Considering building a retro system
  • Uranium-235
    Comrade Glimmer
    • Aug 2007
    • 5042
    • US
    The friends of my best friend sent over three boxes of computer stuff they wanted me to look at. One thing I found was a LIKE NEW AT motherboard. With a 486sx. No IDE, just 5 pin din on the back. 16 bit isa videos card found too. I'm tempted to build an old dos box, even get doom on it.
    At psus are available new on newegg but cases are not
    Guess I need a sound card and an ide/floppy isa card too
    It does have three vesa expansion ports
    • 30965
    Re: Considering building a retro system
    visa? sx cpu? that is old.
    got cache chips on it, or empty sockets? that will make a huge performance difference
    • Curious.George
      • Nov 2011
      • 2305
      • Unknown
      If you truly want to stay "vintage", I may still have a PAS-16 that you could have... (I've already tossed my GUS MAX's)
      • Topcat
        The Boss Stooge
        • Oct 2003
        • 16956
        I like to try and mix 'em up a little.... I tend to not go back that far with age of systems.... Pentium classic is about as far back as I go for functional pieces, they'll play a lot of the classic games yet staying on relatively 'authentic' hardware. FOr retro games, 486's (with the exception of the DX4 100) were pretty useless for old games.... For the older pieces, which are pretty much nothing but conversation pieces, I'll try to keep them more 'original', just because they won't be doing anything but sitting there collecting dust....but its kinda neat to see a P-classic 233mmx running modern sata HDD's. There are many sata1 & sata2 controllers that will play nice with hardware of this era. Pci compliance & drivers are the biggest hurdle.
        <--- Badcaps.net Founder
        Badcaps.net Services:
        Motherboard Repair Services
        http://folding.stanford.edu/
        Team : 49813
        Join in!!
        Team Stats
        • Curious.George
          • Nov 2011
          • 2305
          • Unknown
          Ah, in my case, I keep old machines primarily to support old (expensive) peripherals or software packages (to support clients). E.g., I keep a Deskpro Portable 386 for the ISA bus (I have the 2 slot expansion chassis bolted on back) that supports a coprocessor card that runs a proprietary UN*X with some EDA applications. Even if I could run DOS in a VM on more modern hardware, the coprocessor card (and its special interface to DOS) wouldn't be supported.
          Likewise, I run a Chimera II card in one of my Solaris workstations to support some old W95 applications (EDA applications are notorious for not being forward or backwards compatible with earlier or later releases of THE SAME SOFTWARE!).
          My only "nostalgia" machine is a Sun Voyager which is just too cool to discard!
          https://hiveminer.com/Tags/sunos%2Cvoyager
          • Uranium-235
            Comrade Glimmer
            • Aug 2007
            • 5042
            • US
            It has one chip missing
            there were a few dx and sx chips in a bag too. I should have taken those
            is that missing chip a floating point coprocessor?
              • 30965
              the space is for a soldered in cpu, forget that.
              at the bottom is more interesting, 4 cache chips and 4 sockets that may allow another 4 - download a manual.
              and if it supports it, get a dx4-133
              • Uranium-235
                Comrade Glimmer
                • Aug 2007
                • 5042
                • US
                unfortunately, I have yet to find a model number
                you can see the cpu support by the jumpers by the cpu. it supports a DX2, says nothing about a 4
                • Curious.George
                  • Nov 2011
                  • 2305
                  • Unknown
                  Try using google's photo search (though you may still end up with a gazillion "close but no cigar" hits...
                  • Topcat
                    The Boss Stooge
                    • Oct 2003
                    • 16956
                    If you want a rip-assing 486, I found in my parts pile today a bootable adaptec ISA 50-pin SCSI adapter. Its BNIB. I don't remember the model off the top of my head.
                    Team : 49813
                    Join in!!
                    Team Stats
                    • eccerr0r
                      Solder Sloth
                      • Nov 2012
                      • 8691
                      Still have a 486 with a DX4/100 m/b (likewise VLB) somewhere. RAM is a problem, it has two 72-pin and four 30-pin SIMMs. I don't have enough dense SIMMs to do much with it.
                        • 30965
                        the biggest 72pin ram i'v seen is 256k
                        i had a load for SGI machines
                        • Topcat
                          The Boss Stooge
                          • Oct 2003
                          • 16956
                          Am I to assume you meant 256M? I've got some 128M SIMM's in a couple of my P-classic retro's. 256M isn't supported by their chipsets (HX), I did try them....they'd always hang @ the mem count.
                          Team : 49813
                          Join in!!
                          Team Stats
                          • Uranium-235
                            Comrade Glimmer
                            • Aug 2007
                            • 5042
                            • US
                            luckily I found a small box with a buttload of 30 pin simms. that was included
                            hmm I do have several scsi 50 pin drives. Before such a thing I need to test the board itself
                              • 30965
                              you may get the board i.d. from the boot message.
