T470S - TPM issue since TPM/BIOS update from Windows Update
  • T4-BR
    • Sep 2024
    • 6
    • France
    Many thanks for the high quality ressources available on your website.
    I'm currently facing some issues with my T470S:
    - I sat a Supervisor Password using special chars which was causing issues
    - Access to BIOS was locked but I was still able to use my PC
    2 weeks ago, I got an update of BIOS/TPM from Windows Update.
    Computer restarted and after Lenovo logo a loading bar appeared and at the end something went wrong + an error popped.
    Computer restarted one more time and I got the prompt for typing Bitlocker password.
    I managed to boot into Windows and saw that TPM wasn't working anymore. PC in sleep mode would sometime beep with the code 0285.
    Since I was locked from accessing the bios I used the patch unlock supervisor password and successfully managed to go to BIOS but Security Chip option is missing.
    I tried using the TPM Updater from Lenovo and reported version is 0.0.
    Do you have any idea to fix that ? Thank you !
  • rogfanther
    • Jul 2006
    • 458
    • Brazil
    Try removing all passwords from bios, then download and run bios update from Lenovo site
    • T4-BR
      • Sep 2024
      • 6
      • France
      Hi! Thanks for your answer!
      i already removed all passwords from bios. I tried to update the bios again, but the update program won’t flash because they are the same versions.
        • 21936
        post the original bios backup, and the laptop serial number.
        • T4-BR
          • Sep 2024
          • 6
          • France
          Thank you for your help ! Here is my original backup bios.
          My serial number is : PC0TZQ3L
          • T4-BR
            • Sep 2024
            • 6
            • France
            I don’t know if it could help, but shutdown from Windows is not working and is only locking the session.
            Sleep mode put the PC in a weird state. If i push the button I get the beep code for TCG error and I can only reboot…
            any idea?
            thanks in advance!
            • mikeybass
              by mikeybass
              04-23-2025, 04:30 PM
            • akwky
              by akwky
              Hi!
              04-14-2025, 01:56 PM
            • capoplays
              Help with BIOS update on Dell G15 5515 after chip replacement
              by capoplays
              Hey everyone,
              I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
              The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
              When I check the BIOS using the F12 menu Flash...
              10-24-2025, 06:53 AM
            • ahmypc
              Microsoft Surface Pro 4 Bios Update Issue
              by ahmypc
              The device that has not received an update for a long time cannot update the new ME Region. That's why touch doesn't work. Bios file cannot be opened with Flash Image Tool. Additionally, I am attaching the update file downloaded to the device and the original bios file. I would be glad if you help....
              09-21-2023, 02:14 AM
            • wizard13
              Dynabook Satellite Pro C50D-B-100 - BIOS Issue, Black Screen
              by wizard13
              I am experiencing a BIOS-related issue with my Dynabook Satellite Pro C50D-B-100. When I power on the laptop, the screen stays black, and there is no response from the system. I suspect a corrupted BIOS.
              I have checked the forum and the available documentation but could not find a solution specific to my issue.
              • Brand & Model: Dynabook Satellite Pro C50D-B-100
              • Part Number (P/N): PYU13E-00C00PFR
              • Serial Number (S/N): 22028896H
              • System Configuration (SC): A1PYU13E1127
              • Motherboard Model: IP3_ACN16_MB_V21_20211222A
              • Power Input: DC 19V –
              02-28-2025, 02:43 AM
