Partitioning based on media transfer rate zones
  • japlytic
    • Oct 2005
    • 2086
    You may know this, but for over 25 years hard disk drive manufacturers made use of zoned recording (more sectors on the outer tracks and fewer on the inner tracks) to maximize media recording density, but the inner tracks are slower as a result.
    For a piece of custom test equipment I am building (which would stream long patterns stored on the drive), a 500GB 2.5" drive was split into four partitions: the first 40% for 70-80 MB/sec, 20% for 60-70 MB/sec, 20% for 50-60 MB/sec and the rest for 40-50 MB/sec.
    Have you considered such partitioning?
    • 31250
    Re: Partitioning based on media transfer rate zones
    wont work,
    modern drives re-map the data virtually.
    if your after speed, get an "A/V" drive.
    the firmware is written to keep the data on consecutive sectors to reduce seeks.
    the downside to that aproach is you get heavily used areas on the platters that wear faster - hence the regular firmware scattering the data all over the platters.
    • diif
      • Feb 2014
      • 6978
      • England
      I've setup a few short stroking hard rives back in the day but they were only two partitions.
      Since SSDs are cheap and far faster, why bother ?
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8703
        Yes this works but if you plan on using the whole disk equally, you're killing yourself back to square one. "Short stroking" is the name of the game but you waste a lot of disk space.
        I did this decades ago with swap partitions to increase swap throughput. However if I needed to access the rest of the disk constantly, it would be a net wash or potential loss compared to sticking swap in the middle of the used area.
        • RJARRRPCGP
          • Jul 2004
          • 6304
          That's what I do for RAID-0. (At least for the OS and games)
          Need a bigger partition? Then just create another RAID array.
          ASRock B550 PG Velocita
          Ryzen 9 "Vermeer" 5900X
          Arc A770 16 GB
          eVGA Supernova G3 750W
          Alienware AW3423DWF OLED
          • Topcat
            The Boss Stooge
            • Oct 2003
            • 16959
            For the amount of data on my NAS, SSD still isn't feasible.... to small and too expensive.
            <--- Badcaps.net Founder
            Badcaps.net Services:
            Motherboard Repair Services
            http://folding.stanford.edu/
            Team : 49813
            Join in!!
            Team Stats
            • RJARRRPCGP
              • Jul 2004
              • 6304
              I got a Western Digital Black 1 TB spinner, just in case my Samsung TLC SSDs take a dump.
              Arc A770 16 GB
              • Curious.George
                • Nov 2011
                • 2305
                • Unknown
                And, likely, offers more performance than you'd actually *need*!
                At least in my case, my NAS is accessed much like my safe deposit box; occasionally fetch something and bring it home for normal use.
                So, my NAS is "cold", most days/weeks. And, I have to pick which physical volumes to install in it prior to actually accessing any of that data (list of every volume's contents can be browsed in an on-line database).
                • brethin
                  • Dec 2008
                  • 1907
                  I run 3 NAS units, 2 are very active, 1 with movies 32 TB raid 6, 1 with music 8 TB raid 6 and 1 for backups 48TB raid 6.
                  • Topcat
                    The Boss Stooge
                    • Oct 2003
                    • 16959
                    So is mine. This is my NAS setup. Each system pulls 280w off the grid. The second system in this NAS is a backup/mirror of the first one, and is off 99% of the time.....but I have considered ways to make it more efficient, such as ITX PC-on-a-chip setups, they don't require much raw horsepower. I run WD greens and WD reds, all 5400RPM spinners. THey run cool, efficient, and plenty fast enough for multiple HTPC's to stream from simultaneously....and well, of course store files. Each system has 2x 8TB RAID-10 arrays. They're close to capacity, but not crazy full....raw DVD ISO's are ~8gb each....then tunes....then work-related files.
                    Team : 49813
                    Join in!!
