VESA EVC to VGA splitter cable
  • tmcw
    • Oct 2010
    • 382
    • Ireland
    I found this splitter cable a while back, just got a chance to look at it now, and wondering what it might have been used for. Had a bit of trouble finding out initially what it was, main block that looks like a male DVI connector, split to 2 female VGA connectors.
    The main block that looks like a DVI connector is actually a VESA EVC male connector, best concise info here:
    http://www.interfacebus.com/Design_E...or_Pinout.html
    Pin 13 on the EVC connector is missing, so maybe removed for keying to some particular graphics card?
    Never came across this interface before. Anyone else familiar with it, using it still, on what type of equipment?
  • howardc64
    by howardc64
    Problem
    08-04-2024, 10:36 PM
  • Tomylee
    No LCD image after connector replacement – lifted components and damaged resistor (Nintendo Switch Lite HDH-CPU-02)
    by Tomylee
    Sorry for the person who’s going to read all this !
    I'm on a Nintendo Switch Lite, motherboard HDH-CPU-02.
    While replacing the left joystick, I had to remove the motherboard to access the connector underneath. When I lifted the LCD connector latch, it broke (the plastic had become brittle over time), so I replaced the entire connector.
    During the desoldering of the LCD connector using hot air, three small components located just below the connector (likely 0402 capacitors) came off and remained stuck to the bottom of the...
    07-11-2025, 11:52 AM
  • Tynan Dill
    by Tynan Dill
    Assuming...
    11-22-2024, 01:46 PM
    RJ45 Block Diagram / Schematic
    RJ45 network connectors are most commonly found at either end of an Ethernet (wired internet) connection. At first glance, they appear similar to the familiar telephone plugs and jacks which connect landlines to walls or switchboards. However, RJ45 connectors are typically slightly larger.
    The term RJ45 connector is widely used today to describe both male RJ45 plugs and female RJ45 sockets. The plugs, sometimes called modular connectors, are usually found on the end of Ethernet cables. The sockets or jacks are generally embedded in the device...
    10-31-2024, 04:18 AM
  • bussincaps
    MacBook Pro Mid-2014 A1398 Retina LED Controller Connector [First Repair (Disaster)]
    by bussincaps
    Hello All,
    tl;dr: minimal electronics experience and my first repair, lifted 8 pads off the laptop display LED controller board when attempting a connector replacement, options are attempting pad repair or jump wiring.
    Laptop Model: MacBook Pro 15 Mid-2014 Retina, A1398 MGXA2LL/A
    eDP Display: Samsung LSN154YL01-A02, assembly sold as Apple part 661-8310
    Soldering Equipment: Hakko FX-888D w/ T-18 tips (Chisel, Conical, Bevel types)
    I needed to replace the 30-pin I-PEX Cabline connector (labeled J8300 in the Apple 820-3662 mainboard schematics),...
    08-03-2023, 12:57 PM
