No boot issue....silly antec
  • etnietering
    • Apr 2009
    • 379
    OK, here's the story: I upgraded my computer a few weeks ago to a Core i7, etc, and sold my old stuff to my little brother. So he puts it all in his case, and when he turns it on the fans and hard drives and everything spin up, but no video activity or anything. So we unplugged the hard drives and cd drives, and still nothing. Then I told him to take out the RAM and try running it one stick at a time, with each of the 4 sticks. Still nothing.
    So then tonight I start working on it. First I unplugged everything and took the motherboard out, and inspected it. No visible damage, other than where my water cooling system peed on it, and the leftover foam crap from CPU backplates, both of which were there when I was using the board, when it worked. Put it back in, hooked it up to just the power and the power switch, and still nothing. Then I tried using the jumpers on the motherboard to reset the BIOS - same result. So then I thought to myself hmmm it could be the power supply.....so I take out the power supply, open it up, and what should I see but leaking capacitors! Well, just one leaker, but two bulgers too. The leaker and one bulger are on the +5vsb, and the other bulger is an input cap. So then I put in my newly renovated logisys psu, thinking that if something's wacky with that psu then it would work with mine, and I still get the same thing.
    So having his psu opened, I plugged it in, and looked at the +5vsb reading, I get 5.42v with no load, and when I put in a 51ohm resistor, I get 5.02v. So it seems to be working, but I don't know what happens when it gets hot. I read on other posts here that if the +5vsb gets too high it can fry the southbridge, so I looked at the southbridge chip and I can't see any scorching or melting or anything bad.
    Does anybody have any insight or ideas that could help me?
    Here is (hopefully) all of the relevant information:
    His PSU - Antec SmartPower 500W
    his mobo - Intel 855XBK
    he got a msi 9600GT for a video card, but when I've got my psu in there I've got the PCI radeon 7500 out of my server.
    he's had his antec for about 2 years now I think, and it was running his old system just fine (p4 2.0 w/ 768MB pc133)
    That should be everything you need to know...but chances are good that I forgot something...any ideas anybody has would be great though Thanks!
  • 370forlife
    Large Marge
    • Aug 2008
    • 3112
    Re: No boot issue....silly antec
    ewww smartpowers are from when antec had a little fling with fujiyuu.
    Does the re-done logisys work well on other computers?
    Fujiyuu and CWT moved out after being caught cheating with about every other psu maker out there, CWT is a major whore in the psu business, been with a lot of manufacturers. But they have gotten rid of their std Fujiyuu, and is now a high-class whore.
    Antec plays it safe now and only has dinner with delta and seasonic, as well as fsp on their lower end models.
    • KeriJane
      Mac Enthusiast
      • Sep 2008
      • 681
      Hi Etnietering
      You should not risk plugging that particular PSU into any parts you might want to not destroy.
      Any bulging or leaking caps in a PSU are really bad.
      Most likely that Smartpower has the infamous Fuhyjju brand caps that are likely over-rated in the first place and veery prone to failure inside a hot-running Antec PSU. Any one of them can destroy all manner of computer parts such as motherboards, hard drives, videocards, etc.
      The Antec Smartpowers didn't tend to get all crazy on the 5vsb like some Bestecs did. The Smartpowers would more often get insanely high Ripple on the 12v, 5v and 3.3v rails. The bulging caps are connected to 5vsb? Probably not worth the risk of hooking it up.
      This Ripple can cause instability, no boot or widespread damage.
      Any other PSU to try other than the re-work? I wouldn't recommend trying this one on yet another system.
      Your best option is to replace the PSU immediately and if you feel like experimenting, order up some Low ESR caps for it.
      Good Luck,
      Keri
      The More You Learn The Less You Know!
      • etnietering
        • Apr 2009
        • 379
        yeah, the two little bastards on the +5vsb are fuhjyyyyyyyyu's, but they're the only bad ones on the secondary side. i also saw some teapo and koshins, but those are the really tiny ones. the input caps are panasonic! I can't believe a panasonic would go bad...this thing has two fans, and great airflow around the primary caps, and the +5vsb are RIGHT in front a fan....
        edit: the secondary side is stuffed full of fuhjyyu - but those are the only two bad ones. I'm going to tell my brother to either let me recap it (for the price of parts) or get a new power supply, regardless of what he has to do about maybe getting a new motherboard or something, if this one is fried.
