best cheap/free scores 1.1
This is a sticky topic.
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Re: best cheap/free scores 1.1
    Originally posted by Topcat
    I think ya missed the point. PCI2.2 compliant. The 9550 isn't. These work in older stuff. Compared to ATA33/66/100, these scream, especially with Velociraptors, and have OS support all the way back to Win2k. These don't even have a BBU option, they're a pretty basic controller (good for what I'm using them for). Has a soDIMM slot on it for it's cache...I remember some of the scsi raid controllers had a full length SDRAM or DDR memory module slot on them.
    I've scoured looking for a PCI2.2 complaint SAS controller....sadly, there's no such animal...
    ^Yes they do have a BBU option... I used to run them, and I still have a couple 9500s-4LP's with BBUs somewhere (minus the batteries themselves, they were stolen to fix 9550's). Want them?
    Note that if these were dell OEM ones, the header for the BBU is probably missing, but the correct SMD pin header can be purchased from digikey and soldered on (as is one of mine, no issues)
    sigpic
    (Insert witty quote here)
    • Topcat
      The Boss Stooge
      • Oct 2003
      • 16955
      I don't see the BBU in that shot, the card wasn't shown much in that post....I don't know if they're Dell OEM, they dont have dell branded firmware....but that's not to say someone flashed them. I don't think they have headers...but I'll look closer next time I'm in the office.
      I lab ratted one of these on an asus P2L97-DS, slow old 66FSB P2 motherboard with a pair of P2 333's. Functioned nice, considering it was probably bottlenecking @ the PCI data width of 133mb/s. U2 SCSI is about half that. Keyed for 3.3v and 5v slots....
      <--- Badcaps.net Founder
      Badcaps.net Services:
      Motherboard Repair Services
      http://folding.stanford.edu/
      Team : 49813
      Join in!!
      Team Stats
      • ratdude747
        Black Sheep
        • Nov 2008
        • 17136
        It's there... look for black plastic and the the white battery. I'll see if I can find one of my 9500's and send a pic.
        The dell OEM ones had normal firmware... just no header.
        sigpic
        • ratdude747
          Black Sheep
          • Nov 2008
          • 17136
          Found one. The other is at my parent's house somewhere.
          The header is a 14 position SMD FEMALE header below the SODIMM slot.
          sigpic
          • Dan81
            SNES-powered
            • Oct 2013
            • 1865
            • Romania
            #3045
            Got some more free stuff:
            Gigabyte 8SIML - NEC OEM - this has to be the most idiotic combination ever - Choyo with Panasonic FL on low side and GSC on high side. Does POST though, and uses AMI BIOS as opposed to GB's stock Award BIOS. Came with two PQI DDR266 sticks, one 256 one 128MB.
            Epox EP-8K9A - works fine - caps are mostly Sanyo and Rubycon with a few Teapo in the mix, and two absolutely lone Lelon caps. And somebody was cheap enough to steal the CMOS jumper
            Seagate ST2000DM001 - spins up fine, and health looks suspiciously okay (almost like my main drive), bar a bunch of reallocated sectors (in the 100 range) but it is absolutely slow (38MB/s), and most of the times it won't show up in the POST. Any ideas? Drive looks pretty good.
            Main rig:
            Gigabyte B75M-D3H
            Core i5-3470 3.60GHz
            16GB DDR3-1600
            Samsung SH-224AB DVD-RW
            Delux MG760 case
            • Topcat
              The Boss Stooge
              • Oct 2003
              • 16955
              scored 11x scsi (sca) 300gb 15k cheetahs and 18x 2.5" 36gb 15k SAS HDD's.
              Team : 49813
              Join in!!
              Team Stats
              • Dan81
                SNES-powered
                • Oct 2013
                • 1865
                • Romania
                #3047
                Small update on the 8SIML:
                Recapped it with OST caps since it's not so important, and successfully flashed the retail Award BIOS. Now it can overclock!