                              • Topcat
                                The Boss Stooge
                                • Oct 2003
                                • 16956
                                I think I have an AT full tower around here somewhere too.... A local shop also dumped off a box full of AT PSU's on me as well.
                                Team : 49813
                                Join in!!
                                Team Stats
                                • eccerr0r
                                  Solder Sloth
                                  • Nov 2012
                                  • 8691
                                  Hmm... I have an Adaptec 1542 and a 1522s somewhere, but I have a feeling that both will be clobbered by the VLB IDE controller I have for this 486, at least as far as I recall.
                                  I don't have any VLB video cards, however...
                                  Since ISA was mostly removed from latest Linux plus memory limitations, haven't really done anything with it except use it for DOS testing if at all.
                                  (I was luckily able to fleabay away a stack of 256K 30-pin SIMMs. Hooray...)
                                    • 30965
                                    very nice,
                                    AT psu's are like gold for testing non-pc stuff or building/fixing big arcade machines.
                                      • 30965
                                      you really want a bunch of 1meg or even 4meg sims.
                                      4meg was high-end - so wont be cheap - specially if the amiga/st crowd see them!!
                                      • Topcat
                                        The Boss Stooge
                                        • Oct 2003
                                        • 16956
                                        very nice,
                                        I've used them to test audio equipment (mainly head units) because they tend to have beefy +12v rails. You're 100% correct that AT PSU's are very useful outside the PC world!
                                        Team : 49813
                                        Join in!!
                                        Team Stats
                                        • Satdude
                                          Retro laptop floppy drive not working
                                          by Satdude
                                          Hi, I have a laptop with a Citizen W1D, an infamous drive in the retro computing hobby. They almost always have bad belts, such was the case with this one. However, after replacing the belt, the drive seeks and spins the disk, but the laptop still gives a "No bootable disk" error. Does anyone have any idea what could be wrong? The heads are clean and are able to move.
                                          05-24-2024, 02:32 PM
                                        • tmcw
                                          VESA EVC to VGA splitter cable
                                          by tmcw
                                          I found this splitter cable a while back, just got a chance to look at it now, and wondering what it might have been used for. Had a bit of trouble finding out initially what it was, main block that looks like a male DVI connector, split to 2 female VGA connectors.
                                          The main block that looks like a DVI connector is actually a VESA EVC male connector, best concise info here:
                                          http://www.interfacebus.com/Design_E...or_Pinout.html
                                          Pin 13 on the EVC connector is missing, so maybe removed for keying to some particular graphics card?
                                          Never came...
                                          03-26-2024, 06:26 AM
                                        • BOSCHNJAK
                                          by BOSCHNJAK
                                          ABOUT ME INTRODUCTION FILE
                                          2
                                          024 BEV, BIH, SARAJEVO START PROJECT: ELECTRIC VEHICLE TOYOTA 4 RUNNER CONVERSION http://www.bev.ba/TOYOTA4RUNNER/index.html
                                          2023 BEV, BIH, SARAJEVO START PROJECT: SECRETS AND MANUFACTURING PLANS (AS MY REPLICA) OF THE LIBERTY ENGINE 2.0.
                                          2022 BEV, PROJECT ?
                                          2021 BEV, PROJECT ?
                                          2020 BEV,BiH, Sarajevo: PROJECT IS: HOW TO SWITCH OFF PERMANENT MAGNET FIELD and HOW TO SWITCH ON PERMANENT MAGNET FIELD?
                                          2019 BEV, Croatia, Ston:, Broce: PROJECT - PROJEKT ELEKTRIČNI GLISER http://www.bev.ba/ELEKTRICNIVANBRODSKIMOTOR/indexHR.htm...
                                          12-28-2023, 02:09 PM
                                        • Topcat
                                          Topcat's Ultimate Pentium 4 Retro Gamer!
                                          by Topcat
                                          I'll open this build with the comment that the Pentium 4 processor was probably my least-favorite CPU; even in Xeons. Netburst processors were hot-running and quite unimpressive performers considering the high clock speeds....but they were capable to a certain extent.....and are now entering the peculiar era of 'retro-ness'.
                                          With that said; I was given THIS LITTLE JEWEL last Friday....a gaming rig built on the very CPU I liked the least....but there were some interesting things in it to say the least....and I really don't have a really good P4 retro gamer in my fleet....so....hmmm...yea...lets...
                                          03-07-2022, 08:20 PM
                                        • Brendon@aa
                                          Retro DC Bench Power Supply
                                          by Brendon@aa
                                          Hi, pretty new to repair and have an OLD benchtop DC power supply with no output. There is no voltage showing on the volt meter display however the current meter is full scale at 5a when on the 2a limit setting and 1.35a when on the 500ma setting.
                                          230V AC is making it past the fuse and into the main transformer - a yellow pair on the secondary has 30VAC on it, Brown pair 37V, there is what I think is a centre tap coming from the main transformer in green that has 15V and 20V respectively from the yellow and brown windings.
                                          From there the power dives into what looks like a control...
                                          12-28-2023, 09:47 PM