        • KeriJane
          Mac Enthusiast
          • Sep 2008
          • 681
          Here's where an ESR meter or a Oscilloscope makes a great friend.
          That's the best way to tell what's going on in the Dark Forest of Fuhyjju.
          They don't always pop the top. Usually, but not always. Looks Good doesn't mean Is Good.
          The cooling in a SmartPower isn't as good as it would appear. In many models the exhaust fan didn't even turn on until things got really toasty and in all models they are designed to run slowly and quietly.
          Higher-speed fans or reworking the controller for better cooling is a good idea when recapping.
          If you were in the neighborhood you could scope it over here....
          Good Luck,
          Keri
          • NxB
            • Feb 2009
            • 1595
            It won't start if the ripple is too much. You actually have quite a few failed caps in there that could be shorted or open. Replace with slightly larger uF values (at least 105C) if you want to keep your power supply, otherwise buy a new one.
            I haven't had any repeat failures when recapping the supply except for bestecs. You should be fine.
            If it still shows no video with a different power supply then it probably took the chipset or mosfets/caps.
            • etnietering
              • Apr 2009
              • 379
              I WISH I had an oscilloscope...although if I did I'd probably fail school then because I'd be too busy playing....hehe...I'm about 6 hours from chicago...sorry, maybe I could go to work with my dad one day and use the lab they have there...
              I do remember noticing how quiet it was when he got it (not that it matters with the rest of his fans though) but I just assumed that they wouldn't be boneheaded enough to run the fans so slow that the caps would cook....silly me
              I looked more closely at the VRMs and such on the motherboard, and couldn't see any visible damage...
              I think what I'll do next (probably tomorrow) is try my logisys in his old motherboard, just to make sure it's actually working. It's too bad that that's the only lga775 motherboard in the house...maybe my friend would let me borrow some of his stuff for testing and troubleshooting
              oh, the mobo is actually a 955XBK, not an 855, and the CPU is a Pentium D 830
              • Krankshaft
                • Jan 2007
                • 2328
                I bought my Antec for the quiet fans. The factory fans and the controllers settings are fine for quality cap brands. I used Panasonic FCs.
                Remember that the PSU has 2 fans the one on the inside of the computer case is always running. The rear fan is the one that only comes on when the temps get high enough.
                It's not the heat Fukyuu caps are crap hands down. They'd fail during operation in a vat of liquid nitrogen .
                I've personally recapped 3 Smartpowers and 1 Truepower great supplies that haven't let me down yet.
                • Toasty
                  • Jul 2007
                  • 4171
                  Before you touch anything, how old is that PSU?
                  Antec was (up to 3 months ago) still RMA-ing SP's & SP2's.
                  Go to their site and start a support ticket. You'll need the S/N off the PSU.
                  If they give you a hard time about it being too old, you can always be *ahem* "creative" about a sales invoice...
                  Here's the link for support:
                  http://www.antec.com/Believe_it/inde...support_online
                  Toast
                  veritas odium parit
                  • ratdude747
                    Black Sheep
                    • Nov 2008
                    • 17136
                    NOOOOO!!!! do not rma it! all that does is send you a new box of shit. fix the one you got or buy a delta, seasonic, etc. if you go the recap route, maybe wire the rear fan straightly to 12v (or both 5 and 12 if you want to undervolt it some, i personally don't like undervolting). hardwired fans always keep stuff cool.
                    also some pice would be nice. the antec that came with my dad's case from 7 years ago had crappy heatsinks. it got the gut-for-fans-and-wire treatment.
                    sigpic
                    (Insert witty quote here)
                    • Toasty
                      • Jul 2007
                      • 4171
                      >>all that does is send you a new box of shit.<<
                      Opinion or fact? Recent dealings with Antec?
                      Please explain.
