best cheap/free scores 1.1
This is a sticky topic.
    master hoarder
    • May 2008
    • 12175
    #3301
    Re: best cheap/free scores 1.1
    Originally posted by Topcat
    antistatic bag and then wrap them a couple times in small bubble wrap, and put them in a box with paper or more bubblewrap. They'll survive.
    I second this.
    I've received HDDs like that from eBay and never had problems. Anti-static bag + 2 layers of fine bubble wrap on each drive + some fine bubble wrap around the sides of the box should do the trick for up to 10-12 drives.
    Avoid the air pouches. Some use them in place of bubble wrap. Air pouches are okay for clothes and things that aren't sensitive. But for HDDs, it has to be bubble wrap.
    @ TC: I think I have 2 SCA HDDs I can send you. Posted in your dual Celly thread. Just have to check them out for functionality.
    • ChaosLegionnaire
      HC Overclocker
      • Jul 2012
      • 3264
      • Singapore
      #3302
      yea i can say that air pouches or air pillows dont work. due to the weight of the drive, if it suffers a jolt during transport, the weight of the drive would rupture or burst any of those air pillows. i often end up with deflated air pillows or pouches from shipped hard drives.
        • 31185
        do americans have bubble-wrap?? /sarc
        every item i got from the u.s. via ebay was packed in screwed-up newspaper pages.
        dont get me wrong, a good 4-6" of it all around, but always newspaper rather than bubblewrap.
        • RJARRRPCGP
          • Jul 2004
          • 6304
          Originally posted by Dan81
          Scored this PC. Not bad but definitely not the best either:
          ASRock P4V88+ mobo w/ 6 bulged KZGs (recapped)
          P4 HT 3GHz Prescott (no wonder why the caps died)
          1GB RAM
          Radeon 9250 128MB
          P&O LC-B400ATX (MAX:400W (yeah right.) gutless wonder
          Allied/APEX PC-115 case
          Samsung SD-612 DVD-ROM
          NEC ND-3540A DVD-RW
          Maxtor STM3160215A 160GB 7200RPM.
          Windows 7 (italian)
          Came with a free Windows 7 DVD as well, but don't know if it's SP1 at all.
          KZGs are known to bulge while sitting! (And it looks like a mid-2000s' CPU and motherboard, so no surprise that the KZG-series caps on that motherboard, are shit!)
          ASRock B550 PG Velocita
          Ryzen 9 "Vermeer" 5900X
          Arc A770 16 GB
          eVGA Supernova G3 750W
          Alienware AW3423DWF OLED
          • Dan81
            SNES-powered
            • Oct 2013
            • 1866
            #3305
            Depends. I had a batch of KZGs bulge while sitting on a MSI P965 Platinum, while these ones I removed from the ASRocl clearly pointed to the heat from the Prescott chip. (the caps were brownish-black instead of the usual light brown KZG have.) It also didn't help that the PSU was a Deer that has a EI-28 transformer. (yes, you read that right, EI-28 transformer!)
            Then there are some boards I have on which KZGs still live like nothing happened. I guess it also depends on what the CPU heat output is, because unsurprisingly these that didn't bulge yet were found on a uATX AM2 motherboard.
            Main rig:
            Gigabyte B75M-D3H
            Core i5-3470 3.60GHz
            16GB DDR3-1600
            Samsung SH-224AB DVD-RW
            Delux MG760 case
            • RJARRRPCGP
              • Jul 2004
              • 6304
              While they seem less likely to take a shit on Core 2-era motherboards, it still looks a bit too early to tell! I have yet to confirm a visibly-bad one with my own eyes on Conroe-era motherboards. (65nm Core 2 Duo)
              Arc A770 16 GB
              • Dan81
                SNES-powered
                • Oct 2013
                • 1866
                #3307
                Well, the P965 IS a Conroe-era board. As for bad without bulging, didn't really have such cases with KZG. I did have that happen though with at least a WHOLE round of G-Luxon and several TK ATWY caps on a Biostar motherboard.
