Bionic Pup 32-bit O/S
  • bigbeark
    • Jan 2010
    • 661
    This is a Linux OS that runs in Ram that I found on an Explaining Computers You Tube video. It's available for download on Source Forge. Select "Linux" then search "uppup". This is a tiny yet powerful distro. Burn it to a USB stick. I downloaded it in MX Linux because their USB burner allows you to create a rewritable partition on the install USB stick.
    Why would you do this? Main reason it's only 300MB in size. The included "Light" browser allows you to watch YouTube or post here with as little as 1GB of ram and a slow processor. The browser is based on Firefox but WAY more efficient.
    Did I mention it's blazing quick? Theoretically you can save your session. I'm still working on that aspect.
    As long as your system will boot from a USB stick you are good to go. In fact, I'm thinking you could use an Optical Drive with a "PLOP' CD to start up Bionic Pup on an ancient machine.
    Anyone else tried this?
  • piernov
    • Jan 2016
    • 4439
    • France
    Re: Bionic Pup 32-bit O/S
    On old 32 bits only machine I generally install Debian with LXQt. If it's for my personal use it's ArchLinux32 with i3.
    Although I personally use Firefox, I found Chromium to be slightly more efficient than Firefox in terms of RAM with only one tab open, and lagging a bit less when video acceleration is not available or CPU is overloaded.
    There are of course other more lightweight browsers but website compatibility is a problem for the lightest ones, and in fact rendering is slower without video acceleration or with overloaded CPU.
    • lti
      • May 2011
      • 2558
      There are a lot of Puppy Linux variants. I still have an older one (based on Ubuntu 12.04) on a flash drive.
      I also used Tiny Core a long time ago. It ran in RAM, but it didn't include any software beyond a terminal and some minimal form of a package manager.
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8711
        I still run a full 32-bit OS that's still constantly updating on my 32-bit machines... just to run Firefox 78ESR ...
        • ezenia
          PS4 controller left stick potentiometer replacement issue
          by ezenia
          Not sure if this is the correct section, but I have a PS4 controller that I am trying to fix. It developed stick drift on the left stick and the usual simpler methods did not fix the problem.
          So I went on eBay and ordered some replacement potentiometers. https://www.ebay.co.uk/itm/174967976757 is where I got them from.
          I took the green potentiometers off the replacement sticks and soldered them onto the PCB. Assembled the controller and ran some tests. The drifting was somewhat fixed (not fully in center, but way better than before). However,...
          09-30-2023, 02:19 PM
        • Hondaman
          Firefox is now SATANIC
          by Hondaman
          Now that I have your attention:
          In the last few days, it looks like Firefox has changed their software terms so they are now evil and WILL sell your data.
          I already use Palemoon for Win7 sometimes. Looks like I'll be switching to librewolf as well, as Youtuber Louis Rossman suggests. Palemoon still supports Win7, but sometimes pages don't work properly. The Google Chrome browser might also still work for Win7.
          I will have no choice but to upgrade my Firefox, so that I can copy dozens of tabs into a document or spreadsheet, or go through the history to...
          03-05-2025, 04:41 PM
        • dbuergi
          PS5 Dualsense controller stick drift a mainboard issue?
          by dbuergi
          I got a controller where the left stick was moving left all the time (-1.00 at calibration tool). Even after changing to hall effect sticks it stayed the same and reset and all others things didn't help.
          I removed the stick again and even without it calibration tool shows a movement to the left. Anybody knows where the fault can come from? Maybe any bridges or damaged SMD components?
          05-02-2025, 05:00 PM
        • keepread
          Lenovo Ideapad S400 turns off when booting into any OS desktop
          by keepread
          I've been using this laptop for quite some time w/o battery. It has Linux installed. Recently, someone sent me a web link in an instant messenger. When I clicked on that link the laptop turned off that instant, before the browser even loaded to open it. Since then it turns off several seconds after I start it up and log into the Linux graphical desktop. I can see the mouse cursor moving around the screen when I draw my finger on the touchpad or move the mouse, and then a terminal window begins to load because the desktop autostarts it from last time, and then I hear a pop from the speakers and...
          12-18-2024, 08:32 AM
        • tsavpyn
          Requests to Intel Flash Programming Tool for Linux Ubuntu x86_64
          by tsavpyn
          Dear all,
          I forgot my BIOS password of my Surface Pro 3, I searched for solutions for a long time and knew that by using FPT to dump my bios to bin file and using decryptor, I can get my BIOS password.
          Now I have a problem that I am unable to dump my BIOS into bin file.
          My Surface Pro 3 currently runs on Ubuntu 22.04, with Secure Boot enabled and Boot From SSD Only.
          I searched for FPT but there is no Linux version and none of them work.
          I hereby request a copy of Intel Flash Programming Tool for Linux x64.
          I would really appreciate it if anyone...
          05-28-2024, 11:18 PM
