best cheap/free scores 1.1
This is a sticky topic.
  • Dan81
    SNES-powered
    • Oct 2013
    • 1866
    • Romania
    #1961
    Re: best cheap/free scores 1.1
    Originally posted by momaka
    Oh, are you sure you are not just too used to seeing small teeny tiny 330/470 uF primary caps in those Deers, and now a 680 uF cap seems big?
    I have an old Astec 200 Watt server PSU. That thing has 2x 1200 uF primary caps - now those are HUGE. About the size of a D cell battery.
    Huh,I checked those 680uF caps and they're the same size a D cell,more or less.
    That said, this obviously shows that when Deer/Solytech wants to make a half-decent PSU, they can. I guess this is probably one of the very few units that is complete with input filtering, PPFC, and everything. To bad they used cheap caps again. But I guess it is also good that they used cheap caps, because that's how you were able to get a cheap score on this PSU.
    This one is actually pretty decent. One thing I found strange - if you have worked with Allieds (I guess you did - Allieds are actually the half-decent line of Deer,with L&C being the total uber crap line) you should remember that after the rectifier bridge (which mine has BTW),there's a MOV installed. In my Modecom PSU though,that MOV is replaced with a strange PCB - it has two 2.2uF 400V caps (Su'scon SK - not bothering to replace them as I don't have replacements and they're the small size you see on motherboards) and two pink resistors. Could be a PFC circuit,since the PFC coil 2-pin connector is just next to it.
    Apart from that,this Deer has anything you'd want - PFC coil (real and really heavy as well),approved Y caps covered in heatshrink (both on the PSU board and on the AC receptacle PCB),EE-25 choke (there's a choke on the AC receptacle as well,but it seems they used a copper choke instead of a EE-25 choke,probably because the space between the Y caps and the X cap on the receptacle (there's just one) is small),and of course thick and big heatsinks.
    Just the primary transistors are something I can't find over Google - TT2174. Can those be replaced with 13009's? 13009s are capable of doing 400W with a ERL-35 transformer,right?
    Main rig:
    Gigabyte B75M-D3H
    Core i5-3470 3.60GHz
    16GB DDR3-1600
    Samsung SH-224AB DVD-RW
    Delux MG760 case
      • 31281
      what can these be used for? i will have a read up on them but you have probably used these before.
      any time you need to check a crystal or oscillator, or if you need to tune one - like calibrating a tuner.
      you meter for example, only works upto 15MHz, mine only works to 10MHz.
      but this works upto 2,400MHz
      • vinceroger69
        • Mar 2012
        • 6714
        #1963
        another good gadget to have in your tool collection then i will have too order one.
          • 31281
          well if you prefer the old style, they sell one with a VFD instead of led's for a bit more.
          • TechGeek
            Computer Geek
            • Jan 2015
            • 2254
            VFD=
            Vacuum
            Fluorescent
            Display
            Permanently Retired Systems:
            Kooky and Kool Systems
            sigpic
              • 31281
              i thought that was well known
              • goodpsusearch
                • Oct 2009
                • 2850
                • Greece
                #1967
                WARNING! You should always remove those 2 caps and disable this circuit. It's completely useless and generates a lot of heat with 2 big resistors and the 2 diodes and the caps get cooked no matter what brand and series they are.
                • Dan81
                  SNES-powered
                  • Oct 2013
                  • 1866
                  • Romania
                  #1968
                  They're not big. They are nearly the size of those we find at stores. I think the circuit is disabled anyways due to the lifted pads on that small PCB.
                  Main rig:
                  Gigabyte B75M-D3H
                  16GB DDR3-1600
                  Delux MG760 case
                  • vinceroger69
                    • Mar 2012
                    • 6714
                    #1969
                    have you got a link?
                    • goodpsusearch
                      • Oct 2009
                      • 2850
                      • Greece
                      #1970
                      @Dan81 More info and pics here:
                      https://www.badcaps.net/forum/showth...827#post409827
                      https://www.badcaps.net/forum/attach...6&d=1389575592
                      and here:
                      https://www.badcaps.net/forum/showth...411#post282411
                      https://www.badcaps.net/forum/attach...0&d=1268166583
                      • kevin!
