Tivo HD will not transfer files ....
  • SluggerB
    • Aug 2020
    • 747
    • US
    Not sure where to post this, thought this might be the best place
    Tivo setup:
    Tivo 1 - Tivo HD, Monthly service (ancient, over 10 years old)
    Tivo 2 - Tivo HD, Monthly service (ancient, over 10 years old)
    Tivo 3 - Tivo HD XL, eBay Tivo with Lifetime service (newer but still old)
    Yes I am the idiot that paid monthly for all these years. I found a broken Tivo HD XL with lifetime service on eBay for $40 (Tivo 3), I bought it, it was a bad power supply, I re-capped it, good as new. So the plan was to cancel Tivo 1 and use Tivo 3 in it's stead. So I backed up everything I want off Tivo 1 onto Tivo 2 using the transfer functionality from the Now Playing Menu. Goes fine. I then get Tivo 3 setup up and working, works great. I then cancel the service for Tivo 1 and stick it in the closet for spare parts
    So now I have Tivo 2 and Tivo 3 up and running. I want to get the programs I backed up from Tivo 1, that are sitting on Tivo 2, onto Tivo 3. And I am having problems. Here are the issues:
    - If I try to transfer directly from the Now Playing list of Tivo 3, I can see Tivo 2, if I go into that I see the list of programs on Tivo 2, but when I try and transfer anything, it doesn't start and eventually errors out saying there is a network problem
    - I installed Tivo Desktop on a PC, with that it sees the Tivo 2, but when I go to get a list programs, it counts the first show (it says 1/46) then I get a network connection error and nothing. If I select Tivo 3, it works with that Tivo just fine
    - I installed kmttg, it sees the HD, when I try and pull a list it eventually errors out with
    Code:
    "https://192.168.68.110/TiVoConnect?C...AnchorOffset=0
    http IO exception for: https://192.168.68.110/TiVoConnect?...aying&Recurse=Yes&ItemCount=32&Anch orOffset=0
    Unexpected end of file from server
    Failed to retrieve Now Playing List from Bedroom Tivo
    Check YOUR MAK & IP settings
    - If I go to the https:// of the IP address of Tivo 2, sometimes it does prompt me for the login, I enter tivo and the MAK, but then it just sits there and does nothing. Sometimes I get a Server busy/Out of memory message, and at that point the Tivo becomes unresponsive and needs to be rebooted. Going to the https:// screen of Tivo 3 works fine.
    - I installed pyTivo, it sees both Tivo's, it works with Tivo 3 fine, for Tivo 2, it just hangs forever trying to populate the Now playing list
    - I set a static IP and DNS (using googles DNS servers), didnt make a difference
    I have rebooted Tivo 2 and the PC's multiple times. Something seems wrong with the network stack of Tivo 2. It does everything else just fine, Live TV, playback, recording all work as expected. But I cannot get programs off this thing. I was able to transfer programs to it no problem, but I cannot get them off.
    Any ideas? Could it be possibly hardware related?
  • nomoresonys
    • 12254
    • U.S.
    Re: Tivo HD will not transfer files ....
    not sure but maybe you can't do it because your service is canceled:
    https://www.usatoday.com/story/tech/...tivo/21495221/
    • SluggerB
      • Aug 2020
      • 747
      • US
      I checked online, and also called Tivo customer service, my account on Tivo 2 (which is the one that I can't transfer programs out of) is in good standing.
      The Tivo itself is discoverable by all these apps, but when you try and access the Tivo, the network stack on the device fails. Also I didnt mention it but the Tivo is on a Wired connection.
      Do you think it could possibly be a hardware issue? I will pop the cover off later and see if I see anything obviously wrong, if not I will check out any components near the ethernet port. I can also check diode readings on the chips and compare them to readings I can take off my other Tivo (which always worked fine).
      • SluggerB
        • Aug 2020
        • 747
        • US
        I hooked up the Tivo to a Wireless adapter, bypassing the Ethernet port, and still no dice, so it would not seem to be an ethernet port issue
        • nomoresonys
          • 12254
          • U.S.
          did you reboot the modem, and router if used? is the router seeing both devices?
          • SluggerB
            • Aug 2020
            • 747
            • US
            I did reboot the router, and the router does see both devices, both has IP addresses assigned. The tivo can also successfully connect to the Tivo service. It's just on copying files the network connection fails.
