Need to find a 34-Pin Motherboard Floppy Header
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16956
    Looking for some floppy headers.....searching the usual sources (digikey/mouser/etc) until my eyes bled, I couldn't seem to find such a beast. Yes, the silly 34 pin floppy header for a PC motherboard....
    Why? Well, I was given a bunch of Optiplex 330's, which are useless systems these days....and despite what some have said, they do not respond well to the E5450 c0 stepping LGA771 Xeon mod, tried several, it never worked. They're in a standard BTX case, so I tossed some $5 Optiplex 380 boards in them I picked up on ebay, which will run ANY 5400-series Xeon with hard mods + firmware.....
    The 330 system has a floppy drive, the 380 does not. However, the 380 has the blank for header on the motherboard and the setting in the BIOS.....SO.... I need the header!
    The reasoning is obvious, I want to try installing the header....which should make the floppy drive functional.....but for the life of me I can't find the headers. Scavenging them from junk boards is not worth all the aggravation, swear words, and destruction.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    Re: Need to find a 34-Pin Motherboard Floppy Header
    Would mouser's Molex 70246-3404 work? You will need to pull out/cut down one pin, however.
    BTW you still need to pay the aggravation, swear words, and possibly destruction when clearing the filled-in solder holes (because they likely need to be pristine to put the new headers in due to pin thickness), but yes at least you won't need to remove one from another board intact, which is tougher...
    • Topcat
      The Boss Stooge
      • Oct 2003
      • 16956
      Clearing the holes isn't a big deal.....and thanks for the P/N...after an hour of searchign I never found it. Yea, I know a few pins would need to be removed.
      Team : 49813
      Join in!!
      Team Stats
        • 31043
        .1" 34pin dual box-header
        usually listed under pcb interconnects
        • Topcat
          The Boss Stooge
          • Oct 2003
          • 16956
          I have some ordered. I'll update this with the outcome...the cases have floppy drives, it'd be nice to see them work versus removing them and having to find something else to fill the bay. I thought about card readers, but by the time I bought the card reader plus the cost of an internal card to run it (no internal USB headers), I'm being cheap and not wanting to spend that much on these. These will be some interesting frankensystems, but very usable, even today.
          Team : 49813
          Join in!!
          Team Stats
          • ratdude747
            Black Sheep
            • Nov 2008
            • 17136
            Are all the passives there too? I tried this (or something similar) on something similar if memory serves to no avail.
            That said, on the other hand, I added a HDA header to to the unpopulated header on an alienware X-Fi card I got for cheap (had dell's proprietary audio header populated instead)... which works great.
            sigpic
            (Insert witty quote here)
            • Topcat
              The Boss Stooge
              • Oct 2003
              • 16956
              That's the burning question, I don't know... It *appears* they are, and the setting in the BIOS to enable floppy... It was a cheap gamble, it may be a miserable failure.
              Team : 49813
              Join in!!
              Team Stats
              • Topcat
                The Boss Stooge
                • Oct 2003
                • 16956
                Originally posted by Topcat
                ...it may be a miserable failure.
                Yup, this flopped. Was an inexpensive gamble....but not sure why.... It doesn't seem any components were missing besides the socket itself (seat of my pants says it's a firmware issue)....but I have no clue.
                FWIW, another Xeon hack, this one was easy! Intel DG45ID motherboard. CPU had to be modified of course, but no firmware hacks needed and all instruction sets are supported. I stuck this board in a small slimline case, will be a fine 'work from home' special!!
                Team : 49813
                Join in!!
                Team Stats
                • eccerr0r
                  Solder Sloth
                  • Nov 2012
                  • 8701
                  did it attempt seek test at least or is the drive totally unresponsive?
                  • Per Hansson
                    • Jul 2005
                    • 5895
                    • Sweden
                    I see two floppy headers, one IDC and one slimline.
                    They are labeled DSKT & DSKT2 respectively.
                    Nearby are two jumpers, JP1 and JP5
                    Not sure if they are to select or something entirely different, there is a wiggly line so could be for a built in antenna too?
                    I would not give up so easily, post some really high resolution images of the front and back of the floppy area.