                Still haven't figured out what to do with the 2TB drive - supposedly there is a firmware update for it, but it didn't work (due to slow response), and then there's a Nokia cable-based guide to fix it.
                Main rig:
                Gigabyte B75M-D3H
                16GB DDR3-1600
                Delux MG760 case
                • dragos2009
                  • Mar 2013
                  • 110
                  • Romania
                  #3048
                  remove the logic board from the hdd and check the contact points on where it connects to the drive reading heads most of the time the contacts on the board are corroded and dont make good electrical contact like you can see in the picture here https://imgur.com/a/TGgsdDl
                  • Topcat
                    The Boss Stooge
                    • Oct 2003
                    • 16955
                    I've fixed a LOT of western digital drives that way!
                    Team : 49813
                    Join in!!
                    Team Stats
                    • Dan81
                      SNES-powered
                      • Oct 2013
                      • 1865
                      • Romania
                      #3050
                      Turns out it wasn't that - yes, they were corroded - cleaned with rubber head from a pencil and then again with 99% IPA.
                      Instead, it might very well be the dreaded BSY problem. Problem is, I need a Nokia CA-42/DKU-5 cable, which are as rare as hen's teeth here.
                      That won't stop me from finding one though lol. I'd be more than happy to see this drive working at normal speed with new FW installed.
                      Main rig:
                      Gigabyte B75M-D3H
                      16GB DDR3-1600
                      Delux MG760 case
                      • goontron
                        5000!
                        • Dec 2011
                        • 4108
                        • US
                        #3051
                        ^ Its just a 3v3 serial UART cable. Ive used a Bus Pirate on this fix before.
                        Follow the white rabbit.
                        • Dan81
                          SNES-powered
                          • Oct 2013
                          • 1865
                          • Romania
                          #3052
                          I try to stick to the conventional ways, so USB to TTL it's gonna be.
                          Wonder if the PL2303HX works.
                          Main rig:
                          Gigabyte B75M-D3H
                          16GB DDR3-1600
                          Delux MG760 case
                          • jiroy
                            • Jun 2016
                            • 2416
                            • Lebanon
                            #3053
                            Right after the 4000$ custom build i'm still under pressure and working now on another customer 2500$ desktop . Built on Asus TUF gaming and Intel CPU 8700K , Nvidia Asus 8gb rams , and 32 GB of memory .
                            And here some pictures :
                            • jiroy
                              • Jun 2016
                              • 2416
                              • Lebanon
                              #3054
                              ..And to ease the pressure , I had fun building this 6x fan with 100 laptop batteries , lool ..
                                • 30941
                                that's an IED waiting to happen!!
                                you need fuses and other safety stuff or the good cells will interact with the poor ones!!
                                • jiroy
                                  • Jun 2016
                                  • 2416
                                  • Lebanon
                                  #3056
                                  Yes stj; Bad and risky batteries were already isolated , deep tests , no way to take risks in my shop ..
                                  Everything is double fused , even raw electricity , lol ..
                                  38 batteries are ready for disposal now ..
                                  • Topcat
                                    The Boss Stooge
                                    • Oct 2003
                                    • 16955
                                    I miss those days.... Today in the US, getting some cheapass to pay $400 for a system is a miracle.....$4000, forget it! Back when I started, most wouldn't bat an eyelash @ a $4000 system.
                                    What power supply is that?! It looks 18" long!
                                    Team : 49813
                                    Join in!!
                                    Team Stats
                                    • jiroy
                                      • Jun 2016
                                      • 2416
                                      • Lebanon
                                      #3058
                                      What if i tell you a third one is on the way and it will be an I9 based , hehe ..Another 4000$ i suppose . I deal mostly with famous Lebanese directors and artists , photographers and similar , so the key is , i think , Topcat , is Music and arts .. Always rich people they are , the ones that don't nag a lot (you know what i mean ) ..
                                      This is a cover hiding the 650W power supply and the optional harddisks..
