Post your system.......
This is a sticky topic.
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Re: Post your system.......
    as a little tip, for older cases with a tradtionally mounted PSU, if you have an open 5.25" bay, they make a good place to stash extra wires and whatnot... my two main desktops both have that issue and thats how i fixed it.
    c_hegge, nice build. well done.
    sigpic
    (Insert witty quote here)
    • Agent24
      I see dead caps
      • Oct 2007
      • 5093
      • New Zealand
      #342
      Heh, I always do that too
      -David VanHorn
        master hoarder
        • May 2008
        • 12175
        #343
        +2
        That's where I hide mine too.
        I guess one good thing about cheap PSUs is that they don't have many cables to hide . The Deer PSU I use in my Pentium 3 PC has only 1x 20 pin main connector, 4x drive connectors, 1x floppy. That's it .
        c_hegge, I really like how you rigged the LEDs on your exhaust fan. Very nice!
        By the way, I have a "new" (less shitty) gaming computer . Specs:
        motherboard: ESC P4VXASD+ (S478, 2x DDR, 2x SD RAM, 4x AGP, USB 2.0)
        CPU: 2.66 GHz Pentium 4 Northwood underclocked to 2 GHz
        RAM: Corsair 1 GB PC3200 running @ PC2100
        Hard Drive: 40 GB Seagate Barracuda
        Video: MSI GeForce FX5600 (128 MB VRAM, undercloked memory and core clock for stability reasons)
        Audio: onboard VT1612A AC'97 via VIA VT8235 SB
        Optical drives: 40X Lite-ON CD-ROM (only installed temporarily)
        PSU: 250W Dell (HiPro) HP-P2507F3P
        case: good old white generic stuff. Has a FreeBSD sticker on front. Might a Fry's special. Probably a Cyberlink judging by the original PSU, though. It's missing a side too (found it that way).
        The core components for this computer actually came from the dumpster. See this thread:
        https://www.badcaps.net/forum/showpo...&postcount=157
        PSU is my former test PSU, seen here:
        https://www.badcaps.net/forum/showpo...&postcount=228
        The CPU I picked up at Micro Center for ~$5. Runs much cooler than the original 1.7 GHz Willamate. Can't even get it to reach 40C when inside temperature is ~22C. I got the GeForce FX5600 also for $5 via CL. Keyboard, mouse and HD were trash picks from work. Monitor is 21" Dell (Sony) Trinitron D1626HT CRT.
        It plays games better than my last gaming computer and is more quiet. In particular, Half-Life 2 Deathmatch runs much better due to faster CPU. I'm very happy .
        • dood
          Deputy dood
          • Mar 2004
          • 2462
          Here's my new box, courtesy of Christmas-
          Same case as before, but now...
          AMD Phenom II x4 970 Black Edition (3.5ghz) - http://www.newegg.com/Product/Produc...82E16819103894
          MSI 870A-G46 Motherboard (with all solid caps) - http://www.newegg.com/Product/Produc...82E16813130591
          8gb of GSkill DDR3 (not sure of the specs)
          Logisys "575w" PSU (max sustained output, 450w) <- this is getting replaced as soon as I have the money to get a nice modular supply.
          (1) WD 750gb Black HD as primary
          (1) Seagate 2tb "Green" drive as storage
          MSI 460GTX Hawk video card
          All in all, it's running GREAT. One surprise is that my old 420w PSU wasn't enough to power the system under load. I kept getting random crashes and BSODs. Switched to the Logisys and everything smoothed right out. I say surprised, because the Logisys' +12v rail is actually rated LOWER than the 420w. Most of the amperage is made up on the 3.3 and 5v rails.
          Now, under load, the +12v is dipping to 11.67v (as measured with my multimeter), which I'm not too happy about. So, like I said, it'll be replaced
          Ludicrous gibs!
          • ratdude747
            Black Sheep
            • Nov 2008
            • 17136
            looks sweet minus the PSU.
            what kind of opticals you running there?
            sigpic
            • dood
              Deputy dood
              • Mar 2004
              • 2462
              Just one... it's a cheap DVD DL SATA Burner. Not sure what brand, but it always works!
