macOS Big SUR changed my life
  • dmill89
    • Dec 2011
    • 2534
    Re: macOS Big SUR changed my life
    Originally posted by BigTroll
    Oh boy, looks like I upgraded too soon.Louis Rossmann said the new OS spies on you. https://www.youtube.com/watch?v=aS2lJNQn3NA
    and it looks like it can corrupt your SPI ROM (Apple equivalent to BIOS) and brick your system on older machines as well:
    https://www.youtube.com/watch?v=9tQVQUd94Aw
    • Heihachi_73
      • Jun 2012
      • 713
      Originally posted by stj
      IMO apple turned to the darkside when they left Motorola and started using Intel.
      I thought they went to the dark side when they went to Motorola...
        • 31298
        68000 was a nice chip
        i never owned a "II" - who did they source their 6502's from??
        • RJARRRPCGP
          • Jul 2004
          • 6304
          When I hardly knew a thing about computers, when at The Vermont Achievement Center, in Rutland, Vermont, which I was there from probably late fall, 1988 to July 5, 1994, I saw IIs the most.
          Because, even when Macs had been around for a good amount of time, The Vermont Achievement Center, only had some Macs!
          And rarer, was an IBM!
          You actually had a better chance of spotting an Apple III in a classroom! Wow!
          Then when I went to Crotched Mountain Rehabilitation Center, in Greenfield, New Hampshire, starting on July 5, 1994, it was vice-versa, mostly PCs with Windows.
          I can't recall seeing an Apple III or an Apple II, in fact!
          Where there wasn't a PC for a computer, there usually was a Mac.
          ASRock B550 PG Velocita
          Ryzen 9 "Vermeer" 5900X
          Arc A770 16 GB
          eVGA Supernova G3 750W
          Alienware AW3423DWF OLED
          • Adenitz
            • Jan 2021
            • 122
            • Congo
            Hello to all,
            I have Macbook Air 1466 early 2015 and I tried to update macOS Catalina to Big Sur. After that when laptop starts there is a very loud fan noise like working on full speed and the screen is completely dark. I have tried SMC and NVRAM reset combinations but that didn't solve the problem.
            So I can safely say that macOS Big Sur changed my life also.
            Since there is a fan noise on the start, the motherboard is not dead. Did anyone have similar issues.
            • dragos2009
              • Mar 2013
              • 110
              #26
              wut i have a 2012 mbp 13inch on catalina and the startup chime was always there were there apple devices that didnt have this from factory and big sur added it back ?
              • BigTroll
                • Sep 2010
                • 1317
                • LAMBDA SOND
                #27
                Yeah my mac mini 2018 didn't have it, they started to remove it from models starting with the 2016 MBP, then added it back with big sur.
                My Computer: AMD Ryzen 9 3900X, Asrock X370 Killer SLI/AC, 32GB G.SKILL TRIDENT Z RGB DDR4 3200, 500GB WD Black NVME and 2TB Toshiba HD,Geforce RTX 3080 FOUNDERS Edition, In-Win 303 White, EVGA SuperNova 750 G3, Windows 10 Pro
                • BigTroll
                  • Sep 2010
                  • 1317
                  • LAMBDA SOND
                  #28
                  Originally posted by Adenitz
                  Hello to all,
                  I heard about it corrupting the spi rom or something on older machines, I also have a 1466 2014 Macbook Air and kept it on catalina for fear the update might bork it. Hope you find a solution to the problem.
                  • survivalbloke
                    Macbook A1398 - no startup chime, no boot, but have fans and CPU warm
                    by survivalbloke
                    Macbook A1398 - had repeating loop of startup chime with no actual boot. Just startup chime, then restart, start up chime, then restart, etc. I pulled the battery and cleared BIOS. It will now power up, fans on, CPU warming, but no startup chime and no boot. I reflashed the BIOS chip but the same thing happening. Where should I go from here?
                    06-14-2023, 11:45 AM
                  • valvashon
                    Samsung UN19F4000AF- half chime on startup
                    by valvashon
                    Yet another 19" TV here in the maintenance shop. This one belongs to my 95 year old mom so I'd really like to get it fixed for her.
                    Samsung UN19F4000AF. Back home for a week, I found this TV in her master bathroom unplugged and not connected to anything. Would start to power up and make about half of the Samsung startup chime, then shut back down.
                    Brought it back home with me but after having a quick look it no longer tries to start up and does not have the red LED lit in the IR receiver/switch thing.
                    Power supply is good, tested it on an exact same...
                    09-11-2023, 12:52 PM
                  • platinumsteel
                    Macbook Air 2015 Booting Very Slow and Stuck on apple Logo 99%
                    by platinumsteel
                    Hi guys i have my personal MacBook Pro 2015 820-00165 board that was working fine for more than a year and one day stopped working on my original Magsafe charger. It was turning on with my bench power supply. Opened it up and while diagnosing that somehow i ended up with a shorted smc.The line which was shorted was SMC_PM_G2_EN. I removed the SMC and short was gone. So all I had was another working donor board 820-3435 which i used to program it's SMC to 820-00165 using the SMCTOOL By MuertoGB.Took that SMC and use it on my 820-00165 board .And my board started working again. PPBUS_G3H 8.56V....
                    03-18-2024, 05:16 PM
                  • tvguy12012012120
                    by tvguy12012012120
                    02-07-2025, 05:13 PM
                  • duwane
                    A2141 (2019 16" MB Pro) Strange macOS install issues. NAND? WIFI? FIRMWARE?
                    by duwane
                    Hi All.
                    Sorry ahead of time for the text wall. This is a strange problem and I have tried to explain it as best I can. I realise this is a hardware forum (mostly), but I am still not sure if this is even a hardware fault! I am hoping that someone more knowledgeable than me in the area of understanding installation logs, or someone that has had a similar issue in the past may have some ideas of what might be causing this.
                    The issue:
                    Unable to do a clean install of any macOS versions supported for this model, even after fully erasing and formatting the internal SSD,...
                    10-26-2022, 07:02 AM
