Retro DC Bench Power Supply
  • Brendon@aa
    Tinkerer
    • Dec 2023
    • 9
    • New Zealand
    Hi, pretty new to repair and have an OLD benchtop DC power supply with no output. There is no voltage showing on the volt meter display however the current meter is full scale at 5a when on the 2a limit setting and 1.35a when on the 500ma setting.
    230V AC is making it past the fuse and into the main transformer - a yellow pair on the secondary has 30VAC on it, Brown pair 37V, there is what I think is a centre tap coming from the main transformer in green that has 15V and 20V respectively from the yellow and brown windings.
    From there the power dives into what looks like a control card, there are two big caps and what I thought would be large rectifier diodes on the heatsink are actually two ZN3055 matched pair transistors.
    The bottom transistor is running very hot at 51 degrees centigrade, the top one is a balmy 31 degrees (the workshop is 24 degrees today)
    Seems pretty obvious there is is a short somewhere, now how to find it., what is the best was to go about investigating this?
    The PS looks either home made or made from a kit, there is no makers mark of any type anywhere so not expecting to find a schematic.
    A diagram about how benchtop power supplies with matched pair transistors used to work in general would be very useful
    My next moves unless there are better suggestions are to:
    1) check the heatsink is not live
    2) remove the guts from the can so I can trace where the power flows from the main tranny and sketch out a bit of a circuit
    3) google power supplies that use matched transistors to get a hint
    4) check the voltages on the input and output of the ZN3055's and compare with the data sheet - something is clearly wrong there.
    Any help really appreciated
    Last edited by Brendon@aa; 12-29-2023, 03:18 AM. Reason: Corrected “bottom transformer” to “bottom transistor”
  • harp
    • Jun 2022
    • 599
    • Planet Earth
    Is output shorted?
    Not sure what transformer is heating, I see only one, not top and bottom.
    Are you thinking at 2N3055 bottom and top?...
    • Brendon@aa
      Brendon@aa commented
      Editing a comment
      Thanks Harp, there’s nothing plugged into the outputs but it definitely feels like the output stage is shorted
      Sorry, meant bottom transistor - have edited my typo
  • redwire
    • Dec 2010
    • 3910
    It looks like an electronics magazine build from the 60-70's? You would have to draw a schematic of the board and replace the really old parts, and even then you don't really know how well it worked in the first place.
    The main parts look good - huge power transformer, good heatsink, panel meters.
    What I would do is put in one of the $7 chinese 0-30V 2mA-3A PSU kit boards that are a copy of a 1978? British circuit. They use three op-amps and give adjustable current limit potentiometer as well as good regulation - max. is 24VAC input I think. Measure the DCV across the big filter capacitors and see if the voltage is OK or too high for the kit board, 35VDC max.​
    Or go on an adventure and try fix this.
    • Brendon@aa
      Editing a comment
      Thanks Redwire - it was our bench PS in the lab at the office for years, so has been going great. Yes I reckon it’s a kit and your age feels about right
      It’s a project more than a necessity so will attempt to create a schematic but if that’s a bust I’ll go the Chinese kit route as you suggest - thanks so much for the suggestion
  • harp
    • Jun 2022
    • 599
    • Planet Earth
    So, check with multimeter in diode mode all semiconductors like transistors and diodes for short... and visualy inspect that nothing phisicaly do not shorts over wires or on pcb track.
    Transistor who is warm mean that in that circuit is something shorted, or have low resistance, just follow track to inspect.
    From your actual pictures I can not see much.
    Some tips:
    Hesitate with mains live testing, and always use light bulb current limiter
    Pay attention on na fluffy wires, to not connect, crossover in air joints
    Before removing pcb from can, take notes where some wires go, because wire can easely snap and lost place of connectin. Some pictures also help to document other relevant things in the future in repair process.
    • redwire
      • Dec 2010
      • 3910
      The PSU is acting like there is a low resistance or short across the output. I have seen that when the output diode for reverse-polarity protection gets damaged.
      People will go to charge a battery, connect it backwards and the diode smokes and shorts. Look across the output jacks or on the PC board for a blown diode.
      • Brendon@aa
        Tinkerer
        • Dec 2023
        • 9
        • New Zealand
        Thanks Harp and Redwire, both great suggestions, I will have some time to get into this this weekend, really appreciate your ideas, and yes I have a light bulb limiter, another of Richard's (LER) suggestions that seems like a great idea! Thanks again, I'll let you know how I get along
        • shamsudeen
          Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
          by shamsudeen
          Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
          I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
          i know that in linear power supply the noise will be very low comparing to SMPS supply....
          07-19-2025, 07:14 AM
        • iMuhtaseb
          A1466 gone wrong RAM upgrade
          by iMuhtaseb
          hi
          had this 820-00165 2015 MacBook Air with 4GB of RAM.. i thought of upgrading the RAM to 8GB from the pile of donors that I had..
          I took a known-good 4 pairs off of a board and reballed them and put them to my board.. the computer refused to spin or power up.. I found out there was a short on PP1V2_S3.. I mistakenly injected 2 volts into it lol..
          Removed short, fan span but nothing appearing on screen whatsoever..
          I took another 4 pair from another board and put them to my board and still not powering on..
          its consuming half...
          07-02-2024, 09:57 AM
        • Eniaro
          Bench test a series X
          by Eniaro
          How do you bench test a series X? I was planning to find a defective PSU to use its connector, but before I go about doing this, I was wondering if there's any bench PSU to the series X connector adapter available
          06-17-2025, 01:46 PM
        • Topcat
          Topcat's Ultimate Pentium 4 Retro Gamer!
          by Topcat
          I'll open this build with the comment that the Pentium 4 processor was probably my least-favorite CPU; even in Xeons. Netburst processors were hot-running and quite unimpressive performers considering the high clock speeds....but they were capable to a certain extent.....and are now entering the peculiar era of 'retro-ness'.
          With that said; I was given THIS LITTLE JEWEL last Friday....a gaming rig built on the very CPU I liked the least....but there were some interesting things in it to say the least....and I really don't have a really good P4 retro gamer in my fleet....so....hmmm...yea...lets...
          03-07-2022, 08:20 PM
        • Topcat
          Rebirth of a Pentium II - P6DKF Retro Build
          by Topcat
          It's been a LOOOONG time since I've done one of these.... I've had the case for years, its just been sitting in my office with crap stacked on top of it. It has a Micronics 486 motherboard in it with a DX4-100 CPU.... I was never a 486 enthusiast, I had no intentions of doing a build with it....I only kept it for the case....which someone dropped off for recycling years ago.
          Anyway, I recently stumbled upon a Supermicro P6DKF AT motherboard and tested it in 'the oven'. I remember seeing one (or one similar) back in the 90's before eATX was a twinkle in anyone's eyes and wondering...
          03-25-2023, 09:20 PM