            • diif
              • Feb 2014
              • 6978
              • England
              Is there a transfer limit ? You can copy to one Tivo but not from that to another.
              Windows 10 wasn't involved for the copying was it ? I've seen it do weird things with file permissions.
              Setting google as your DNS wouldn't make a difference, that's external DNS only, depending on your setup it would be your router/modem that does your internal DNS.
              • nomoresonys
                • 12254
                • U.S.
                wonder if their server is not working correctly.
                • SluggerB
                  • Aug 2020
                  • 747
                  • US
                  there is no transfer limit that I know if.
                  The initial Transfer was Tivo -> Tivo, no PC required. After Tivo <- Tivo failed, I tried using a PC as an intermediary, to no avail. No Windows 10 here, all Windows 7. I've tried 2 different physical PC's and a VM all with identical results so I don't think thats the issue.
                  Since the other Tivo works flawlessly I do not think it is an external issue.
                  • nomoresonys
                    • 12254
                    • U.S.
                    head scratcher, there's this, don't know if it applies tho: Note that some shows cannot be transferred due to copyright restrictions placed upon them by the content owners. These shows are marked with a red circle-slash.
                    • SluggerB
                      • Aug 2020
                      • 747
                      • US
                      These are shows transferred from another Tivo. So there are transferrable.
                      • nomoresonys
                        • 12254
                        • U.S.
                        ok, wasn't sure if they had already been transferred or not.
                        • someonenotyou
                          How to transfer information from one BIOS to another?
                          by someonenotyou
                          Hi.
                          I am starting to learn about UEFI BIOS.
                          At the moment I have Lenovo laptop with bad BIOS.
                          I tried to clean ME region and transfer EC region from a known working BIOS, but the laptop does not POST (just fan spin).
                          So there is something else bad.
                          If I flash a know working BIOS, the laptop POSTs and boots into Windows.
                          But the problem is, that the serial numbers, Windows key, and every thing else is from another laptop.
                          Where do I start to transfer the S/N, Windows key and other information from one BIOS to another?
                          Thank y...
                          03-04-2025, 03:41 AM
                        • SluggerB
                          Tivo Series 3: Green blinking light of death
                          by SluggerB
                          Anyone familiar with these old Tivos and the blinking green light issue they can develop?
                          Someone sent me one that is exhibiting the issue, and I've been taking reading around the board and comparing them to a known good Series 3 Tivo motherboard I have, and so far the only different I can find is a difference in diode reading on a voltage regulator. However when I swap over the voltage regulator from the good Tivo to bad Tivo, it shows the diode readings of the original component, so something else is causing the issue
                          Power supply is good so I know it's not that....
                          07-14-2023, 09:12 PM
                        • Mark D
                          Samsung UN65JU67ODFXZA Version TD01 Schematic and Parts List
                          by Mark D
                          The TV is a Samsung UN65JU67ODFXZA Version TD01. I replaced the power source board and the TV is now working, but I decided to try and troubleshoot the old board to fix at the component level. Trying to get a schematic and a parts list has proven to be an issue. Trying on my own, I can't tell you how many times my Norton security has flagged sites as "malicious". I ordered a service manual from ServiceManuals.net, paid $16.99 and got 66 pages of everything BUT schematics and component parts list! Can anyone steer me in the right direction? Some of the surface mounted component parts...
                          10-29-2024, 03:15 PM
                        • Deby
                          List of compatible laptop motherboards
                          by Deby
                          This is a list of compatible laptop motherboard information that I have been collecting for some time.
                          And it's still ongoing.
                          Every time I come across information that a board is compatible with another, I write it down.
                          Anyone who wants to, can continue to expand the list.
                          Packed in the rar, is an excel table that has additional information.
                          Motherboards.rar...
                          05-31-2024, 04:34 AM
                        • wshadow
                          HP Mini 800 G5 - Transfer identity & WinLic between two mainboards
                          by wshadow
                          I got two HP Mini 800 G5 machines, both 65W mainboards (have all 12 FETs populated on the CPU power rail).
                          One board is always throwing errors in MemTest86, no matter which known good CPU/RAM combo installed. Board is fried. Period. Will be scrapped.
                          The defective board contains a Win10Pro license in BIOS.
                          The other board is working perfectly fine, but only includes a FreeDOS "license".
                          I want to transfer the Win10Pro license from the fried board to the working one. If that includes transferring S/N etc, I'm fine with that, will...
                          09-15-2025, 09:04 AM
