Post your system.......
This is a sticky topic.
    Re: Post your system.......
    http://www.sysprofile.de/id142000
    desperately needs some updating.
    POS GTX260 is gone (HD6870 now), 8GB DDR3 instead of 6GB DDR2, ....
      Originally posted by ncovert View Post
      You may have seen my earlier post, but you will be happy to know I have retired both of those machines. Now, here is my main pc specs:
      My main PC: Intel D875PBZ desktop board, 2.8Ghz Pentium 4 HT, 2GB DDR RAM (4x 512MB Dual Channel), WDC WD2500JD SATA HD (primary), WDC WD800JD SATA HD (secondary), HP dvd640 LightScribe DVD+RW drive, ATi Radeon 9000 64MB AGP, SB Live Value, Thermaltake Purepower 350W, all housed in a beat up Antec SX1030b case (black with side window) OS: Windows XP MCE 2005
      Yeah, I'm not THAT rich...
      I also have 2 19" monitors, one Dell 1907FP and a Lenovo Thinkvision. The Lenovo is on the right as my primary, but everything opens on the Dell monitor. Strange.
        Asus P5Q Pro
        Intel Q6600 stock (overclocking to 3 ghz rarely) + ZeroTherm FZ 120 cooler
        Corsair 4 GB DDR2 (2 + 2, 800 Mhz CL8)
        Sapphire Radeon 4850 with Accelero S1 Rev2 passive cooler
        Seasonic X-650 semi passive psu
        3 or 4 drives installed, about 5 TB total (WD + Seagate)
        LG dvd writer
        Leadtek Winfast 2000XP Expert TV tuner
        Antec 300 case with all the coolers except one by the hard drives turned off.
        One Samsung T240 (1920x1200 24") + one Samsung 2494HM (1920x1080 24")
        Logitech X-540 5.1
        Microsoft Curve 2000 something keyboard and Logitech MX518 mouse...
          SpidermanII is the case and the computers name.
          PSU Therlatake Purepower 1.3 #W0119RU 400W
          XP Home Ed.
          Asus K8N (No crap caps yet)
          AMD Athlon 64 3000+ ~2.1GHz
          1G RAM
          EVGA GeForce 6600 @256MB (Recapped)
          WD 232 gig SATA
          x2 DVD RW
          CD RW
          Cannibalized DELL card reader
            Alright, here's an updated pic of mine -
            Coolermaster Elite case (not sure the model)
            NF4SK8AA Motherboard
            Athlon64 X2 4200+ CPU (ADA4200DAA5BV)
            3GB DDR (2x1gb 2x512mb)
            MSI N460GTX Hawk 1gb vid card
            2x750gb WD Black Edition in RAID 0 (TLER enabled)
            1x2TB Seagate Green (new)
            All powered by a PC Power & Cooling Silencer 420w PSU, with all available power plugs used :p
            Ludicrous gibs!
              Uhh.. the Foxconn Winfast motherboards..
              I've only ever seen dead ones so far
                Looks like it might have Chemi-con KZG caps too. (although they could be KZE)
                  Well, figured I'd add mine as well...
                  Tyan S2877 Dual Socket 940 Motherboard
                  - 2 x Opteron 280 Dual cores @ 2.4GHz
                  - 2 x Thermaltake Copper plated/pipped coolers (AS5 applied and burned in)
                  - 4 x 2GB DDR400 ECC
                  - XFX 5550 1GB
                  - DVD-RW/DL
                  - 2 x 500GB SATA drives (Not RAID configured)
                  - 1 x 160GB IDE 7200 RPM
                  - Rosewill Full Tower
                  - 600W OCZ StealthXStream EPS12V PSU
                  - Rigged GPU fan on Northbridge heatsink
                  - 5 case fans from 120mm to 30mm
                  WEI Scores - Windows 7 64-Bit
                  CPU: 6.8
                  RAM: 7.1
                  Aero: 5.5
                  Gaming: 6.5
                  HDD: 5.8
                  Not bad for a $230 system.
                    I had a Leadtek Winfast K7NCR18D that was replaced many times under warranty. Bad caps, and it liked to fry the ATX connector.
                    Indeed it does. I haven't replaced them because its been working fine.
                    Ludicrous gibs!
                      Since everybody is posting pictures, here is my old Compaq, complete with its ghetto cooling system and homemade speakers. The third picture shows how I added a line-level audio input. The blue wires are the signal wires and the black wire is ground.
                      I also have a replacement for the HP laptop. It is a Toshiba Satellite L750.
                      Intel Core i3-2330M CPU
                      4GB of RAM
                      Intel HD Graphics
                      Toshiba MK5075GSX hard drive
                      TSST TS-L633F DVD burner
                      Windows 7 Home Premium 64bit
                      I don't like Toshiba's choice of hard drive and optical drive and their decision to use a Synaptics touchpad, but they should last for a couple years.
                        how the hell did you get that dual opteron for $230
                          Tyan S2877 Dual Socket 940 Motherboard ($50 on Ebay with 2 x 1.8GHz CPUs, 4x512MB DDR400 ECC and the coolers.)