              Ludicrous gibs!
              • shovenose
                Send Doge Memes
                • Aug 2010
                • 6575
                nice one!
                That PSU makes me puke but other that that looks like an awesome system!
                • ratdude747
                  Black Sheep
                  • Nov 2008
                  • 17136
                  thats cool... my main rig has twin sata dl burners, both liteon made (one's an asus, but the OEM is liteon). don't have the $ or the need for blu-ray.
                  sigpic
                  • shovenose
                    Send Doge Memes
                    • Aug 2010
                    • 6575
                    Blue-ray in a computer is pretty useless IMO,except in HTPCs...
                    • ratdude747
                      Black Sheep
                      • Nov 2008
                      • 17136
                      2 things:
                      1. movies
                      2. data backup
                      sigpic
                      • PCBONEZ
                        Grumpy Old Fart
                        • Aug 2005
                        • 10661
                        Agree.
                        Discs are too expensive for backup use.
                        A hard drive is better. Better yet a dedicated NAS.
                        An old PII could do that and cost less than the RW burner.
                        The only time I'd ever use a Blue-Ray is for a movie that I couldn't get on DVD.
                        That hasn't happened yet.
                        Mann-Made Global Warming.
                        - Dr Seuss
                        • c_hegge
                          • Sep 2009
                          • 5219
                          At least that PSU isn't a Leadman or Awfull Power
                          • ratdude747
                            Black Sheep
                            • Nov 2008
                            • 17136
                            you mean sledgehammer bait?
                            sigpic
                            • c_hegge
                              • Sep 2009
                              • 5219
                              Nah, more like load tester bait.
                              • shovenose
                                Send Doge Memes
                                • Aug 2010
                                • 6575
                                a BOOMbox
                                • c_hegge
                                  • Sep 2009
                                  • 5219
                                  • ratdude747
                                    Black Sheep
                                    • Nov 2008
                                    • 17136
                                    that came from one of my first threads back in early 2009 (or late 2008, i can't remember)... back when I was a noob... silly me asked about recapping a 400W A-Power, and the only advice I got was to sledgehammer it... and from multiple members.
                                    Ironically I still have the guts (or lack thereof) from it, kept as a memento from my past as a noob.
                                    sigpic
                                    • dood
                                      Deputy dood
                                      • Mar 2004
                                      • 2462
                                      The poor Logisys' feelings are getting hurt here...
                                      Why is it that a cheapo PSU rated at 25a +12v can keep my system stable, when a PCP&C supply rated at 30A +12v can't?
                                      Ludicrous gibs!
                                      • PCBONEZ
                                        Grumpy Old Fart
                                        • Aug 2005
                                        • 10661
                                        Perhaps it has to do with 3.3v, 5v or 5vsb.
                                        FYI: Most people miss this:
                                        There is a minimum amps required on +5vsb for mobos but only [that I've seen] Intel ever mentions it by amps.
                                        The other manufacturers just tell you what ATX PSU spec your PSU needs to be to cover that. The PSU spec they say to use will have a minimum +5vsb requirement good enough for the board.
                                        - For example..
                                        ATX12V 1.1 , +5vsb , 1.0a [required] , 2.0a [recommended]
                                        ATX12V 2.01 , +5vsb , 2.0a [required] [2.5a for 500mS max.]
                                        ATX12V 2.2 , +5vsb , 2.5a [required] [3.5a for 3 seconds max.]
                                        - Some of my server boards require 3a continuous on +5vsb.
                                        If your board actually uses around 2.5a 5vsb and you're sporting an ATX12V 2.01 PSU then it being unstable wouldn't surprise me too much.
                                        I see a lot of people show up here with blown +5vsb.
                                        It get's blamed on crap +5vsb design.
                                        Very often it happens when using an older PSU on a newer board.
                                        - I think the 5vsb gets blown most often by cheaping-out and reusing an old spec PSU on a new spec board when the old PSU isn't rated for enough 5vsb amps in the first place.
                                        - That's user/tech error. Not a 5vsb design problem.
                                        - Dr Seuss
                                        • dood
                                          Deputy dood
                                          • Mar 2004
                                          • 2462
                                          Well, lets take a look.