                    Possibly it is just missing some passives.
                    • Topcat
                      The Boss Stooge
                      • Oct 2003
                      • 16956
                      Completely unresponsive.
                      Attached are a couple high res pics....let me know if somewthing jumps out at you....
                      Team : 49813
                      Join in!!
                      Team Stats
                      • eccerr0r
                        Solder Sloth
                        • Nov 2012
                        • 8701
                        Which drive select did you use/did you use a twist or straight cable/connector?
                        I had an intel board where A: used a straight cable and B: was totally useless.
                        • Topcat
                          The Boss Stooge
                          • Oct 2003
                          • 16956
                          It was a cable from an optiplex 330. Looking at it, it is a twisted.
                          Team : 49813
                          Join in!!
                          Team Stats
                          • Per Hansson
                            • Jul 2005
                            • 5895
                            • Sweden
                            The missing R617 seems related to disk select from what I could trace out it is connected to IDC pin 2.
                            The missing R960 seems related to the step command, it seems connected to IDC pin 20.
                            That said it seems there are not many, if any components missing when comparing to your picture of the Optiplex 330
                            The idea by eccerr0r seems very well worth a try: possibly it uses a straight cable.
                            I also note this message in the BIOS setup you show of the Optiplex 380:
                            Note: The "USB Controller" setup option will affect floppy operation
                            How does Windows see the floppy, just fine? Floppy controller and all?
                            • Topcat
                              The Boss Stooge
                              • Oct 2003
                              • 16956
                              I don't remember seeing the floppy controller in Windows device manager...but if it doesn't detect the floppy, it disables it IIRC. I'll try the straight cable....certainly worth a shot....I'm sure I have a drawer full of them.
                              Team : 49813
                              Join in!!
                              Team Stats
                              • Per Hansson
                                • Jul 2005
                                • 5895
                                • Sweden
                                The "normal" behavior in old Award BIOS'es is that you can disable floppy seek, and the floppy itself.
                                (Select none instead of 720KB or 1.44MB) and then third you have the ability to disable the floppy controller.
                                Only the last one makes the floppy controller disappear in Windows.
                                Dell systems are simplified, no ability to select floppy size.
                                But I just tried it on my ancient Precision 470: with "diskette drive" set to "Off" no floppy controller was seen in Windows, or A:\ drive obviously.
                                With it set to "internal" (but no hardware present) it barked during POST that no floppy was present: but within Windows both the controller and A:\ drive showed up...
                                It might be interesting to see if the Optiplex 330 BIOS options for "diskette drive" have "internal" as a choice as well?
                                EDIT: If it is a BIOS issue it could be worth to check with Dell DCCU if more options are available that way:
                                https://www.dell.com/support/article...n-utility-dccu
                                • Topcat
                                  The Boss Stooge
                                  • Oct 2003
                                  • 16956
                                  Thanks for all the info!!
                                  If it's missing components mentioned above, I'm not sure 'trial & error' guessing would do much good....I'd need a schematic...or perhaps trace back the corresponding components on the 330....
                                  I will take another poke at this as soon as I get some of this other junk off my bench.
                                  Team : 49813
                                  Join in!!
                                  Team Stats
                                  • Per Hansson
                                    • Jul 2005
                                    • 5895
                                    • Sweden
                                    ^^When I wrote that about the missing components I had not yet compared it to your picture of the 330.
                                    When I did compare it was when I wrote:
                                    "That said it seems there are not many, if any components missing when comparing to your picture of the Optiplex 330"
                                    I think testing with a straight cable would be the first test, because the 330 does not have the slimline floppy connector from what I can see.
                                    So possibly the 380 is wired differently.
                                      • 31043
                                      why not just follow the 17 used tracks and see if any terminate at a component-pad
                                      • Topcat
                                        The Boss Stooge
                                        • Oct 2003
                                        • 16956
                                        I did a quick check between repairs. Straight cable versus twisted cable had no affect.... Definitely worth a try....but no go.
                                        This post created from the machine in question.
                                        Team : 49813
                                        Join in!!
                                        Team Stats
