How to avoid shitty "McWires"?
  • Offscreen6
    • Jan 2021
    • 22
    I've opened up a lot of electronics, and I keep on seeing these stupid little thin wires. On hand I can (and did) pull out three different things with this same wire in it (a clock, a mini arcade machine, and a multimeter), and I suspect my newest broken thing failed because one of these wires went loose.
    These things are just overall low-quality. They're easily frayed, they never stay on their joint for long, and they're everywhere. For this reason, I call them McWires. I have attached examples below; one appears to have rusted, and the last image shows a McWire that came broken off out of the box... no joke.
    Does anyone know how I can replace these with higher-quality wires or how to avoid them altogether? Any help appreciated.
  • Uranium-235
    Comrade Glimmer
    • Aug 2007
    • 5045
    • US
    Re: How to avoid shitty "McWires"?
    I had a brand new shuttle xh270 and, as usual they have the sata wired with the slimline sata cable. This time it was was cut twisted back together poorly with a heatshrink over it, and the top was exposed. not even soldered. Obviously a RMA with a poor repair
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8712
      Wire is wire. The plastic on them sucks, too hard. However it should be fine if they aren't disturbed! Especially piezo elements, it shouldn't be disturbed. Mechanical failure is what gets these wires due to the stiffness of the insulation.
      It's up to you if you want to replace them but really the only way is to make sure the wires do not get mechanically moved around frequently. Zip tie, hot glue, attach them to something sturdy.
      • lti
        • May 2011
        • 2558
        I've seen that wire on the AC input of cheap power supplies (like this).
        The wire in the third picture looks like some kind of copper-clad stuff.
        There's another type of wire I discovered that is copper-colored (not copper-clad), but its resistance is extremely high, it doesn't handle flexing, and it is attracted to a magnet. I have a "Cmple" branded cable that is made of that stuff. The resistance is about 0.5 ohms per foot for what appears to be 24AWG wire.
        • ChaosLegionnaire
          HC Overclocker
          • Jul 2012
          • 3266
          • Singapore
          that is probably steel wire consisting of only a few strands. penny pinching and corner cutting at its finest!
            • 31296
            all this is because the bankers drove up the price of copper.
            • lti
              • May 2011
              • 2558
              No, I cut the cable open after one of the wires broke. It looks like 24AWG or 26AWG wire, and it has a "lightly oxidized copper" color all the way through. Also, the resistance is too high for steel wire. I initially thought that it would have hair-thin wire based on the resistance and how quickly the wires broke.
              It was an extremely cheap cable, and the company that sold it has to have a bunch of aliases (like Powmax and Deer) to keep selling them to people who think they're sticking it to the audiophile brands.
                • 31296
                brass / copper alloy?
                • ratdude747
                  Black Sheep
                  • Nov 2008
                  • 17136
                  Copper clad aluminum?
                  sigpic
                  (Insert witty quote here)
                  • Offscreen6
                    • Jan 2021
                    • 22
                    Thanks for the reply.
                    Yeah, securing the wires sounds like it could be a good solution. However, there are some that I have around that, due to their position or nature, can't be properly secured (for example, there's a set of McWires running a high-power flywheel motor, one of which came loose during normal use).
                    How would I go about finding out which length, thickness, or other type of wire I can replace those ones with? Is it just a matter of resistance?
                    • eccerr0r
                      Solder Sloth
                      • Nov 2012
                      • 8712
                      Also poor selection of attachment points may exasperate the issue. The solder joint is the weakest spot and you want to make sure the least amount of stress is applied there.
                      length, thickness, resistance, temperature, voltage, abrasion, chemical, and yes, flexibility are all part of wire selection.
                      • Agent24
                        I see dead caps
                        • Oct 2007
                        • 5095
                        • New Zealand
                        Those wires have fewer strands than usual, too, which makes them more susceptible to breaking.
                        -David VanHorn
                        • Dannyx
                          Wire twisting tool for small wires - ideas ?
                          by Dannyx
                          Good day folks. Recently, I started doing more and more alarm system installs which involve dealing with a ton of small wires which are part of 4 to 12 core alarm cable. To make my installs as clean and neat as possible, I twist together the individual wires whenever possible to make braids like in the picture. It takes a lot of time and wears on my fingers really quickly, to the point where I actually developed a blister on my index finger from all the twisting. This got me thinking if there's a tool designed to braid small wires like this. I know there is something for twisting together solid...
                          08-23-2020, 06:29 AM
                        • ChaosLegionnaire
                          correct way to connect bare speaker wires into spring clip terminals?
                          by ChaosLegionnaire
                          i recently bought a logitech z607 surround system. however, its giving me grief. when i first connected it, it only had sound coming from the front right speaker. after a great deal of fiddling and reseating the speaker wires into the spring clip terminals, i finally had sound coming from all 5 satellite speakers.
                          however, the sound still gets cut off intermittently if i move the speakers, subwoofer or move/touch the speaker wires on the back of the subwoofer. so i wanna ask what is the right way to connect bare speaker wires into spring clip terminals?
                          i googled...
                          10-27-2022, 06:19 AM
                        • budwich
                          Headphone wires.... confused!
                          by budwich
                          I picked up a "beat up" set of sennheiser headphones (hd201). The phono plug end seemed to have an issue such that most of the time only one ear would work but by compressing / bending the jacket of the phono plug, I could cause the other ear to work. Must be a phono jack (3 pin) problem. So I cut it off and have solder based replacement. BUT... the wiring seems "mysterious" to me. I can't see how this can work or even ever worked. Attached is a picture of the wires (less the phono plug). One sheath has what I believe is two enameled wires while the other has basically...
                          09-01-2023, 07:27 AM
                        • howardc64
                          by howardc64
                          Problem
                          08-04-2024, 10:36 PM
                        • playit
                          psu sata power wires thinner - does it make a difference ?
                          by playit
                          hello , i have a psu 450 zebronics (yes its bad crap) which used to work before with its own sata power cable ,but today its not able to power up harddrive efficiently with its own power sata cable , but when there is a connector which have a thick wire than the psu sata power cable wires - its powering up and working smooth , no problem yet .
                          i the voltages with multimeter shows 12 ,3.3 v , no problem , but hardrives powers well only with this thick wire sata power cable connector from psu power molex .
                          any explanation on this ?? thank you ,soon i am planning to buy some branded...
                          10-12-2023, 05:25 AM