                                      • ChaosLegionnaire
                                        HC Overclocker
                                        • Jul 2012
                                        • 3264
                                        • Singapore
                                        #3059
                                        working now on another customer 2500$ desktop . Built on Asus TUF gaming and Intel CPU 8700K , Nvidia Asus 8gb rams , and 32 GB of memory.
                                        oh my goodness... is the hard drive i see a wd blue 1tb ezex? u know, those drives drop like flies. i'd rather see a wd re series drive go in there...
                                        • jiroy
                                          • Jun 2016
                                          • 2416
                                          • Lebanon
                                          #3060
                                          No ChaosLegionnaire , This one is 4TB Blue WD , but it's not the booting device , you can see in another shot , a close picture on the M2 Kingston 480 GB .
                                          • H34TO
                                            ITE IT8390 (IT8390E-256) programmer "ITE Download Board 4" user manual + firmware, flashing ITE ECs on the cheap
                                            by H34TO
                                            Recently I've gotten into EC flashing due to my broken laptop(s) and started frantically searching methods for flashing the IT5571E-128 chip on the cheap(due to me beaing a student and not having a job) and noticed that ITE newer chips can be flashed via ISP (In-System Programming) either via SMBus or the KBC (EPP - Enhanced Parallel Port) interface. While these can be achieved with programmers like SVOD4/3 or the RT809H/F those options are WAYYY out of my budget so I was horrified. But recently I stumbled uppon some programmers on aliexpress that claim they can program a variety of ITE chips...
                                            06-17-2025, 07:17 AM
                                          • evilkitty
                                            When your mom is complaining about her new cheap lights
                                            by evilkitty
                                            My Mom bought some cheap motion sensor lights on wish... then complains about about batteries and this thing chews though them, well it uses 4 AAA batteries and a pack of rechargeable ones is about 13 USD
                                            well since it uses 4 AAA and rechargeable are 1.2v and non-recharge at 1.5 this thing must work with 4.8-6v, I'll shove a USB cable on it, infant i will use a broken phone charge cable... dam this thing uses 430 mA and they made it battery powered...
                                            lets ignore the fact that i thought the board fit both ways... and the wire color is reversed going to the board...
                                            07-23-2024, 01:27 PM
                                          • aaronkatrini
                                            by aaronkatrini
                                            - Autorange
                                            - DC volts up to 30V
                                            - Accurate Resistance
                                            - Diode test (Beep mode)
                                            - Frequency up to 200MHz
                                            - Capacitanze up to 5000uF
                                            - as cheap as possible
                                            05-06-2024, 09:54 AM
                                          • Dan81
                                            The Cheap Duo - Two SiS machines
                                            by Dan81
                                            Just as the title states. Two cheap SiS machines, surprisingly stable.
                                            What I will tackle in the near future (the build will be slightly postponed due to slight stomach issues - am still recovering and my physical power (sorry if it sounds weird,English isn't quite my primary language) isn't the best at the moment. Especially with the diet I have to take at the moment.) are two SiS based machines.
                                            The first one is a IPC rebranded Mitac 7521T. Why did I feel the need to tackle this machine? Well, just look at the specs:
                                            CPU - P3 1100MHz Coppermine...
                                            04-16-2022, 12:28 PM
                                          • eccerr0r
                                            Caseless Cheap Chinese electronic tools
                                            by eccerr0r
                                            "Caseless Cheap Chinese electronic tools" I mean things you get from banggood, ali, fleabay, Am-Zon, etc. like AVR-Transistortester, miscellaneous signal generators, frequency counters, (variable) power supplies, oscilloscopes, low resistance meters, etc., etc. that comes optionally with a case, or comes only with a cheap piece of plastic that barely provides protection to the PCB.
                                            Just wondering what of these (generally flimsy) tools you actually find use (almost) everyday and find indispensable for the price, compared to buying a Fluke or whatnot, if there is an expensive...
                                            11-23-2021, 03:44 PM