                Main rig:
                Gigabyte B75M-D3H
                16GB DDR3-1600
                Delux MG760 case
                • RJARRRPCGP
                  • Jul 2004
                  • 6304
                  While they apparently can support Conroe with a BIOS update, there's a good chance that it's from 2005, or so it seemed (sorry) and thus still the Prescott-era and the like. (Cedar Mill, Smithfield or similar, IIRC)
                  2005 would put it in well in the bad cap danger zone! As even high-end Asus motherboards were known to have bulging and leaking wet-electrolytic caps! Yikes! After all, my 2005 Antec SmartPower 2.0 was confirmed to have a bad Fuhjyyu cap, in probably the standby zone! (I made the discovery in 2011, after hearing a whine, a lower-pitched squeal, like a radio, with the Acer Aspire M5630 PC off, when the house was very quiet, IIRC, back when I of course still lived at 105 Main St.)
                  Arc A770 16 GB
                  • brethin
                    • Dec 2008
                    • 1907
                    Only KZG I had bulge was in a Asus P4C800D that had a over clocked 3.4 and it was my fault for not cooling the case better.
                    • Topcat
                      The Boss Stooge
                      • Oct 2003
                      • 16958
                      Not your fault. KZG was bad for this. I've seen 'new old stock' KZG's die on the shelf. Seen gazillions of them fail in action.
                      <--- Badcaps.net Founder
                      Badcaps.net Services:
                      Motherboard Repair Services
                      http://folding.stanford.edu/
                      Team : 49813
                      Join in!!
                      Team Stats
                        master hoarder
                        • May 2008
                        • 12175
                        #3311
                        LOL! YES?
                        Weird. I've gotten bubble wrap way more often than newspaper. Come to think of it, I've gotten newspaper only on a few occasions. It was done very well and nothing got damaged. And the nice thing about newspaper is that I don't feel bad about dumping it back in the recycling bin. Bubble wrap, I try to save, if new or newish looking... and have accumulated a couple of big boxes already.
                        True for most of the older ones.
                        I haven't seen any bad ones with a date code of 2008 and later. That said, I would still avoid the 6.3V 3300 uF KZGs - just never seen any of them last.
                        Agreed. I consider the i915/945/955/965 chipsets to be Prescott -era too, even though both 945 and 965 will support some Core -based CPUs.
                        So if the board is old enough to have one of those chipsets, it's probably also has the potentially-flawed KZGs.
                        • RJARRRPCGP
                          • Jul 2004
                          • 6304
                          That's likely the same period as the Asus A7N8X-X I had, where the KZG-series caps on the motherboard, when just sitting, bulged with a Hawaii-style eruption at the top vents. (and some at least about to do that, if not already!)
                          Arc A770 16 GB
                          • Curious.George
                            • Nov 2011
                            • 2305
                            • Unknown
                            #3313
                            HP Pavilion dv7 (i5@2.5G, 8G, 500G) and a MS Surface (not sure which version).
                            • Curious.George
                              • Nov 2011
                              • 2305
                              • Unknown
                              #3314
                              I just got 10 in a box....it was a little 'girthy', but all was well. wrapped each drive 2 layers of bubble wrap was fine....so stacked, there was technically 4 layers, plus the antistatic bag....packed snug in the box with more bubblewrap so they weren't hitting eachother loosely.
                              OK, I'll do a dry run (with SATA drives) to see how many I can fit in a "conveniently available" box (so I don't have to keep a particular box on hand waiting for the next chance I have at rescuing some drives).
                              • Topcat
                                The Boss Stooge
                                • Oct 2003
                                • 16958
                                picked up 4x seagate 9.1gb 68-pin cheetah's for 20 bucks. They're the 1.6 height ones....they had slower seek speeds, but with all the platters + 10k RPM, they sound mean spooling up!
                                Team : 49813
                                Join in!!
                                Team Stats
                                • Uranium-235
                                  Comrade Glimmer
                                  • Aug 2007
                                  • 5042
                                  • US
                                  #3316
                                  I once got a Promise Vtrak 15100 for $100
                                  all bays, both psus still worked. Tested it after I cleared out the settings with a serial cable.
