Re: RAID5 failure: 2 bad HDD's at the same time
that is what I am aiming for, something where 2 drives can fail. Anyone tried the SHR2 from Synology?
You _NEVER EVER EVER_ do that!
If a Drive in a RAID Array fails, you build a new one and copy the content from the old to the new one as long as it works. Start with the most important things.
Also RAID is NOT a replacement for the BACKUP!
So all you can do right now is to clone the drives and hope you have everything you need, then rebuild the RAID with the new drives....
No, I've lost nothing important and that is a good thing. I do have a few offline HDDs. Some of the stuff on the RAID array was so old, it gives me a chance to clean up my file storage. Rather than copying everything and deleting the stuff no longer wanted, I just revesed it by copying only the stuff I want. This gives me more space.Leave a comment:
Well, I guess I ran out of luck and shit hit the fan all right at home, ugh!
I am running a WD PR4100 16TB NAS. All was good until I noticed some slow file transfer occasionally. Done a HDD test and drive 2 failed. O.K. no problem, order new drive, replace drive and rebuild RAID5. Easy, right?Well not so fast. Wouldn't you suppose, the drive 3 failed, during the half way mark of rebuilding the RAID5 array on drive 2?
So all you can do right now is to clone the drives and hope you have everything you need, then rebuild the RAID with the new drives....Leave a comment:
This is why RAID IS NOT BACKUP.Leave a comment:
this is why for large arrays, raid 6 is a better ideaLeave a comment:
I prefer to trade robustness for convenience -- I only spin up a drive when I'm accessing its contents. If that content is munged, then I have to consider how much of the other content may be at risk. Or, if the box that I'm using to access that drive may, instead, be the culprit.
[Software/firmware/clients/apps/PEBKAC have been known to be buggy]
As I don't expect to encounter problems, when/if I do, it gives me a moment to think about what's happening before I propagate a failure (to other copies of the data).Leave a comment:
Well, drive 2 is FUBAR. Won't read from it period. Not sure why Drive 3 has some bad sectors and I was able to get the important stuff off the Raid5. So that is good. However I am not able to recover the whole Raid array. But that is o.k. I kept too much junk anyway.Leave a comment:
I've been able to successfully reassemble my Linux md-RAID5 arrays that were destroyed by two disk failures, but there's no guarantee that the data I pull off is accurate. However I was able to get a good portion of the data off after the failure.
Which reminds me, I need to backup my array again soon...Leave a comment:
thats why i dont buy nas boxes off the shelf. they are typically composed of a homogeneous set of drives so this means that the drives have a tendency to all fail at the same time! talk about very convenient planned obsolescence there! im sure the companies that make these nas boxes couldnt care less either if it means more buying and more money!
therefore, i prefer to diy my own nas and thus pick drives with different platter density technologies and different number of heads etc. so they would fail at different times instead.
do what eccerror said. for me, i fire up linux, pull the smart data, see how many pending, uncorrectable and reallocated sectors there are and run gnu ddrescue to pull as much data off the bad drive as possible if its still acessible and not bricked in which case the drive is totally unaccessible and undetectable neither by the bios nor os.
if the drive is bricked and the data is critical, send it to a data recovery company. the fee could cost thousands of dollars for the recovery.Leave a comment:
As always RAID is not a backup.
Question is, how bad are the drives. If you pull them up on their own on a PC (DON'T WRITE TO THEM!) can you at least read a few bytes? SMART information?
If you have two drives completely dead, you're probably SOL. If just one is dead and one has a few bad sectors, depending on your NAS firmware you may be able to recover something...unfortunately I don't have any experience with WD's RAID, just Linux mdraid...Leave a comment:
Of course, the "cost" (window of vulnerability) of rebuilding the failed drive will vary (e.g., RAID5 being more expensive than RAID1).Leave a comment:
Question is: How do I recover all the files or recover the RAID?Tags: None
by titomno2Hi guys,
I post my problem here because I think it could be a capacitor related issue (Asus support on this particular subject is non-existing).
So the computer is a Zephyrus-S17-GX735LXS-26T and the strange behavior is seen.
On cold start most of the time the internal screen is detected and a picture it works fine until shutdown, sleep or deep sleep.
Then the screen won't work for a long period of time.
If I wait 1 or 2 hours it work again most of the time.
When it doesn't work the batterie indicator blink 3 times white stop and the same schematic is repeated... -
by flat-eartherI have a cheap action camera with an annoying trait, every time I change batteries the date & time gets reset and I have to set it again.
To solve this problem I want to add a small internal battery inside it which will keep supplying power to the camera for a while while I change batteries so the date & time is retained.
I have opened the camera and I think there is enough room to add something inside to accomplish this:
The camera is powered by a 3.7V nominal single cell lithium ion battery.
So I need to connect another battery in... -
by OscarAVHello,
I just came here to see if someone has had the same problem I have, and if he or she solved It, to know how to do It.
I have made a quick search for my laptop but I have not seen anything similar.
I have an old laptop, an HP Pavilion dm4-1065dx which takes a lot of time to be ready to start if the laptop has been unplugged for a while. It has no battery. The battery failed long time ago. It needs to be plugged to work. But as I said, It can take a lot of time until the charging led gets on, and I can switch on the laptop. I am using an external monitor... -
by sam_sam_samI have had these 70 watt high pressure sodium yard lights for many years now probably at least 15 years or more and there is a protection diode that after several years starts to go bad and when it does this it has momentarily shutting down the light and then a few minutes later it starts working again
This about the forth time I have fixed this one and you can tell if it the diode or not if it lights up and it only shuts down when the air conditioner turns on then it is the diode
If it cycling on and off constantly then it is the bulb itself that is the issue
by Sus256Hi all!
HISENSE 65E7KQ PRO
RSAG7.820.13512 - chassis
MT9618BAATAB - cpu
RSAG7.820.12059 - power
HD650Y3U77 - panel
KLM8G1GETF - emmc
The TV does not turn on, the standby indicator is on. All voltages are present.
Emms is dead. Not readable, not detected.
Replaced emmc.
But with another dump there is no launch
Terminal log
UART
AC_ON
RPMB key is not yet programmed
HASH1_VERSION=0x00000000 64bit
E-B
FDE enabled
layout pattern onebin by SAR7,0... - Loading...