                        recapping PCB.
                        • Jul 2013
                        • 195
                        • España
                        #1971
                        Yesterday picked up 7 computers scrapyard.
                        2 IBM (pentium 4) 5 lenovo (core 2 duo, pentium D), 1 HP (PENTIUM 4).
                        thinkcentre all had the bad capacitor, repair those that were better (others were in very poor condition motherboard) and repair 2 thinkcentre time, one with a core 2 duo, and one with a pentium d 930.
                        The core 2 duo, the voltage regulator of the ram had a capacitor bad and sometimes the computer is restarted a 6.3v sanyo 1800 microfarads, were two equal and Feds look 2 case for 2 Nippon Chemicon 16v 1800 microfarads.
                        PS: I am writing this from the thinkcentre core 2 duo hehe.
                        Gaming pc:
                        nVidia RTX 3080 TI, Corsair RM750I.
                        Workshop PC:
                        Intel core i5 8400, Intel SSD 256GB, nvidia gt1030, asus b365-a.
                        Server:
                        • Towncivilian
                          • Jul 2014
                          • 22
                          • US
                          #1972
                          I have one of those ThinkCentre small form factor boxes. I modified the BIOS and CPU socket to fit a Xeon X3363 in it. Quad-core, 12M L3 cache. Working well so far, no bad caps!
                          ASUS P8Z77-V LK, i7-3790, 32GB DDR3-1600, GTX 750 Ti, 256GB 840 Pro & 2x1TB / 1x2TB, Creative SoundBlaster ZxR, FSP Aurum S 400W
                          abit IP35 Pro, Q9300, 16GB DDR2-800, GTX 750 Ti, 128GB 840 Pro & 1TB WD Blue, Corsair CX430
                          HP d530 CMT, P4 EE 3.2ghz (with modded BIOS for correct microcode), 4GB DDR-400, ATI 9600XT, X-Fi, 80GB Velociraptor, 500GB WD Blue, XP SP3, Sony SDT-9000 & Seagate CTD-8000 DAT drive for ripping audio DATs
                          abit BX133-RAID (recapped + SMD caps installed in processor socket), PIII-S 1.4ghz Tualatin, 768MB PC133, FX5600, SoundBlaster AWE32, 40GB Deskstar, Windows 98SE
                          Depeche Mode Live Wiki
                            • 31281
                            http://www.ebay.co.uk/itm/291433094715
                            you can also get the led one in about 5 colours if you look.
                            • vinceroger69
                              • Mar 2012
                              • 6714
                              #1974
                              cheers stj i have already saw the led ones some of these chinese testers etc are useful in electronics repairs im still waiting for my pre built est tester too come then i will finish my kit and maybe upgrade it.
                                • 31281
                                the hardest part with these chinese bargains is protection,
                                plastic cases can cost almost as much as the equipment, finding "something" that will do the job is also tricky.
                                  master hoarder
                                  • May 2008
                                  • 12175
                                  • Bulgaria
                                  #1976
                                  +1
                                  Don't think. Make that circuit gone! It is absolutely useless.
                                  Plus, you will end with more parts in your parts box .
                                  • vinceroger69
                                    • Mar 2012
                                    • 6714
                                    #1977
                                    Too be honest with my old esr tester i havnt bothered with a case for it this new one i may though try to find something that does the job.
                                    • Compgeke
                                      • Feb 2014
                                      • 524
                                      Picked up a ZTE Speed N9130 (aka ZTE Cocaine) for $7. Not a terrible phone hardware wise, just locked to Boost.
                                      Going to be used as a webcam but hardware wise it's not bad, being a 1.2 Quad Snapdragon 410 + a gig of ram. Sadly no custom roms for it, it'd be great with CM11 or 13.
                                        • 31281
                                        most ZTE can be unlocked very easily.
