Evaluating laptop fan health
  • pingaroon
    • Nov 2019
    • 121
    • uk
    I have a big box of laptop fans and have been testing them one by one with a bench power supply.
    All are 5v, but have different power ratings in Amps (from .19 up to .6)
    Presumably this Amperage rating is the maximum it can theoretically supply, so here is my question.
    Given 3 identical fans with the bench voltage set to 5v and the amps set to auto (no cap), you would expect the amps to be the same on all 3. If it draws more amps (closer to the rating limit), does that indicate the fan is in poorer health (as it is having to work harder) ? Conversely, if the amps are low (nowhere near the limit), could that indicate a fault or is it just using as much as it needs and so is in good health?
    I noticed for example testing 5A fans, some of them draw .45A, whilst others draw .25A etc.
    What can I deduce from the power supply readings in order to test the health of these fans.
    THANK YOU
    • 31301
    Re: Evaluating laptop fan health
    the current rating is an indication of power it will draw.
    that could mean more flow, or more static pressure, or it could just be bigger
    the real test its does the shaft/blades wobble or have any play.
    that would indicate the bearing is worn.
      master hoarder
      • May 2008
      • 12175
      Not much, honestly.
      The maximum power and/or current rating stated on the fan is probably what the fan will draw under "worst" conditions, whatever those may be (blocked fan intake or output or locked rotor due to an object.) It's a bit ambiguous, IME, and the -running- current typically tends to be much lower than the stated current, though not always.
      You should also consider the fact that the windings on fans are inductive devices... and as such, the typical tolerance for those can be +/-20%... so I imagine the current/power draw may also vary as much even between two identical fans.
      Therefore, I don't think you can say anything about a fan's health based solely on the current it draws. Like stj noted, just spin the fan and watch it come to a full stop, then note how much it "wobbles" back and forth as it does that. This will tend to be a lot more pronounced with ball bearing fans, as BBs usually have lower resistance/friction than sleeve bearing fans. Of course, it will also depend on magnet strength and design too - weaker/slower fans with weaker magnets will tend not to wobble as much as stronger fans.
      In any case, the easiest way to tell IMO, is to just spin the fan and watch it slow down to a stop - if it stops too fast, the bearing is definitely in need of service (well, if it's a sleeve bearing anyways - ball bearings you can't service and only can replace them.) And also try the fan at full speed and at lower speeds while listening for any grinding or clacking noises (the latter typically only seen in work/broken BB fans.)
      • emil_t
        RTX3090 working fine but fans not spinning
        by emil_t
        Hello guys. I have a problem with a PNY XLR8 GAMING RTX3090 graphics card. The problem is that it displays and works fine, but the fans don't spin at all. The problem occurred when someone else removed the fans in order to clean it and broke one of the fan connectors. He replaced it himself and after that, it wasn't working anymore. I guess he damaged something else in the process. What i have done so far: I found 2 capacitors next to the connector that were in a bad shape, he must have touched them with his tools - they weren't shorted, but i replaced them with similar ones from a similar card....
        04-12-2024, 06:54 AM
      • b-slayer
        Asus Strix-G15-G513RM fans don't work
        by b-slayer
        I have an Asus Strix-G15-G513RM, who starts normally, but as the fans don't work, it stops and is really really hot,
        The Bios was the latest one, (327), but I managed to downgrade it to version 325 to see if it changed something,
        (as I read somewhere that a corrupted bios can explane my problem), but nothing, it just went full blow during the downgrade,
        (so now, i can say that the fans are fonctionnal), but as it restarted, the fans won't turn at all again.
        ah, and in the Bios, even when the temperature is really hot, the fan are a 0 rpm,...
        09-04-2025, 04:58 AM
      • Stephen
        A2991 Logic Board issue, 20volts 0 amps help!
        by Stephen
        Customer plugged in samsung monitor into the board and used it as a power supply, killed UG800 and UG400. I replaced those two with an exact donor board we had In stock and working, board pulls 5volts and then gets like 2.89 amps on the left side. The singular port is the port that failed. Used a perfectly working chips from donor (board was locked) Now I only get 5volts 0 amps on that power and then 20volts 0 amps on the two left side ports, I checked for DFU and nope nothing, computer not turning on. No shorts present anymore. I am confused as I used the exact components from an identical...
        09-10-2025, 03:16 PM
      • Stephen
        A2991 logic board issue, 20volts 0 amps help!
        by Stephen
        09-10-2025, 03:15 PM
      • JayPoorJay
        Hot Water Rad - A Few ECU Fans and a Timer Switch
        by JayPoorJay
        Good Afternoon, Good People.
        I know this will be an elementary little project for most if not all of you, but I thought I would write a post and get put on track, rather than bumbling my way through it with all kinds of trials and errors.
        I REALLY would appreciate y'alls help.
        This is the problem - My wife and I purchased a big ol Victorian/Colonial House in NYC two years ago. The kitchen is surrounded on 3 sides by exterior walls, there is also a 1/4 of the kitchen floor (ceramic tiles) that has a crawl space underneath, and the kitchen gets FREEZING cold...
        10-29-2024, 12:54 PM