                      Toast
                      veritas odium parit
                      • ratdude747
                        Black Sheep
                        • Nov 2008
                        • 17136
                        well if model x was a crap model, then rma sends you another one of the same crap model. you might have bought some more time but it is till a gamble. i would imagine what they would send would be shit. i do not own any newer antecs since they are so $$$$$$$. i am justfing my response on logic.
                        fix it and be done. would be more reliable in my opinion.
                        sigpic
                        • KeriJane
                          Mac Enthusiast
                          • Sep 2008
                          • 681
                          Hi ratdude
                          Sorry, but that's not how Antec is handling RMA these days.
                          The crappy 'ol SmartPowers and TruePowers are no longer in production. They are not about to go to the expense of re-starting production for warranty returns. They do not have a giant stockpile on hand either.
                          Antec has been sending out vastly superior Delta and Seasonic PSUs for RMA.
                          I know this because I bought a Delta sourced Earthwatts 500 from someone that RMA'd a TruePower recently and got the Delta in return. I posted it here somewhere once.
                          The Delta appears to be a very well done PSU.
                          RMA if you can,
                          Keri
                          • bgavin
                            • Jan 2007
                            • 1355
                            KJ, that is good to know.
                            I have shit canned old ANTEC supplies because I don't want another of same as an RMA.
                            • Toasty
                              • Jul 2007
                              • 4171
                              Thank you KJ. It's precisely the point I was going to make. I've done 2 - SP2's since February this year and both have been replaced with Earthwatts Deltas.
                              Both were "pay-in-advance" transactions where Antec cross-shipped the replacements and I paid for shipping back of the old ones. Once they received the dead ones, they refunded my money, but not my return shipping. Fair enough... $8.95 for a new 500 watt PFC supply.
                              Recapping is all fine and good. But, you can replace every single cap for let's say less than $25 including shipping, on a 5-7 year old PSU, only to have a major failure in the FET's or a transformer a week later. Where are you?
                              Also, as I have said in other posts, your time and effort has to be worth something. At minimum wage you're going to easily chew up $30 of time you could be flippin' burgers. I'm hungry dammit!! Where are you?!
                              Or, pay under $75 for a decent brand new PSU with a 2-3 year warranty and be more confident that it's not going knockers up in the middle of something critical.
                              Repair may be the only option. Replacement is not an option for many people or many circumstances such as specialized units or industrial applications.
                              Toast
                              veritas odium parit
                              • Krankshaft
                                • Jan 2007
                                • 2328
                                $30 bucks? Minimum wage in NJ is $7.25 per hour you saying it takes 4 hours to recap these things?
                                45 mins for me less than 1 hour minimum wage works for me .
                                I'm surprised Antec is still replacing these PSUs.
                                I'd think they'd honor the returns for 2-3 years and after that screw you.
                                • weirdlookinguy
                                  • Sep 2007
                                  • 1638
                                  Ratdude I do not mean to insult you, but this mentality is why everything sold these days is such shit. Everybody wants good stuff, but they also want it CHEAP. You gotta suck it in and cough up the dough if you want quality.
                                  Like I said, I do not mean to insult you or anyone... I'm pissy about this subject because I just got into an argument with a friend last night about cheap cases. People don't see the point in spending a bit of $$$ for something decent, but they sure do love to bitch and wonder out loud when it craps out / falls apart a year later.
                                  • Toasty
                                    • Jul 2007
                                    • 4171
                                    Hmmm... fine for those of us who are set-up and stocked for such things.
                                    Speaking novice/n00b here.
                                    - Learning how to get the caps out without destroying the foil traces or the ones that are double sided.
                                    - equipment
                                    - researching parts online
                                    - time spent here asking questions and researching
                                    - not finding that whacko-sized 3300uF cap at 25mm x 8mm that was shoe-horned in to begin with
                                    - more research
                                    - ordering from 2 different sources
                                    ...ad nauseum
                                    By the time you're done, you've chewed up a considerable amount of your time.
                                    I'm still hungry....!
                                    Toast
                                    veritas odium parit
                                    • ratdude747
                                      Black Sheep
                                      • Nov 2008
                                      • 17136
                                      ok, so pick a bank for me to rob. no money= no money
                                      ok, jk about that. i dont buy antecs simply because they used to be crap with a gold pricetag. i save money by buying higher quality USED stuff... mainly used Deltas. i will be buying one of thes 550w acbel units this week.