                                        • kevin!
                                          recapping PCB.
                                          • Jul 2013
                                          • 195
                                          • España
                                          #1980
                                          Re: Your Best Dumpster Finds
                                          A few days ago I picked up this:
                                          One is a core 2 duo (the best) only had to make 2 sanyo capacitors reccaping exploited by the heat.
                                          Go perfect!
                                          has:
                                          Core 2 duo e7200 (future upgrade Xeon 5430)
                                          ram: 2GB DDR2 (future upgrade 3GB ram)
                                          HDD 160GB
                                          GPU: Intel (upgraded to nvidia 610)
                                          What impressed me most about this computer is that it has integrated a speaker LOL
                                          The others are Pentium D, The others are Pentium D, 1 Pentium 4, I was able to recover 2 (Pentium D) more, also had bad capacitors.
                                          Then I gave this brand new Toshiba U500 a great friend, had overheating problems, and the problem was needed is a thin heating pad and thermal grease quality, and now works perfect.
                                          has:
                                          Intel core i5 450m
                                          310 Nvidia 512MB (MXM Slot)
                                          4GB ram
                                          640GB HDD.
                                          And finally, I found a computer 486 (AMD 100 MHz) PCI ports, and supports VGA PCI.
                                          The only bad thing is I have to change the dallas chip.
                                          Gaming pc:
                                          Workshop PC:
                                          Server:
                                          • H34TO
                                            ITE IT8390 (IT8390E-256) programmer "ITE Download Board 4" user manual + firmware, flashing ITE ECs on the cheap
                                            by H34TO
                                            Recently I've gotten into EC flashing due to my broken laptop(s) and started frantically searching methods for flashing the IT5571E-128 chip on the cheap(due to me beaing a student and not having a job) and noticed that ITE newer chips can be flashed via ISP (In-System Programming) either via SMBus or the KBC (EPP - Enhanced Parallel Port) interface. While these can be achieved with programmers like SVOD4/3 or the RT809H/F those options are WAYYY out of my budget so I was horrified. But recently I stumbled uppon some programmers on aliexpress that claim they can program a variety of ITE chips...
                                            06-17-2025, 07:17 AM
                                          • evilkitty
                                            When your mom is complaining about her new cheap lights
                                            by evilkitty
                                            My Mom bought some cheap motion sensor lights on wish... then complains about about batteries and this thing chews though them, well it uses 4 AAA batteries and a pack of rechargeable ones is about 13 USD
                                            well since it uses 4 AAA and rechargeable are 1.2v and non-recharge at 1.5 this thing must work with 4.8-6v, I'll shove a USB cable on it, infant i will use a broken phone charge cable... dam this thing uses 430 mA and they made it battery powered...
                                            lets ignore the fact that i thought the board fit both ways... and the wire color is reversed going to the board...
                                            07-23-2024, 01:27 PM
                                          • aaronkatrini
                                            by aaronkatrini
                                            - Autorange
                                            - DC volts up to 30V
                                            - Accurate Resistance
                                            - Diode test (Beep mode)
                                            - Frequency up to 200MHz
                                            - Capacitanze up to 5000uF
                                            - as cheap as possible
                                            05-06-2024, 09:54 AM
                                          • Dan81
                                            The Cheap Duo - Two SiS machines
                                            by Dan81
                                            Just as the title states. Two cheap SiS machines, surprisingly stable.
                                            What I will tackle in the near future (the build will be slightly postponed due to slight stomach issues - am still recovering and my physical power (sorry if it sounds weird,English isn't quite my primary language) isn't the best at the moment. Especially with the diet I have to take at the moment.) are two SiS based machines.
                                            The first one is a IPC rebranded Mitac 7521T. Why did I feel the need to tackle this machine? Well, just look at the specs:
                                            CPU - P3 1100MHz Coppermine...
                                            04-16-2022, 12:28 PM
                                          • akwky
                                            by akwky
                                            Hi!
                                            04-14-2025, 01:56 PM