                    Team Stats
                    • ratdude747
                      Black Sheep
                      • Nov 2008
                      • 17136
                      I'm running a 14 drive 1.75gb RAID 10 with a 4tb weekly backup drive. Not terribly efficient but it fits in my rack, so I'm happy.
                      sigpic
                      (Insert witty quote here)
                      • Curious.George
                        • Nov 2011
                        • 2305
                        • Unknown
                        My NAS is "distributed" (many hosts on an internet) and operates at a much higher level of abstraction than a NAS "appliance". I.e., there are media that hold data, a VTOC that keeps track of "what's where" (and other metadata), interfaces that provide access (hardware and software) to the media (and, thus, the data) and rules that govern how data is replicated and "vouched for". Presently, about 100 spindles that can be powered up in various combinations on a score of hosts (so, HUGE processing and transport bandwidth).
                        Unlike an appliance, I place no constraints on the "availability" of data. The media holding it may be offline -- that doesn't make it corrupt, rather, just "having a longer access time"! Whenever a volume "appears", scanning (reverification) of its contents can resume -- as it is being otherwise accessed. If a particular volume is needed, the user is prompted to "mount it" (e.g., load a CD into a drive, somewhere that can be found).
                        I also don't care what type of media is used -- spinning rust, solid state (not just SSDs), tape (until recently), WORM (weening myself of this, presently), optical, etc. As long as there is an interface that can make that data available to the "system", it's OK. Interfaces can be IDE, SATA, SAS, SCSI, SCA, FC-AL, iSCSI, USB, 1394, CF, SD, SSD, etc. -- why should the NAS care?! It's just "storage"! (why do all of the physical volumes in the NAS have to share a common interface?)
                        I use an RDBMS as the VTOC -- as well as for tracking housekeeping data for the Array (i.e., when was the last time this datum was VERIFIED?).
                        And, the rules are just software -- algorithms.
                        These looser constraints give me more flexibility in what I can store, how I store it and how much effort I want to have expended (on my behalf) to preserve any particular datum ("file"). I can choose to store five different copies of an object ("file") in five different places ("containers") on five different media ("volumes") of five different physical characteristics ("media types") behind five different interfaces hosted by five different OS's. Yet, to *me*, the user, they are all functionally interchangeable! Give me ANY of those copies and I've got the data that I want/need!
                        [I.e., the CD/DVD originals from which I created each of the ISOs can be genuine parts of the NAS store -- even though they are read-only, removable, slow, small, etc!] If an ISO gets corrupted, the RDBMS tells me where to find another copy of the files IN the ISO that have been affected -- so the ISO (which is a container!) can be recreated. Ditto a RAR/ZIP archive, etc.
                        I can implement any variety of RAID (no striping) on any collection of files/objects just by building those desired relationships in the RDBMS that tracks all of the contents of the various volumes. And, at a granularity appropriate for the data involved. Volumes need not be the same size or have similar access characteristics (e.g., one half of a RAID 1 can be a CD while the other half is made of rust)
                        Because the RDBMS is available 24/7/365, I can browse the NAS's contents without having any of those media actually on-line. And, I can define the schema to let me annotate entries in any way that makes sense, to me (beyond just a "filename").
                        I can expand the array one volume at a time without having to "rebuild" anything. E.g., the 12 2T SAS drives I picked up this week magically increase the array's capacity without any special overhead -- just start copying files onto them like any other media!
                        Finally, I can deal with subsets of the array outside of its scope -- just move the drive to another machine and access it as a "normal" drive (e.g., a USB disk can be carried to a friend's home and used there; then reattached to the array as if it was never gone!). Because of this, I can recover/repair/access multiple volumes concurrently WITHOUT requiring special appliance hardware! (what happens when the power supply in your appliance shits the bed? or, the NIC fails?)
                        • Curious.George
                          • Nov 2011
                          • 2305
                          • Unknown
                          I've had bad luck with Greens (I don't even bother rescuing them, anymore).
