best cheap/free scores 1.1
This is a sticky topic.
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16959
    Re: best cheap/free scores 1.1
    $25.00 ebay score = Supermicro P6DGU dual slot-1 GX chipset motherboard. Been looking for one on and off for a while, I have the dedicated 'RAID port' add-on card for the onboard SCSI that goes to one of these (came in a junk box years ago). I don't know if either works, the motherboard was listed as untested and I've never had a board to test the raidport card....so $25 gamble, I'm not too worried if none of it works, I've gambled a lot more than this on pool & football games.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • Dan81
      SNES-powered
      • Oct 2013
      • 1866
      • Romania
      #2982
      Got a free ECS 755-A2 v1.0 that won't POST (or beep for that matter), further check showed corrosion.
      Also got a ASUS A9550GE/TD/256M/A
      Main rig:
      Gigabyte B75M-D3H
      Core i5-3470 3.60GHz
      16GB DDR3-1600
      Samsung SH-224AB DVD-RW
      Delux MG760 case
      • RJARRRPCGP
        • Jul 2004
        • 6304
        Originally posted by dmill89
        A few recent scores.
        Dell OptiPlex 790 SFF for $20:
        Epson LX350 9-Pin dot-matrix printer with 2 new ribbons for $15:
        IBM Thinkpad T40 for $10:
        In case you're wondering what on earth I'd do with such an ancient laptop, IBM actually released Windows 9x drivers for these so with a 1.5 Ghz. Pentium M, 512 MB ram, and a mobility-Radeon 7500 it makes a nice Win 9x system and will even run most games from that era well.
        I see good ol' Windows 98 SE!
        ASRock B550 PG Velocita
        Ryzen 9 "Vermeer" 5900X
        Arc A770 16 GB
        eVGA Supernova G3 750W
        Alienware AW3423DWF OLED
        • brethin
          • Dec 2008
          • 1907
          My T40 has a 2ghz CPU and 2 GB ram running Windows 7 ultimate.
            • 31278
            that must run like shit on 32bit.
            sounds like you have an M760 cpu.
            • Curious.George
              • Nov 2011
              • 2305
              • Unknown
              #2986
              Another pair of Cisco 2960's (no idea why I'm seeing so many of these, lately).
              And, the "insignificant but most treasured" prize is a set of 3 Cisco "console" cables. These will be SO much easier to keep track of than my homemade cables!
              • brethin
                • Dec 2008
                • 1907
                It runs great.
                • Topcat
                  The Boss Stooge
                  • Oct 2003
                  • 16959
                  Raided a local computer shop, got 4x Mitsumi floppy & card reader combos. I never even knew these existed!! Awesomeness!
                  Team : 49813
                  Join in!!
                  Team Stats
                    • 31278
                    i think i have one new in the box.
                    it may be a different make though.
                    • ChaosLegionnaire
                      HC Overclocker
                      • Jul 2012
                      • 3266
                      • Singapore
                      #2990
                      wow nice... usb 3 in 1 floppy card reader. i think i might need one as well. will u be flipping them on junkbay? hehe!
                      topcat, might i trouble u to post the top shot of the mitsumis showing the model number sticker? is it fa404m? thanks man!
                      EDIT: on second thought, after raiding ebay for pics. the connector on the drive doesnt appear to be usb but some kind of 4 pin connector. any idea what that is?
                      • ratdude747
                        Black Sheep
                        • Nov 2008
                        • 17136
                        If they're the right version, with a FW upgrade they can do SDHC. IIRC it's' V1.6 and higher. I can't find it at the moment but I know it's posted on here somewhere.
                        I have two of these myself. Not used anywhere, but good drives nevertheless.
                        sigpic
                        (Insert witty quote here)
                        • ratdude747
                          Black Sheep
                          • Nov 2008
                          • 17136
                          USB. 4 pin heqder for internal use. No shield.
                          sigpic
                          • Topcat
                            The Boss Stooge
                            • Oct 2003
                            • 16959
                            Yes, they are FA404M drives. I tested them all, they all work. The beige one is going in one of my retro rigs.
                            I've never updated firmware on a floppy drive or card reader...
                            Team : 49813
                            Join in!!
                            Team Stats
                            • Curious.George
                              • Nov 2011
                              • 2305
                              • Unknown
                              #2994
                              Card readers, optical media drives (WORM, CD, DVD), NICs, CPUs, damn near any USB peripheral, etc. all increasingly rely on firmware updates (to fix the crap the manufacturer didn't realize initially).
                              A big part of each system build that I undertake is verifying the firmware for all of the devices is up-to-date before starting the OS install. Often, it's hard to "inspect" current version numbers. So you have to locate an update and try to apply it -- only to have it tell you "this device does not need an update".
                              And, firmware can often vary from OEM to OEM and application to application. My DLTs had all sorts of different firmware upgrades depending on where and how I intended to use them! <frown>
                              • ratdude747
                                Black Sheep
                                • Nov 2008
                                • 17136
                                https://www.badcaps.net/forum/showpo...6&postcount=19
                                Just a windows .exe updater. It's in Japanese but the firmware is the same. Took some digging to find it back in the day, but now it's uploaded here for all eternity.
                                sigpic
                                • Topcat
                                  The Boss Stooge
                                  • Oct 2003
                                  • 16959
                                  Cool, thanks. I'll try it tomorrow when I get in the office.