                                  • goontron
                                    5000!
                                    • Dec 2011
                                    • 4108
                                    • US
                                    #3317
                                    Nice icon U235
                                    Follow the white rabbit.
                                    • Uranium-235
                                      Comrade Glimmer
                                      • Aug 2007
                                      • 5042
                                      • US
                                      #3318
                                      • Topcat
                                        The Boss Stooge
                                        • Oct 2003
                                        • 16958
                                        ^ I probably don't even want to know the story behind any of that!
                                        Team : 49813
                                        Join in!!
                                        Team Stats
                                        • Uranium-235
                                          Comrade Glimmer
                                          • Aug 2007
                                          • 5042
                                          • US
                                          #3320
                                          It's a character from a cartoon. There was an animation error that made her eyes, well, like they are in my avatar. Everyone found it funny so they kept it like that, made her somewhat...slow (though she makes very few appearances throughout the show). The fans eventually called her "derpy" (south park reference). Her name made it into the show but some asshat parents thought they were making fun of retarded people so they just cut her name out (although her (derpy) name still shows up in the closed caption to this day). Shes somewhat of a lovable eh, 'disabled' pony that only made her mark from animation mistake and fanart
                                          edit: After the derpy incident, they offically named her "Muffins". Later in one of her few appearances, she officially had some connection to her name
                                          https://www.youtube.com/watch?v=BO9JRtLYhRQ
                                          • H34TO
                                            ITE IT8390 (IT8390E-256) programmer "ITE Download Board 4" user manual + firmware, flashing ITE ECs on the cheap
                                            by H34TO
                                            Recently I've gotten into EC flashing due to my broken laptop(s) and started frantically searching methods for flashing the IT5571E-128 chip on the cheap(due to me beaing a student and not having a job) and noticed that ITE newer chips can be flashed via ISP (In-System Programming) either via SMBus or the KBC (EPP - Enhanced Parallel Port) interface. While these can be achieved with programmers like SVOD4/3 or the RT809H/F those options are WAYYY out of my budget so I was horrified. But recently I stumbled uppon some programmers on aliexpress that claim they can program a variety of ITE chips...
                                            06-17-2025, 07:17 AM
                                          • evilkitty
                                            When your mom is complaining about her new cheap lights
                                            by evilkitty
                                            My Mom bought some cheap motion sensor lights on wish... then complains about about batteries and this thing chews though them, well it uses 4 AAA batteries and a pack of rechargeable ones is about 13 USD
                                            well since it uses 4 AAA and rechargeable are 1.2v and non-recharge at 1.5 this thing must work with 4.8-6v, I'll shove a USB cable on it, infant i will use a broken phone charge cable... dam this thing uses 430 mA and they made it battery powered...
                                            lets ignore the fact that i thought the board fit both ways... and the wire color is reversed going to the board...
                                            07-23-2024, 01:27 PM
                                          • aaronkatrini
                                            by aaronkatrini
                                            - Autorange
                                            - DC volts up to 30V
                                            - Accurate Resistance
                                            - Diode test (Beep mode)
                                            - Frequency up to 200MHz
                                            - Capacitanze up to 5000uF
                                            - as cheap as possible
                                            05-06-2024, 09:54 AM
                                          • Dan81
                                            The Cheap Duo - Two SiS machines
                                            by Dan81
                                            Just as the title states. Two cheap SiS machines, surprisingly stable.
                                            What I will tackle in the near future (the build will be slightly postponed due to slight stomach issues - am still recovering and my physical power (sorry if it sounds weird,English isn't quite my primary language) isn't the best at the moment. Especially with the diet I have to take at the moment.) are two SiS based machines.
                                            The first one is a IPC rebranded Mitac 7521T. Why did I feel the need to tackle this machine? Well, just look at the specs:
                                            CPU - P3 1100MHz Coppermine...
                                            04-16-2022, 12:28 PM
                                          • akwky
                                            by akwky
                                            Hi!
                                            04-14-2025, 01:56 PM
