Help Beeping machine
  • computergeek07
    • Jul 2005
    • 6
    I just recently re-capped a motherboard and now im trying to put it back into a system. I get it all put together and everything and cannot get it to shut up(stop beeping) It just sits there in continual BEEP........BEEP........BEEP.. I need some help on what i should try, I have switched processors, switched memory sticks, unplugged the hard drive, is there something disconnect or what's the problem? I get power and everything it seems like normal except for this annoying little BEEP.
  • bushytails
    Moderator
    • Dec 2004
    • 217
    Re: Help Beeping machine
    Check to make sure the CPU fan is one that gives an rpm signal, and that it's connected to the proper fan header on the board.
    --Randy
    • computergeek07
      • Jul 2005
      • 6
      Will the manual tell me exactly where to plug the fan into? Or do i just have to guess, because on the board there is a connector right directly behind the CPU so i figured this would correspond to run the fan, it seems to me that this is some kind of memory beep, but i have swaped the memory out, so I dont know what is going on. I will try your suggestion and see if i can find out if i connected the fan right or not.
      • kc8adu
        • Nov 2003
        • 8832
        • U.S.A!
        did the board work after recapping?
        did you test it outside the case?
        did it work before the recap?
        • computergeek07
          • Jul 2005
          • 6
          I am trying to test your first question, This is the point I am at, It worked before the re-cap i believe but it had bad video and the agp slot did not work to add a new video card because the caps took the functions of it out. No i haven't tried it out of the case, what is it i can do out of the case or where can i put it to test it that is safe and will not harm the board?
          • computergeek07
            • Jul 2005
            • 6
            Here is a few pictures of the before and after job, just to show and see what you think of the job.
            • RJARRRPCGP
              • Jul 2004
              • 6304
              Repeated and IF long bleeping is usually RAM related. It's probably because the RAM isn't being detected at all, the RAM is bad or it don't like the RAM.
              Short bleeping likely is caused by the motherboard thinking that there's a processor overheat problem.
              ASRock B550 PG Velocita
              Ryzen 9 "Vermeer" 5900X
              Arc A770 16 GB
              eVGA Supernova G3 750W
              Alienware AW3423DWF OLED
              • kc8adu
                • Nov 2003
                • 8832
                • U.S.A!
                just fire it up on a stat bag on the bench.
                that will eliminate things like standoff shorts.
                get it to a bright light and magnifier to check for solder shorts.
                as for the agp look for vrm damage near it.
                • computergeek07
                  • Jul 2005
                  • 6
                  I tried the method of putting it on the bench and didn't really find anything. But i got looking and found a trace that looks like it was melted and possibly destroyed during the soldering process. I dont know if this is it,but probably is, just thought i would offer this as a suggestion to the problem.
                    ALIENWARE Steam Machine R2 i7-6700T Specification for Upgrade or Repair
                    This specification for the ALIENWARE Steam Machine R2 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Steam Machine R2 boardview and Steam Machine R2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                    09-12-2024, 03:28 PM
                  • CG2
                    Janome DC3050 Sewing Machine Pedal Resistance
                    by CG2
                    OK, this is a long shot. I got this sewing machine cheap because it's end of line, ex-display, and had no pedal. The genuine pedal costs £60, while Ebay knock-offs go for around £15. So I went for the knock-off, it doesn't work, and I'm not sure whether it's the pedal or the sewing machine that has the problem.
                    Now this is an electronic machine, unlike the old fashioned sort where the pedal was a big resistor in series with the power to the motor. Here, the pedal is just (I think) a variable resistor fed with a 5 volt supply, and limited to a current of 5 milliamps. Assuming that...
                    04-14-2023, 07:53 AM
                  • Soulzink
                    Samsug washing machine. Power supply DC41-00189a board issue
                    by Soulzink
                    I am trying to fix a samsung washinmachine power supply main board.
                    I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
                    Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
                    The power supply board reference is the following: DC41-00189a
                    I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel...
                    04-19-2025, 06:26 AM
                  • unimatrix93
                    How to stabilize AC voltage to CNC machine
                    by unimatrix93
                    Hello there everybody, I'm not sure if it's the right topic to ask this but I hope so.
                    I have a CNC machine wired to 3-phase 230V AC.
                    It's a smaller CNC machine with a 3500W motor, do it does not uses much power.
                    The problem is, when the residents come home and put load on the network, the voltage can drop to around 207V which is fine for most household items but by CNC machine stops working from this.
                    I contacted the electricity company but they refuse to help me solve this problem.
                    So I started to look around for some DIY...
                    03-17-2025, 05:52 AM
                  • xdever
                    820-01700 not booting, 4V PP2V5_NAND_SSD0 but 2.5V when the machine is off.
                    by xdever
                    I got a 820-01700 of a friend that doesn't turn on. I read that a typical issue with these boards is the TPS62180 generating the NAND voltages, so this is where I started looking. Sure enough, PP2V5_NAND_SSD0 is 4V when the machine tries to turn on (I try to determine this by measuring PP2V5_NAND_SSD1, which is 2.5V as it should in this case. The PP0V9_SSD0 and PP1V8_SSD0 power supplies for the SSD are on at the same time when PP2V5_NAND_SSD0 is 4V). The extremely weird thing is that when the machine is off (PP2V5_NAND_SSD1=0, PP0V9_SSD0=0 and PP1V8_SSD0=0), PP2V5_NAND_SSD0...
                    01-15-2025, 08:44 PM
