trouble booting computer
    I does not happen everytime but most times, when I turn on my computer it gets about halfway through the booting proccess then stops, Then I cannot do anything I cannot even turn it off. I have to unplug it from the mains then plug it in and start booting again, it always works the second time, can anyone help solve my problem.
    Jim
    Re: trouble booting computer
    Howdy!
    Yup, bad caps on mobo or in PSU can do that.
    Can't tell you much more unless you give us some information to work with.
    Mann-Made Global Warming.
    - Dr Seuss
      Sounds like it's interal do you think I should take it for repair.
      Jim
        No, it COULD be internal. - It COULD just be Windows is screwed up.
        Since I have NO IDEA what you I have I can't check for known issues.
        If it is a caps issue most repair places will want to sell you a new motherboard or a new system because it is beyond their capacity to replace caps.
        What is the motherboard?
        What is the power supply?
        What is the Video card?
        Make and models please.
        - Dr Seuss
          I am sorry but I do not know the answer to any of the 4 questions even the make as we had it especially built is there anything I could try.
          Jiml
            I meant the make/models of the parts.
            If you are comfortable with doing some disassembly and finding numbers on things then we can try that.
            If not you are better off taking it to a shop.
            - Dr Seuss
              Thanks very much for the advice but it will have to go to the shop.
              Jim
                Kinda like saying my car stalls out occasionally and not giving the make/model.
                Could be anything from a hard drive problem to caps to power supply.
                  I hear ya but so what if PC's aren't jimpick67's thing?
                  - Probably an expert in some things you and I are clueless about.
                  - Dr Seuss
                    Quite possible.
                      Have you tried booting of the windows cd and running a chkdsk? Or unplugging some usb stuff and cards etc. I've never had a problem with bad caps on a psu affecting the boot and I can't see why it would.
                        easily. sometimes caps fail in a way that causes uptime to affect their degree of failure. one example is sometimes caps need to warm up to act properly if they are failed. say that caused a non-pnp device to fail, and when it begins to work, the booting computer gets a curve-ball by the sudden appearance, causing boot issues.
                        another way caps can affect boot is causing devices to act abnormally, causing errors.
                        sigpic
                        (Insert witty quote here)
                          I HAVE SEEN bad caps in PSU BLOW HOLES in chipsets [literally] and that definitely affected booting.
                          - Dr Seuss
