable software and easy to use, even if you are a beginner.
Try itComment
by Stanley1843I tried to install Linux on a secondary disk in my PC and after a failed Linux grub installation my PC didn't boot in Windows 11. I saw the message (Reboot and select a proper Boot device).
I made a bootable USB windows 11 and I run the below commands on the cmd but with no succeed.
DISM /Online /Cleanup-image /Restorehealth
The DISM.... command shows me the error 87.
sfc /scannow
chkdsk
bootrec /FixBoot
bootrec /ScanOs
bootrec /RebuildBcd
For some reason it writes(Total identified installations 0) like there no...-
by DynaxSCHi,
I have an really very weired issue with ASUS ROG STRIX B550-I GAMING.
Some NVME (PCIe) SSD's are not working correctly in the second M.2 socket. An example of it is the SAMSUNG SSD980 1TB NVME SSD.
Some other NVME (I have only smaller ones) disk do work without any problem, also SAMSUNG disks, eg an MZVPV128HDGM-0000.
The behaviour is also really very strange, i.e.:- The disk shows always up in BIOS - so it is recognized, so far so good
- POST-ing with this disk with fresh Windows 24H2 installation (done in the M.2_1 socket) in the M.2_2 socket
by T4-BRHello,
Many thanks for the high quality ressources available on your website.
I'm currently facing some issues with my T470S:
- I sat a Supervisor Password using special chars which was causing issues
- Access to BIOS was locked but I was still able to use my PC
2 weeks ago, I got an update of BIOS/TPM from Windows Update.
Computer restarted and after Lenovo logo a loading bar appeared and at the end something went wrong + an error popped.
Computer restarted one more time and I got the prompt for typing Bitlocker...-
Channel: BIOS Requests ONLY!
by 0xxHi folks,
My son clicked “Update and Shutdown” on a Razer Blade 14 (2022, RZ09-0427), closed the lid, disconnected the charger, and put the laptop in his backpack. The next day, it wouldn’t boot: only the green LED blinked, no fans, no keyboard backlight, no display. The chassis does get warm, so the CPU/GPU seems to get power.
What I’ve tried so far: disconnecting the main battery, CMOS reset with power drain (30s), using a different power adapter, and connecting to the monitor - same result.
I assumed that Windows Update was interrupted due to closing... -
I had 3 people contact me in a week because Windows suddenly didn't boot:
As you can see, all 3 are ASUS computers, but I believe the common factor is the BIOS being American Megatrends (AMIBIOS/APTIO).
The first two recovered just fine after a restart, but the third one didn't and was brought to me. The model is F541UV (X541UV).
Setup allows to add a boot option manually and the operating system boots just fine from both bootx64.efi and bootmgr.efi. However, there is no way whatsoever to save the option(s): upon a reboot the machine goes straight...-
- Loading...