                          - 2 x Opteron 280 Dual cores @ 2.4GHz ($15 for the pair on Ebay)
                          - 4 x 2GB DDR400 ECC (I think I paid about $45 on Ebay)
                          - XFX 5550 1GB ($50...Guess where...Ebay)
                          - DVD-RW/DL ($5 from the local PC scrap guy)
                          - 2 x 500GB SATA drives (Not RAID configured) (One for $25 on craigslist and the other for $5 from the scrap guy)
                          - 1 x 160GB IDE 7200 RPM ($5 from the scrap guy)
                          - Rosewill Full Tower (That guy says $5 on everything, this included.)
                          - 600W OCZ StealthXStream EPS12V PSU ($20 from Directron.com on clearance)
                          - Rigged GPU fan on Northbridge heatsink (Salvaged from something)
                          - 5 case fans from 120mm to 30mm (Pulled from scrap PCs)
                          Oh yeah, I paid $5 for my sound card as well, from the dude at the scrap place.
                          If you include the LG 19" Flatron that I got for $5, non-working, one cap and she's good as new. I get lots of monitors from that guy, most of them I can fix as well.
                          Then there's the Logitech G5 gaming mouse I paid $1 for, and my Emachines PS/2 super-slim keyboard...Also $1.
                          All together that's what...$237? With the monitor, keyboard, and mouse. Gotta know where the deals are people, used is just as good as long as it turns on.
                          ~Edit~ I also just built this rig after selling my customized budget gaming PC. Black custom painted case, Sempron 2300 x2 OC'd to 2.7GHz at 30C Idle(High 40s full load) with a salvaged 939 Alienware cooler. 2 x 2GB G.Skill DDR2 800 @ 975Mhz, 250GB SATA, XFX 4650 1GB, LG Super-Multi and Westinghouse 19" LCD with built in speakers. Got $290 out of it, then I flipped it into the new Rig.
                          That's not counting the HP DV7 Turion x2 @ 2.0GHz, 4GB DDR2 800, 250GB SATA and ATI HD 3200 Graphics. I got that in a semi-working state as a trade for swapping out some LG guts from 23" widescreens.
                          Lady just gave it to me with a botched Vista install, broken casing pieces and an overheating CPU. $20 for a new touch/media panel, AS5 on the CPU/GPU instead of the crappy thermal pads and a fresh Windows 7 64-Bit install...She's running like a beast, for almost nothing. Oh, and she idles in the high 40s, haven't really loaded her down yet.
                          Sorry about the edit. Don't like to bump threads.
                            The homemade speakers are awesome. For some reason, they blend so well I almost didn't see them in that picture .
                              aaand another one fell for it
                              motherboards -> Foxconn WinFast
                              graphics cards -> Leadtek Winfast
                              edit: wait wat
                              Leadtek did actually produce winfast labeled motherboards.. but they stopped at Socket A. Everything newer (orange PCB) is Foxconn Winfast.
                              http://www.tbreak.com/reviews/article.php?id=157
                              http://www.foxconnchannel.com/produc...d=en-us0000034
                              Judging by the "WinFast" font, they were probably both made by foxconn anyways though..
                              confusing shit
                                Here are some pics of my pc (attachments)
                                  Intel motherboard it looks like
                                    It says Intel D875PBZ desktop board in his signature
                                    I see what looks like KZG :O
                                      edit: wait wat
                                      confusing shit
                                      Yep, the K7NCR18D was a Socket A board, and was purchased right before Leadtek stopped selling them. It was most likely a Foxconn underneath.
                                      The Winfast I'm running now is about 5 years old and has performed flawlessly (knock on wood). It was my brother's PC before it got handed down to me.
                                      Ludicrous gibs!
                                        Finally, I got around to fixing up the mess of wires in my siugnature PC (well, kind of - it still looks a bit messy around the bottom and behind the motherboard tray - partly because my Delta DPS-750CB doesn't have any cable managment features). Now I'm not too embarrased to post a few pictures of it and my fixed up cables.
                                          C Hegge That is a fine looking mess. I don't see a single thing wrong with it at all. I have a new "neat" PC and I have wires all over the place. The next thing I'm buying is a wireless keyboard and mouse. I'm tired of all the tangled cables...ect. If there was such a device that could make my flatscreen monitor wireless I love to have that too.
                                          My system :
                                          Hp Pavilion p6687 c-b
                                          AMD PHENOM II 840T Quad-Core PREMIUM VISION CPU
                                          TWO FRONT PANNEL USB 2.0 slots
                                          8 GB DDR3 SYSTEM MEMORY
                                          1 TERABYTE HARD DRIVE
                                          SUPERMULTI LIGHTCSRIBE DVD BURNER
                                          ATI RADEON HD 4200 INTEGRATED GRAPHICS
                                          GENUINE WINDOWS 7 HOME PREMIUM 64-bit
                                          15 IN ONE CARD READER
                                          SATA
                                          BUILT IN LAN
                                          801/SOMETHING WIRELESS
                                          Hp 2509m 25 INCH DIAGONAL FULL HD LCD MONITOR
                                          Hp USB OPTICAL THREE BUTTON CORDED WHEEL MOUSE
                                          NO NAME BRAND 4 INCH POWERED SPEAKERS
                                          STANDARD BLACK HP USB WINDOWS KEYOARD
                                          KOSS UR/29 HEADPHONES
                                          I think its enough for using the internet and burning some DVD's
                                          Mark Twain
                                          John Paul Jones
                                          Rod Serling