                                      sigpic
                                      • Toasty
                                        • Jul 2007
                                        • 4171
                                        >>ok, so pick a bank for me to rob. no money= no money<<
                                        LOL! Toast breaks out small violin and begins to play....
                                        I'm still hungry! Get them burgers flippin' son!
                                        and YES, I want fries with that!
                                        Toast
                                        veritas odium parit
                                        • privato89
                                          Nintendo Switch Oled HEG-001: Second-Stage Boot Failure
                                          by privato89
                                          I'm facing an issue with a HEG-001 motherboard that is unable to complete the Second-Stage Boot. I'd like to start directly with my conclusion, which is the decision to replace the MAX77621AEWI chip, and understand if it could be a correct evaluation.
                                          Before I dive into the process that led me to this decision, I want to mention that I have a fully equipped lab where I can perform any kind of tests.
                                          Let's begin:
                                          Following some guides online, I tried to understand how the Boot phase of the Nintendo Switch works, and what are the...
                                          03-26-2024, 06:37 AM
                                        • hinisa
                                          Xiaomi router freezes at boot after re-capping
                                          by hinisa
                                          I'm using Xiaomi Router 4A gigabit edition as wireless repeater. It worked fine for 2 years or so, but last week, wireless started to disappear.
                                          When I unplug/replug the power, it was working fine for a day/half a day or so until it freezes again.
                                          After testing with different power supply adapters and concluding it wasn't the issue I finally opened the case and this was the situation:
                                          Anyway I proceed to clean up the mess and replace all caps but unfortunately it made the situation worse. Now router can't even boot, either it freezes during...
                                          07-08-2023, 05:58 AM
                                        • Luke Anders
                                          Lenovo Legion 5 (15ACH6H/17ACH6H) - Does not boot into any OS
                                          by Luke Anders
                                          A few details about the laptop itself:
                                          Name: Lenovo Legion 5
                                          Model: 15ACH6H (according to its back cover details) / 17ACH6H (according to the BIOS Menu)
                                          BIOS Version: GKCN60WW
                                          EC Version: GKEC65WW
                                          Serial Number: PF39AQ7Z
                                          Board Model: NM-D562 Rev 3.0
                                          RAM: 16GB Installed, DDR4 (brand new)
                                          NVME: 500GB NVME drive (brand new, installed Windows 10 onto it for testing purposes and tested on another laptop (a dell XPS) works perfectly fine and boots in)
                                          I bought this laptop recently from eBay as a faulty device....
                                          10-12-2024, 05:13 AM
                                        • NolesFan
                                          Samsung un82ru88000f - Boot loop sort of but can correct with taping of LVDS ribbon
                                          by NolesFan
                                          Hello all... TV started boot looping. Opened the back panel and tried to isolate the problem. Just PSB no boot loop. PSB and MB no boot loop. Plug in the LVDS from panel to MB and boot looping starts up. It doesnt matter of order that I plug the LVDS ribbons back in, only 1 and no boot loop but as soon as 2nd one plugs in boot looping. I then noticed a flicker on the screen when I was closing the clip on the harness to the LVDS. Shut the lights off so I can see better, and I noticed as i slowly close it, I will get a picture, but as soon as it clips in, I lose picture and booting happens. So I...
                                          10-24-2024, 06:36 PM
                                        • praveenramavath
                                          Majority PETERHOUSE GRADUATE Internet Radio (Auna Silver Star) - Stuck at boot "Welcome" Screen
                                          by praveenramavath
                                          Hello All,
                                          I have an issue with my Majority PETERHOUSE GRADUATE Internet Radio, it keeps rebooting at the boot logo Welcome screen. I have an another forum active in other website but due to lack of response I am posting the same here. I am positing a link below that has pictures including all the troubleshooting I have tried, appreciate if someone can take a look and give me any suggestions.
                                          https://www.hifivision.com/threads/m...-screen.98243/
                                          Troubleshooting Summary: Majority Internet Radio - Flash Chip
                                          04-26-2025, 09:08 AM