                          What sort of sustained throughput can you get from them (or the reds)? I'm building a 50T datastore for the RDBMS in my "disk sanitizer" to store compressed disk images from which to mass-produce machines. I'm stuck trying to balance power consumption (it would be nice to only have the drives that were serving up images AT THE TIME actually spinning) vs throughput -- I want to be able to build multiple machines concurrently. I either have to actively manage power on the individual drives (i.e., spin down those that aren't needed at the moment) or opt for drives that will do this on their own (though they are usually lower performing).
                          • reformatt
                            Intel iMacs, 3rd party SSD failures and Fusion setups
                            by reformatt
                            I thought I'd throw out some of my personal experiences in the last 12 months with Intel iMacs, 2.5" SATA SSD drives and Fusion drive data recoveries.
                            As a backgrounder, Apple never fitted a 2.5" SSD's to these iMacs. Apple's SSD option was a system of 32GB NVMe blade drive (NGFF connector) and Seagate 1TB 2.5" HDD, married together in software to become a Fusion drive. Non Fusion systems have just the 1TB Seagate HDD.
                            So, the most common reason an iMac comes across my bench is because it's either ridiculously slow, or it fails to boot at all. The most...
                            12-18-2024, 10:34 PM
                          • Geeker007
                            Please review my ESP based WLED controller board for WS2815 12V LED Strips - New to electronics.
                            by Geeker007
                            I'm designing an ESP-based WLED controller board for WS2815 12V LED strips, with a primary focus on energy efficiency.
                            To minimize power consumption, my goal is to completely shut down the system when the LED strip is turned off.
                            However, the current buck converter powering the ESP module draws about 8 watts even when the LEDs are idle, making it unsuitable for low-power operation.
                            I am using below components:
                            • Buck Converter: TPS562201 (12V → 5V regulated)
                            • Microcontroller: XIAO ESP32-C3 (with built-in USB-C)
                            • LED Strip: WS2815 (12V digital LED strip)
                            • Switching
                            06-29-2025, 05:20 PM
                          • someonenotyou
                            How to transfer information from one BIOS to another?
                            by someonenotyou
                            Hi.
                            I am starting to learn about UEFI BIOS.
                            At the moment I have Lenovo laptop with bad BIOS.
                            I tried to clean ME region and transfer EC region from a known working BIOS, but the laptop does not POST (just fan spin).
                            So there is something else bad.
                            If I flash a know working BIOS, the laptop POSTs and boots into Windows.
                            But the problem is, that the serial numbers, Windows key, and every thing else is from another laptop.
                            Where do I start to transfer the S/N, Windows key and other information from one BIOS to another?
                            Thank y...
                            03-04-2025, 03:41 AM
                          • SluggerB
                            Tivo HD will not transfer files ....
                            by SluggerB
                            Not sure where to post this, thought this might be the best place
                            Tivo setup:
                            Tivo 1 - Tivo HD, Monthly service (ancient, over 10 years old)
                            Tivo 2 - Tivo HD, Monthly service (ancient, over 10 years old)
                            Tivo 3 - Tivo HD XL, eBay Tivo with Lifetime service (newer but still old)
                            Yes I am the idiot that paid monthly for all these years. I found a broken Tivo HD XL with lifetime service on eBay for $40 (Tivo 3), I bought it, it was a bad power supply, I re-capped it, good as new. So the plan was to cancel Tivo 1 and use Tivo 3 in it's stead. So I...
                            07-02-2022, 08:09 AM
                          • wshadow
                            HP Mini 800 G5 - Transfer identity & WinLic between two mainboards
                            by wshadow
                            I got two HP Mini 800 G5 machines, both 65W mainboards (have all 12 FETs populated on the CPU power rail).
                            One board is always throwing errors in MemTest86, no matter which known good CPU/RAM combo installed. Board is fried. Period. Will be scrapped.
                            The defective board contains a Win10Pro license in BIOS.
                            The other board is working perfectly fine, but only includes a FreeDOS "license".
                            I want to transfer the Win10Pro license from the fried board to the working one. If that includes transferring S/N etc, I'm fine with that, will...
                            09-15-2025, 09:04 AM