                                          Logisys Specs - +3.3@30A, +5V@38A, +12V@25A, -12V@0.8A, -5@0.5A, +5VSB@2A
                                          PCP&C specs - +3.3@20A, +5V@20A, +12V@30A, -12V @ 0.8A, +5VSB@2.5A
                                          So, the Logisys is rated higher on +3.3 and +5. Now, I would've figured that with my mobo/cpu upgrade, the bulk of the load would be on +12 and the others would've remained relatively consistant from the old system... I actually dropped from 3 hard drives to 2, and removed a PCI RAID controller.
                                          The only other thing I can think of is the lack of an 8 pin Aux connector on the PCP&C supply. However, the board came with a cap on half of that connector if you only want to use a 4 pin, so I'd think that would be fine.
                                          *shrugs* I'll just get a bigger supply in a month or so, and the PCP&C has become a good spare.
                                          Ludicrous gibs!
                                          • canadaboy25
                                            Drive SMART status not showing up through RAID controller?
                                            by canadaboy25
                                            Hey guys,
                                            I have an Asus M5A99FX Pro R2.0 motherboard with AMD RAIDXpert. I set up a 1000GB RAID1 array on it. This was about 8 years ago. Every once in a while, a power outage or something would knock one drive offline and degrade the array. After a reboot the drive would be back online and it would rebuild just fine.
                                            Recently, a drive dropped offline and the array became degraded. I figured it was no big deal and rebooted then set it to rebuild overnight. The next morning I took a look and both drives had dropped offline at 70% rebuild. Uh oh.
                                            I rebooted...
                                            09-24-2021, 01:56 PM
                                            Announcement: The Win-raid forums are closing
                                            by SMDFlea
                                            https://winraid.level1techs.com/t/wi...uncement/38021
                                            The win-raid forums are closing at the end of this year,its a sad time for all who have used the site to gain knowledge from some of the really talented members there.
                                            11-20-2021, 10:21 AM
                                          • bmxlovah
                                            Dell Precision T7910 no bios, no post after applying SAS/RAID setup
                                            by bmxlovah
                                            My Dell Precision T7910 died after enabling onboard SAS controller and applying RAID settings. There were no hardware changes between working and not working state, only setup (via bios -> controller settings). After applying settings and reboot PC turns on, flash leds (normally) but there's no further action, it just stays on with no graphics and no keyboard led's on. There's no Dell logo, nothing. I've tried resetting bios by jumper, replacing cpu's, replacing ram, removed/replaced cmos battery, disconnecting all drives etc. I've also dumped .bins from mobo chips SLI1 (16...
                                            11-24-2022, 06:29 AM
                                          • tbalint3
                                            Abit ST6-Raid repair
                                            by tbalint3
                                            Hello All,
                                            I am trying to repair an old Abit ST6-R motherboard.
                                            The symptoms are the following:
                                            I got it in a non-working state. I was told that it sometimes turned on, but many times just the CPU fan was spinning and no other signs of life, the board didn't POST, and now it doesn't POST at all.
                                            It was full of bulged electrolytic capacitors, so I replaced all of them with new Low-ESR ones, but it didn't solve the problem.
                                            If I install a CPU in the S370 socket, only the fans are spinning and no POST. There are no beep codes even if the RAM DIMMs...
                                            09-01-2024, 10:03 AM
                                          • canadaboy25
                                            Getting Windows to boot after changing SATA from RAID to AHCI
                                            by canadaboy25
                                            Hey guys I'm wondering if anyone has any ideas on how to get Windows 10 to boot up and install drivers after changing the bios settings for the sata port from raid to ahci.
                                            My motherboard is an Asus M5A99FX pro R2.0 and when I built the PC I set all of the sata ports to raid mode. There is one setting for ports 1-4 and one setting for port 5 and the esata port. I currently have 4 drives set up in two raid 1 arrays on ports 1-4. My ssd containing Windows 10 is plugged into port 5. I also have an external esata enclosure with a 2tb drive that I use as a Windows backup plugged into...
                                            12-02-2018, 02:17 PM
