trouble booting computer
  • jimpick67
    I does not happen everytime but most times, when I turn on my computer it gets about halfway through the booting proccess then stops, Then I cannot do anything I cannot even turn it off. I have to unplug it from the mains then plug it in and start booting again, it always works the second time, can anyone help solve my problem.
    Jim
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: trouble booting computer
    Howdy!
    Yup, bad caps on mobo or in PSU can do that.
    Can't tell you much more unless you give us some information to work with.
    Mann-Made Global Warming.
    - Dr Seuss
    • jimpick67
      Sounds like it's interal do you think I should take it for repair.
      Jim
      • PCBONEZ
        Grumpy Old Fart
        • Aug 2005
        • 10661
        No, it COULD be internal. - It COULD just be Windows is screwed up.
        Since I have NO IDEA what you I have I can't check for known issues.
        If it is a caps issue most repair places will want to sell you a new motherboard or a new system because it is beyond their capacity to replace caps.
        What is the motherboard?
        What is the power supply?
        What is the Video card?
        Make and models please.
        - Dr Seuss
        • jimpick67
          I am sorry but I do not know the answer to any of the 4 questions even the make as we had it especially built is there anything I could try.
          Jiml
          • PCBONEZ
            Grumpy Old Fart
            • Aug 2005
            • 10661
            I meant the make/models of the parts.
            If you are comfortable with doing some disassembly and finding numbers on things then we can try that.
            If not you are better off taking it to a shop.
            - Dr Seuss
            • jimpick67
              Thanks very much for the advice but it will have to go to the shop.
              Jim
              • NxB
                • Feb 2009
                • 1595
                Kinda like saying my car stalls out occasionally and not giving the make/model.
                Could be anything from a hard drive problem to caps to power supply.
                • PCBONEZ
                  Grumpy Old Fart
                  • Aug 2005
                  • 10661
                  I hear ya but so what if PC's aren't jimpick67's thing?
                  - Probably an expert in some things you and I are clueless about.
                  - Dr Seuss
                  • NxB
                    • Feb 2009
                    • 1595
                    Quite possible.
                    • dan86
                      • Nov 2009
                      • 35
                      Have you tried booting of the windows cd and running a chkdsk? Or unplugging some usb stuff and cards etc. I've never had a problem with bad caps on a psu affecting the boot and I can't see why it would.
                      • ratdude747
                        Black Sheep
                        • Nov 2008
                        • 17136
                        easily. sometimes caps fail in a way that causes uptime to affect their degree of failure. one example is sometimes caps need to warm up to act properly if they are failed. say that caused a non-pnp device to fail, and when it begins to work, the booting computer gets a curve-ball by the sudden appearance, causing boot issues.
                        another way caps can affect boot is causing devices to act abnormally, causing errors.
                        sigpic
                        (Insert witty quote here)
                        • PCBONEZ
                          Grumpy Old Fart
                          • Aug 2005
                          • 10661
                          I HAVE SEEN bad caps in PSU BLOW HOLES in chipsets [literally] and that definitely affected booting.
                          - Dr Seuss
                          • Aeisens
                            Samsung UE50RU7170 not booting /no picture
                            by Aeisens
                            Dear all,
                            My issue is the following:
                            Tv suddenly started to make Strange things and went out. After disconnecting power and restarting, it tried to start but failed. After each attempt it got worse and worse. Now only the Stdb light is on and it is not booting.
                            I checked the power supply -> Backlight on when disconnected from mainboard, so I guess Power supply is ok.
                            Additionally the upper right part of the main-board makes some whistling noise -> probably issue there and therefore issues with booting
                            Question 1: Where should I start to...
                            06-24-2025, 03:07 PM
                          • Daniel Kubica
                            Dell Latitude 5590 i5-8350U LA-F411P kernel panic when booting from USB
                            by Daniel Kubica
                            I got a bare Dell Lattitude 5590 with missing battery, RAM, RTC battery and Storage, I wanted to put some components in it and use it as my home laptop. After adding a FRU 2GB DDR4 2400 SoDIMM RamaxelRAMI've tried booting Linux Mint from USB, I got an error while trying to boot it. I tried reseating the stick, different slot, didn't help.
                            I tried to boot Windows 10 installer, as that was the stock system my model came with, got a BSOD as soon as the installer started booting, different code every time. I've tried switching to AHCI mode, I've tried linux in legacy mode, I've tried compatibility...
                            06-14-2025, 09:24 AM
                          • sylvain_92
                            iMac 2009 A1312 2009 not booting - 3rd led not on
                            by sylvain_92
                            I am trying to repair my iMac A1312 late 2009 intel i5.
                            First of all it was booting but no screen on internal lcd but working with external one,
                            I tried:
                            - another screen and led power board (booting no screen - same as before)
                            - another mxm graphic card (not booting missing 3rd led)
                            * screen and mxm gpu tested are 100% working on another A1312 iMac.
                            I putted back the original mxm graphic card and what a surprise, now it's not booting anymore even with the stock parts.
                            The main...
                            12-23-2022, 03:36 PM
                          • slimmy182
                            MacBook Air M1 A2337 820-02016 not booting, taking 5V 0.42A and 2.173W
                            by slimmy182
                            Hello, a friend give me this M1 Mac Air, he said that it simply stop working. Apple preventive is replacing motherboard.
                            Model is MacBook Air M1 A2337, logic 820-02016, not booting, and taking 5V 0.42A and consuming 2.173W.
                            Once disassembled is very clean, no water damage at all. Visual ispection reveal no visible problem. Flir camera point to two hot point:
                            C81DC PP3V8_AON_VDDMAIN
                            And
                            Q5800
                            What should I test as next step?
                            Thank you very much!
                            02-01-2024, 01:08 PM
                          • bargo
                            Macbook air 820-00165-A fixing
                            by bargo
                            Hello folks,
                            I hope you are doing well.
                            I have had a macbook Air, from 2013 with 8GB 1.7GH one day (almost 1 year ago) it had failed, so you know as a human being, I had to try to fix it, but then i caused a lot of more trouble by shorting PPDCIN_G3H with PP5V_S4RS3 by mistake, which I then fixed to a good extent (macboook was powering up three times then normal boot, into internet recovery (which was not working) but booting into ubuntu via a usb stick went halfway, etc... so after so much time spent on this logic board replacing stuff to get it to that working state,...
                            02-15-2023, 06:24 AM