                                  Team : 49813
                                  Join in!!
                                  Team Stats
                                  • Curious.George
                                    • Nov 2011
                                    • 2305
                                    • Unknown
                                    #2997
                                    A friend just dropped off a box of workstation graphics cards (AGP & PCIe -- several Quadro 6000's, a couple of GTX960's, etc.) that he picked up in an auction lot, this week. I'll probably just trade them away to a friend/colleague for something I may find interesting.
                                    But, I want to avoid trading stuff of "unknown quality" as it can leave a sour taste in folks' mouths.
                                    If I simply plug each card in and verify that I can get "generic" (low resolution) video and something towards the upper end of their display capabilities ON EACH INTERFACE and verify fans are working (for those cards that have fans), is that a "close enough for government work" test? I.e., how likely is it that something subtler has failed that won't be apparent if the card "appears" to work?
                                    [Note there are rarely any claims made as to the quality of goods purchased at auction so I can't even say they were "working pulls".]
                                    Or, should I not bother testing at all and just treat the lot as "as-is, where-is"? Its future recipient may "get lucky" or he may end up with a bunch of recyclable boards...
                                      • 31278
                                      i would run a 3d game or a stress-test program to get them warm.
                                      • Curious.George
                                        • Nov 2011
                                        • 2305
                                        • Unknown
                                        #2999
                                        Ah, OK. Good point.
                                        But, will a "failure" manifest as some sort of NOTICEABLE visual artifact(s) or an outright crash? If a disk drive fails to produce data for a read() operation, the OS logs that event. I can examine the logs to see if the disk is having issues. I can run a disk benchmark and see if it is having to retry operations (affecting throughput) and note degradation in performance as a crude indicator of the drive's integrity.
                                        Is there anything similar when it comes to a video card? If some benchmark claims the card can do <whatever>, would that same benchmark ALWAYS yield the same performance for a "good" card? Would it show reduced performance for a compromised card? Or, would it just "not run"??
                                        • ratdude747
                                          Black Sheep
                                          • Nov 2008
                                          • 17136
                                          GTX 960's? Those are actually quite recent... If they do work (power up, no artifacts after 30 mins of use), you'd probably be able to sell them pretty easily. If they're a matched pair, then that would be good for an SLI rig. I've been sorta looking for a pair, actually; from what I've seen even the 960's still go for a pretty penny.
                                          The rest, it depends. Older AGP may have some retro value, newer would have upgrade value for old systems; neither would have mass appeal though. For the other PCIe's, it depends on what exactly it is; older ones have lost a lot of value due to the massive improvements in GPU performance in recent years and also are more prone to failure. Newer cards run cooler in addition to having much better performance.
                                          sigpic
                                          • H34TO
                                            ITE IT8390 (IT8390E-256) programmer "ITE Download Board 4" user manual + firmware, flashing ITE ECs on the cheap
                                            by H34TO
                                            Recently I've gotten into EC flashing due to my broken laptop(s) and started frantically searching methods for flashing the IT5571E-128 chip on the cheap(due to me beaing a student and not having a job) and noticed that ITE newer chips can be flashed via ISP (In-System Programming) either via SMBus or the KBC (EPP - Enhanced Parallel Port) interface. While these can be achieved with programmers like SVOD4/3 or the RT809H/F those options are WAYYY out of my budget so I was horrified. But recently I stumbled uppon some programmers on aliexpress that claim they can program a variety of ITE chips...
                                            06-17-2025, 07:17 AM
                                          • evilkitty
                                            When your mom is complaining about her new cheap lights
                                            by evilkitty
                                            My Mom bought some cheap motion sensor lights on wish... then complains about about batteries and this thing chews though them, well it uses 4 AAA batteries and a pack of rechargeable ones is about 13 USD
                                            well since it uses 4 AAA and rechargeable are 1.2v and non-recharge at 1.5 this thing must work with 4.8-6v, I'll shove a USB cable on it, infant i will use a broken phone charge cable... dam this thing uses 430 mA and they made it battery powered...
                                            lets ignore the fact that i thought the board fit both ways... and the wire color is reversed going to the board...
                                            07-23-2024, 01:27 PM
                                          • aaronkatrini
                                            by aaronkatrini
                                            - Autorange
                                            - DC volts up to 30V
                                            - Accurate Resistance
                                            - Diode test (Beep mode)
                                            - Frequency up to 200MHz
                                            - Capacitanze up to 5000uF
                                            - as cheap as possible
                                            05-06-2024, 09:54 AM
                                          • Dan81
                                            The Cheap Duo - Two SiS machines
                                            by Dan81
                                            Just as the title states. Two cheap SiS machines, surprisingly stable.
                                            What I will tackle in the near future (the build will be slightly postponed due to slight stomach issues - am still recovering and my physical power (sorry if it sounds weird,English isn't quite my primary language) isn't the best at the moment. Especially with the diet I have to take at the moment.) are two SiS based machines.
                                            The first one is a IPC rebranded Mitac 7521T. Why did I feel the need to tackle this machine? Well, just look at the specs:
                                            CPU - P3 1100MHz Coppermine...
                                            04-16-2022, 12:28 PM
                                          • akwky
                                            by akwky
                                            Hi!
                                            04-14-2025, 01:56 PM
