Geforce 6800gt VGA missing red output signal
    replied
    Re: Geforce 6800gt VGA missing red output signal
    If you can, YES.
    I think only two of those are really needed to get an image, though (two of them are simply grounds.) But again, skipping the two grounds on those may deteriorate the image even further.
  • shabs1985
    replied
    Originally posted by momaka
    You'll need a soldering iron with a sharp tip. The tip doesn't necessarily need to be small. It just needs to be sharp. Chisel and bevel-shaped tips should be easier to use over regular conical/pencil. The one on my iron is spoon-shaped (cheap copper tip that wore into a spoon over time, but it works great for SMD stuff.)
    As for the inductors... just put piece of wire in their place or a 0-Ohm SMD resistor. It's not an ideal solution (may or may not cause slight color imperfection or possibly noise/blurriness at very high resolutions), but it will get the card working, at least.
    Will I have to solder 4 wires for the two missing inductors?
    replied
    That's why I pick them up with a toothpick with a tiny bit of gel flux on it.
    Otherwise... yeah when they fly away, good luck finding them. For me it's even harder, as I have a thick carpet on the floor. It's white (thankfully) and not those off-white or gray carpets that tend to hide everything you drop on them.
    replied
    i used an 858d,
    the only real problem with 0402 is losing them when they ping off the end of the tweezers - just as well they come in long strips!
    replied
    I suppose if the part is in an inconvenient spot, then hot air might be easier to use. I haven't encountered that too many times, though - at least not on video cards and motherboards. And I actually like doing those small 0402 SMDs with my iron - they are pretty easy. Helps to have long nails, though, (or good tweezers and a steady hand) as I often usually just keep the SMD on the board with my thumb nail, and then touch with the iron on one lead, then on the other. Takes maybe 1-3 minutes max to do everything. Hot air can be quick only if you have a good powerful station and you're working on a smaller board. The 852D+ I have takes way too long to solder anything, even on max heat, so I don't bother with it most of the time. It only comes out for QFN chips or similar work.
    replied
    some gell-flux and hot air and the part will center itself on the pads,
    i was recently changing some 0402 resistors like that!!
    replied
    ^ Really? For SMDs with two leads only? Nah, I don't have the nerves for hot air for small stuff like that. Unless it's SMD with many (over 10) small pins, I don't bother with hot air. If you do hot air, then you need good flux and probably also solder paste, and a slew of other stuff. With iron, you just need flux and a steady hand.
    replied
    hot air station.
    replied
    Originally posted by shabs1985
    I have two inductors missing. how would you solder thesee back onto the board?
  • shabs1985
    replied
    replied
    read the post again,
    it's not a cap - he has an inductor missing because someone damaged it.
  • shabs1985
    replied
    I also have a 6800gt with the same no red on vga issue. did replacing the cap work?
  • japlytic
    replied
    I recommend replacing all three as a set for best performance - these inductors are typically used for electromagnetic compatibility.
  • dj_ricoh
    replied
    Can you post a picture how it looks in curent state on the screen?
    replied
    Originally posted by Topcat
    I was going to suggest that for testing purposes.
    Well, that's what I did on my first card with that issue (a Radeon HD2400 XT). But then I found out that this "for testing purposes only" "temporary repair" was good enough for the analog resolutions I wanted to run (no ghosting or noise whatsoever). So I started "fixing" every card with this issue in this way... unless of course I had an exact replacement component from another card (which I do quite often, as I keep a good stash of dead GPUs.)
    Originally posted by Uranium-235
    you could also use a dvi-vga adapter if the port supports it
    Yup, or that.
    It should support it. DVI (digital-only) ports became standard only on the Radeon RX series and GeForce GTX 10x0 series... and everything afterwards, of course, as modern GPUs no longer carry RAMDACs (save for some of the lower-end cards that may still come with a VGA port.)
    But the 6800 GT is certainly old enough to support analog output through DVI.
  • Uranium-235
    replied
  • Topcat
    replied
    If bad comes to worse, you can just solder a piece of jumper wire across the inductor. It will work fine. I've done it before many times. Just might affect signal clarity at very high analog resolutions.
    replied
    *tries to locate the DVI port on the back of the CRT monitor*
    I don't think I have one!
  • Uranium-235
    replied
    why not just use superior dvi
    replied
    Note about your missing inductor above: it is a dual-inductor / common mode inductor. But really only one of the lanes (sides) caries the red output. So you only need to jumper that side - if using a jumper, that is.
    NVIDIA GeForce RTX 3080 / RTX 3090 Schematic & Board View
    The GeForce RTX 3080 is an enthusiast-class graphics card by NVIDIA, launched on September 1st, 2020. Built on the 8 nm process, and based on the GA102 graphics processor, in its GA102-200-KD-A1 variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on GeForce RTX 3080. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The GA102 graphics processor is a large chip with a die area of 628...
    10-02-2024, 08:52 AM
  • gurj1979
    Asus Zenbook UX431DA / UM431D - Ryzen - missing PWM Fan Signal.
    by gurj1979
    Hey guys.
    Need help with this one.
    Fan not spinning due to missing PWN Fan signal.
    Also 5 seconds from powering up it freezes, unless in BIOS.
    But as soon as Windows starts to load, it will freeze.
    CPU is COLD / Room temp when it freezes.
    I've replaced the CPU, same problem.
    Replaced SIO/KBC IT8987e and reprogrammed - same problem.
    Replaced fan - same problem.
    Replaced flex cable from board to daughterboard (which has fan connector on it) - same problem.
    Checked the Thermal sensors around CPU and Board to the SIO/KBC and...
    08-19-2024, 05:22 PM
    NVIDIA GeForce RTX 2060 / RTX 2070 Schematic & Board View
    The GeForce RTX 2060 is a performance-segment graphics card by NVIDIA, launched on January 7th, 2019. Built on the 12 nm process, and based on the TU106 graphics processor, in its TU106-200A-KA-A1 variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on GeForce RTX 2060. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The TU106 graphics processor is a large chip with a die area of 445...
    10-02-2024, 07:51 AM
    NVIDIA GeForce GTX 950 / GTX 960 Schematic & Board View
    The GeForce GTX 950 was a mid-range graphics card by NVIDIA, launched on August 20th, 2015. Built on the 28 nm process, and based on the GM206 graphics processor, in its GM206-250-A1 variant, the card supports DirectX 12. This ensures that all modern games will run on GeForce GTX 950. The GM206 graphics processor is an average sized chip with a die area of 228 mm² and 2,940 million transistors. Unlike the fully unlocked GeForce GTX 960, which uses the same GPU but has all 1024 shaders enabled, NVIDIA has disabled some shading...
    10-01-2024, 01:54 PM
  • jpreza
    Apple NVIDIA AGP GeForce 6800 GT Dual Link DVI+DVI outputs 603-6338 missing caps!
    by jpreza
    I recently acquired this card from a seller who was selling a PowerMac G5 for parts. He mentioned that the video card was probably broken too.
    Upon closer inspection, I can tell the reason why it won't work: it's missing a bunch of CAPS! (it's also missing an inductor - 1.0uH).
    It's a nice card as it's one of the few AGP cards that will support 2560 x 1600 resolution on a PowerMac G5 using a 30" Cinema Display.
    Looking at the card, it appears to be missing the following:
    1x 1.0uH inductor - orange square
    2x...
    11-01-2024, 10:54 PM
